377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. anupritaisno1
    KitKat Dec 21, 2015
    anupritaisno1 , Dec 21, 2015 :
    it's normal after an update for the phone to be unresponsive for sometime.
  2. souravsunny
    Gingerbread Dec 21, 2015
    souravsunny , Dec 21, 2015 :
    What about the CPU usage...The Snapdragon 810 was an Octa core processor.. The 4 High performance core never fire together after last update no matter what I throw at it... Only 2 high performance cores work together... Causing minor stutters in games and AnTuTu scores dropping by almost 10-15k.... Essentially reducing the Snapdragon 810 to a Snapdragon 808...What is the use of putting a Snapdragon 810 if it was gonna function like a Snapdragon 808 in the 1st place...??
  3. Kroksas
    Cupcake Dec 21, 2015
    Kroksas , Dec 21, 2015 :
    Thanks for update, but my fingerprint/home still dead. Probably hardware fault :(
  4. Akshat2793
    Ice Cream Sandwich Dec 21, 2015
  5. Gatorcracker24
    US Brand Ambassador Dec 21, 2015
  6. arthurmb
    arthurmb , Dec 21, 2015 :
    Installed the update and I think that WiFi have some bugs and color balance don't work... Can someone check this..??
  7. Akshat2793
    Akshat2793 , Dec 21, 2015 :
    Nope it's not normal. I have a couple of other phones and when they are updated, they are blazingly fast right after the update. It's just Oxygen OS I guess.
  8. DJMoore
    DJMoore , Dec 21, 2015 :
    Yes I got it tonight, however the performance has settled down after 10 minutes
  9. Akshat2793
    Go to recovery, clear cache and try again. That's the trick. It usually works.
  10. DJMoore
    Yes it took about 10 minutes after the phone booted fully and did a second update, it then settled down
  11. souravsunny
    Its does get activated but only 2 at a time...Essentially functioning like a Snapdragon 808...But yes sometimes I have seen the A57 not getting activated specially if it ever enters the battery saver mode..after that even with disabled battery saver the A57 are not up till a restart...And even then only 2 cores fore together alternately and not all 4 A57s at once causing choppiness in Real Racing 3 and decrease in AnTuTu scores after 2.1.2
  12. Akshat2793
    Alright! Let us know, what other bugs you're facing and how's the gaming performance, that is if you play games.
    DJMoore likes this.
  13. Manas Eapen
    Jelly Bean Dec 21, 2015
    Manas Eapen , Dec 21, 2015 :
    1. So that you can switch between any of the four a57 rather than stuck with 2.
    2. Adreno 430
  14. DJMoore
    I don't play games apart from letting my daughter play bubble pop occasionally
  15. souravsunny
    Why wouldn't all 4 A57 cores fire at once..?? Its a Snapdragon 810 for God's sake...If had to buy a Snapdragon 808 phone...I would have gone for that ...Isn't it..??
  16. strefo
    Eclair Dec 21, 2015
  17. dynrambo
    Eclair Dec 21, 2015
    dynrambo , Dec 21, 2015 :
    Thank you very much! I am very looking forward to the screen temperature feature! :)
  18. anupritaisno1
    KitKat Dec 21, 2015
    snapdragon 810 is NOT an octa-core processor.
    I have not heard of any device with a "TRUE" octa-core processor
    there are 8 cores. they are divided into big and little
    the little cores don't do anything when the big cores are active
    proof :- in geekbench, sd 801 scores 1000+ in single core test . given that it's true octa-core, it should score 8000+ points but it only scores 4000+ meaning its quad-core with big.little
    and more cores does not mean more performance. no app can use 8 cores
    more gigahertz does not mean more performance
    cpu performance is dependent upon it's price
    it's already confirmed that it's a hardware fault. go to the service center or request an rma.
    it's normal.
    just wait for a few minutes. charge your phone until then.
    go to boeffla
    that's not a demanding game at all.
    make sure your cpu and battery temps are normal and battery is over 30 %
    thanks. merry Christmas and happy new year
    BSA champ bicycles. I think you mean BSNL ?
  19. Manas Eapen
    Powering all four at once could result in enormous amount of heat leading to throttling. But if you can switch 2 among four and still maintain performance I would rather choose that.
  20. Akshat2793
    That's what i am saying man, it's bull s**t. I mean OnePlus 2 is not a cheap phone and this is totally unacceptable. Agreed if we buy a phone for 100$ or maybe 250$, we shouldn't set our expectations high, but oneplus 2 costs around 400 freaking $. When we are spending that much money, obviously we'll be expecting at least decent gaming performance but this is like a slap to our faces. First, spend 400$ and then spend countless hours wasting time flashing kernels and stuff, just to make our phones run smoother.
    ronyjarod likes this.
