377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. redditoneplus2
    Cupcake Jan 21, 2016
    redditoneplus2 , Jan 21, 2016 :
    I think the left side is the microphone, no speaker here. The right side the only speaker...
    Prashant Juyoti likes this.
  2. hasssha122
    hasssha122 , Jan 21, 2016 :
    Hello brother , i have a update but its update failed . and its showing twrp locked what does that mean ?
  3. scarEEcrow
    Donut Jan 21, 2016
    scarEEcrow , Jan 21, 2016 :
    I have an One plus two ...just bought it yesterday actually...it shows an oxygen version of 2.1.0...and system update available of 2.2.0,but after downloading the update,it fails to install and asks for reboot option only.....all the stock apps are also backdated after the reboot....please give me a solution.... :(
  4. akbasu777
    Gingerbread Jan 21, 2016
    akbasu777 , Jan 21, 2016 :
    The adapter was out of stock in Amazon India till recently but yesterday I found it available and immediately placed order. It is quite costly - ₹699! but no option. Let me try it after receiving it.
  5. akbasu777
    I have updated to 2.2.0 about two weeks back. No issue till now - Touch Wood !!!
  6. JustAPhone
    Ice Cream Sandwich Jan 21, 2016
    nhittalamani likes this.
  7. Makz25
    Makz25 , Jan 21, 2016 :
    Audio Tuner kill the Audio quality with Bluetooth headphones and Bluetooth speakers :( can i delte the App ?
  8. rgvd1987
    rgvd1987 , Jan 21, 2016 :
    U can disable it.
  9. Ajeet Kumar3
  10. baslia
    baslia , Jan 21, 2016 :
    I have no big deal except sometimes the phone freezes qnd I have to reboot it ...
    I experienced some lag sometimes, so I have to reboot the phone once a week
  11. Earl234
    Earl234 , Jan 21, 2016 :
    Same problem here. My 5 days old OP2 with Ox 2.1.0 and some apps offers me Ox 2.2.0 update every time i reboot it but after downloading it starts to install and fails at say 20%. Not sure about app backdating, never checked it. Need step-by-step guide for Android dumbuser.
    scarEEcrow likes this.
  12. Tharoon500
    Tharoon500 , Jan 21, 2016 :
    I'm having, some trouble with the new update.
    My phone freezes random times i.e. when i'm stream videos, surfing on the internet or play, my phone button doesn't work nor either the touch screen.
    When watching video fx. the video freezes but the background sound still works..
    the only way to stop it is by turning the phone off..
  13. arrow34
    arrow34 , Jan 21, 2016 :
    Same here, was fine on 2.1.2, not on 2.2.0 and MASSIVE lag! Need help to fix this, please fix your update!
  14. FoxYume
    Eclair Jan 21, 2016
    FoxYume , Jan 21, 2016 :
    I've been having major issues with the phone lately as well.
    Lag, freezes, crashes, random reboots. It all happens so often nowadays that it's just not funny any more.
    Hopefully the January-update will fix this.. If there's going to be a January update that is..
    It seems to become a common thing with OnePlus phones. Hardware is awesome, software just lacks. The OPO had it last year (looking at you, Lollipop update..) and now this one has it as well..
  15. nhittalamani
    nhittalamani , Jan 21, 2016 :
    It's Jan 2016..No update yet..its Q1 when will Android M arrive..?
  16. KostasV
    Honeycomb Jan 21, 2016
    KostasV , Jan 21, 2016 :
    It will be Q1 till 31/03...
    vonMonster likes this.
  17. deleco
    Cupcake Jan 22, 2016
  18. deadtingel
    Froyo Jan 22, 2016
    deadtingel , Jan 22, 2016 :
    Just stay ;-) wait for next updates or skip till marshmallow. As long everything works fine, not change something.
  19. JustAPhone
    Ice Cream Sandwich Jan 22, 2016
    JustAPhone , Jan 22, 2016 :
    You can't delete it.. or disable from the app list.
    But i think you can stop using it.... go to the app, menu -> the very bottom you will see Sound Effects turn on of off.
    I use bluetooth headset so this thing won't turn on, basically i am safe from the low quality audio from the tuner... i use rocket player EQ then.
    Makz25 likes this.
  20. Krishna442
    Eclair Jan 22, 2016
