377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. ashoktvm
    Ice Cream Sandwich Dec 21, 2015
    ashoktvm , Dec 21, 2015 :
    You must be joking
    bokdoyagee likes this.
  2. wjohnson
    Eclair Dec 21, 2015
  3. cal d
    Cupcake Dec 21, 2015
  4. Clement Louis
    Froyo Dec 21, 2015
  5. ashley37
    Froyo Dec 21, 2015
    ashley37 , Dec 21, 2015 :
    No, you just don't know what you are doing noob.
    bokdoyagee and kirahvi27 like this.
  6. danpe86
  7. .Sup
    .Sup , Dec 21, 2015 :
    When you hide the search bar - does the empty space where the bar was get utilised?
  8. keessonnema
    KitKat Dec 21, 2015
    keessonnema , Dec 21, 2015 :
    No really. I have no issues at all. 100% succes rate everytime. "knocks off"
  9. l3p1dl0
    l3p1dl0 , Dec 21, 2015 :
    No, no more space when you removed the bar.. just visual effect...
  10. Fmps1987
    Honeycomb Dec 21, 2015
    Fmps1987 , Dec 21, 2015 :
    usb otg doesn't work for me. Never work. I use one pendrive type C without oneplus adapter. Any sugestion? i have tried exfat,nfts, and fat32.
  11. vinko1950
    Eclair Dec 21, 2015
  12. .Sup
    Thanks. I already uninstalled Google App which does the same thing.
    Mrperry1 and l3p1dl0 like this.
  13. ahuja011
    ahuja011 , Dec 21, 2015 :
    Hope all the issues reported earlier are fixed,, and new ones are not introduced.
    Kudos to the dev team for their continuous efforts to make this happen. :)
    Thanks @Helen
  14. wmm
    KitKat Dec 21, 2015
    wmm , Dec 21, 2015 :
    Not for me. The attached screen shot was on Wi-Fi, and that's pretty much the maximum my account gets. Screenshot_2015-12-21-14-23-33.png
  15. Altatron
    Gingerbread Dec 21, 2015
    Altatron , Dec 21, 2015 :
    How long does the phone take to boot up? Feels like I'm stuck in a boot loop. I sorry flashed it
  16. arielr550
    Eclair Dec 21, 2015
  17. user308notfound
    user308notfound , Dec 21, 2015 :
    A lot of people are complaining about finger print scanner issues. I never had a problem with it since 2.1.2. I have 3 finger prints registered and no issue. The problem could be hardware, or your fingers are calloused enough to not register your print :D. The 2.2.0 update works fine, no wifi issues whatsoever like a lot of people are complaining here. I can't verify the bluetooth issue though. As for the CPU cores if they are throttling or working as they should, I am also not sure as I am using a custom kernel before.
    There are still features lacking like separate volume for notifications. I installed one module in xposed but it is not working properly.
    Using the phone for 7 hours, no lags whatsoever even when playing mortal kombat. LED notification lights seem to be brighter than before which is good. No major quirks as of this time. Thanks for the update OnePlus!
  18. LanzAttack
    Froyo Dec 21, 2015
  19. wmm
    KitKat Dec 21, 2015
    I haven't had any of the other bugs that I've seen reported so far in this thread, but I did run into one. I have a couple of folders of widgets on my home screen. After updating, all the widget icons in the folders were replaced by green Android figures. If I create new widgets and move them into the folders, the icons are correct, so it's not a serious problem -- I can just replace the Android figures with newly-created widgets -- but I wanted to report it (@Helen said that they monitor these threads for bug reports for a couple of weeks after each OTA).
  20. awder
    Donut Dec 21, 2015
    awder , Dec 21, 2015 :
    When I have "doubletap to wake up screen" or any gesture the screen refuses to wake up sometimes, when the phone is locked. Is this issue fixed? Can anyone confirm or experiencing the same issue?
