377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. wimsjohn
    Honeycomb Jan 9, 2016
  2. fremond
    Froyo Jan 9, 2016
    fremond , Jan 9, 2016 :
    Yeah, you cant use the stock weather app if you dont know mandarin :)
  3. RichtigerLurch
    Gingerbread Jan 9, 2016
    du04lal likes this.
  4. ming6247
    Cupcake Jan 10, 2016
    ming6247 , Jan 10, 2016 :
    Dear OnePlus,
    hi there. i just gotten my OnePlus 2 yesterday and after configuring it, it has a software update upgrading to 2.2.0 ' OnePlus2Oxygen_14_1512111634' which consists of 87MB. after downloading successfully, i try to install it but it failed. i try to dwl the OTA and flash it too, but i dont seems to work. please solve this problem! or maybe release another update for people who are having difficulties in getting this update. your help is very much appreciated! would love to hear from you soon!
    Thank you very much!
    Best regards.
  5. thunderbird2
    thunderbird2 , Jan 10, 2016 :
    Dear All,
    Post upgrade of my Oneplus2 to OxygenOS version 2.2.0, i see that WIFI speeds (download & upload) are very slow.D/L speed is ~ 10 MBPS and U/L speed is <10kbps.
    Another device on same WIFI network shows 72 MBPS/9MBPS constantly.
    I never faced this issue before the upgrade.
    Anyone else facing this problem and suggest any fix ?
    Thanks in advance.
  6. ayk1982
    Ice Cream Sandwich Jan 10, 2016
    ayk1982 , Jan 10, 2016 :
    This isn't a customer support. Either clean flash the OS 2.2 on your own and instructions can be found on the forum if you do a search or scroll down to contacting online customer support and chat with them
  7. pkatiyar
    pkatiyar , Jan 10, 2016 :
    my One plus 2 hangs everytime after unlocking. No matter how i unlock the phone. It hangs for couple of minutes and then it works fine.
    I know this is not customer support, but i am not able to get hold of any help.
  8. pkatiyar
    Seems like many people are stuck with minimum 5 replies or missing order number for tech support access. seems pretty stupid for such tech company.
  9. iNathan
    Gingerbread Jan 10, 2016
    iNathan , Jan 10, 2016 :
    Since 2.2.0 I've had constant lag issues.
    - Swapping apps
    - Opening apps
    - Opening folders
    - Unlocking phone (unlock sound plays then after 3-4 seconds the screen comes on - the home screen redraw is also slow at this point)
    - Even hitting the back button in settings or Google Hangouts takes a while.
    This is all very random and not 100% of the time and not limited to certain actions.
    Roccia85 likes this.
  10. Leehm
    Honeycomb Jan 10, 2016
    Leehm , Jan 10, 2016 :
    10 more days then it reach one month since this update. Any news for marshmallow?NOT ETA.
  11. Leehm
    Go to the custom ROM there find the FULL Oxygen 2.2.0 zip file. download it and copy to your OPT. Reboot to recovery and flash the zip and you're done.
    NOTE:You are able to flash original ROM without root, unlock and flash custom recovery.
  12. Miraq
    Donut Jan 10, 2016
    SaltLife likes this.
  13. smart vamsi
  14. yeti_inparis
    yeti_inparis , Jan 10, 2016 :
    Hi Helen,
    I have an oneplus 2. The newest oxygen update doesn't work. When l ckick on "reboot", a message tells me 'installation's failed'. How could I upade my phone if the automatic update seems not to work.
  15. adnansajid33
  16. sungfive
    Sahilkum likes this.
  17. Chicano
    Froyo Jan 10, 2016
    Chicano , Jan 10, 2016 :
    I would say no problem here also, but my recently updated OnePlus2 stopped working for two or three times. I had to restart it from the power button. I will be more careful and see where the problem is and what apk is putting it in "freeze mode"
  18. Roccia85
    Roccia85 , Jan 10, 2016 :
    I have exactly the same issues.
    I hope there will be one another update soon to fix these bugs...!
    Thank you in advance opo.
    iNathan likes this.
  19. Zafaryaab
    Zafaryaab , Jan 10, 2016 :
    If OPT has dual stand by then I am facing serious issue, when I am on sim 2 I am unable to receive calls on sim 1 !!! Plz someone has any solution for it
  20. serafinasmith
    Cupcake Jan 11, 2016
