377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. rajrhins
    Cupcake Dec 22, 2015
    rajrhins , Dec 22, 2015 :
    I think you are the first person to receive the update in INDIA...
  2. ozikat12
    Froyo Dec 22, 2015
    ozikat12 , Dec 22, 2015 :
    Upgraded. So far it's good. At least when i hold horizontally snap a photo it will auto-rotate when i set my screen to Portrait mode.
  3. ozikat12
    Froyo Dec 22, 2015
    agoinfly likes this.
  4. gintisaurabh
    Donut Dec 22, 2015
    ajvignesh and AkileshAkil like this.
  5. majidmad
    Froyo Dec 22, 2015
  6. Jitesh Saitawadekar
    KitKat Dec 22, 2015
    Jitesh Saitawadekar , Dec 22, 2015 :
    He has flashed the OTA manually.
    rajrhins likes this.
  7. AkileshAkil
    Gingerbread Dec 22, 2015
    AkileshAkil , Dec 22, 2015 :
    He might have flashed the zip file
  8. fxguru77
    Jelly Bean Dec 22, 2015
  9. JakeSully
    JakeSully , Dec 22, 2015 :
    Can anyone here from Sweden confirm that 2.2.0 is out for Sweden? Since my oneplus 2 is still saying it's up to date :/
  10. ozikat12
    Froyo Dec 22, 2015
    You want a quick update, can download the OTA file and update from here https://forums.oneplus.net/threads/mirrors-for-official-oxygen-os-roms-and-ota-updates.387615/
    Nothing is wrong, Helen has mentioned the roll out is by batch.. You got to "wait" or do your own hack.
    I think I have a better luck than you? After upgrade I still get a steady 50Mbps on my OnePlus Two. Could it be your... Wifi? ;)
    There are many reason of slow, may be your ISP network congested, your mobile data is slow or your wifi is utilization is higher. That is my opinion.
    otto2 likes this.
  11. spencer1620
    Ice Cream Sandwich Dec 22, 2015
    spencer1620 , Dec 22, 2015 :
    I'm in the UK and have the update!
    AkileshAkil likes this.
  12. bestlands
    KitKat Dec 22, 2015
  13. haroonxiddiqui
    Eclair Dec 22, 2015
    haroonxiddiqui , Dec 22, 2015 :
    If above mentioned is the case I ll make sure it don't hit my mobile :D
  14. Yashrajsinh
    Yashrajsinh , Dec 22, 2015 :
    You'll have to wait for it. OR you could just download the .zip file and flash it manually.
  15. Fadi95
    Fadi95 , Dec 22, 2015 :
    Same here, stays connected but the speed has gone from 50mbit/s to 2-5mbit/s....
    Stephen McGuiness likes this.
  16. Fadi95
    Hi, I´m from Sweden and have the 2.2.0 update. Follow this guide: "how to get the update
    download this app https://play.google.com/store/apps/details?id=de.mobileconcepts.cyberghost&hl=en
    open it
    accept the vpn connection
    connect to any server in the netherlands
    go to system update
    click on check for update
    update will be there"
  17. majidmad
    Froyo Dec 22, 2015
    majidmad , Dec 22, 2015 :
    I recieved the update:
    Still "bt_oem_back up" error is there.
    It's very lagy and unstable, battery drain is wondering!
  18. shrubber
    shrubber , Dec 22, 2015 :
    Someone could upload stock 2.2 Kernel? I have installed boeffla but it has some problem.
  19. Crononaut
    Crononaut , Dec 22, 2015 :
    I have a Peugeot 208 Alluré, and my car-stereo rebooted as soon as I connected the OPT via BT to the stereo. BUT because of advice from a user on the XDA forum; I installed the trial version of the app "Bluetooth Phonebook". Since then I have had no problems.
    I can recommend that as a temporary fix, until Oneplus get their act together and fix it.
  20. Quexex
    Froyo Dec 22, 2015
    Quexex , Dec 22, 2015 :
    Update has been available since yesterday in the UK.
    Just updated my phone and so far everything seems fine.
    Best fix is the sensitivity of the touch screen and buttons while charging. Actually typing this while charging.
    Shutter lag is much better on the camera.
    You can also add widgets to the shelf, not sure if you could do that before though.
    Home button is more responsive.
    This is the first update I've received since getting my opt and its gone much better than either my old xperia T of Z1.
    Will post more once I've given it a solid testing.
