377
OxygenOS 2.2.0 rollout is starting
Thread Status:
Not open for further replies.
  1. rules_broken
    Froyo Dec 24, 2015
    rules_broken , Dec 24, 2015 :
    Yes you will get the by OTA.
  2. Ramesh TP
    Eclair Dec 24, 2015
    shashik008 likes this.
  3. nikhiltanwar
    Eclair Dec 24, 2015
    nikhiltanwar , Dec 24, 2015 :
    Using OPT in Bangalore, India. no update yet.
    Users who already got it.
    Does it solve this snapchat issue
    Or Touchdown issue
    Any one of these fixes will help as i have to constantly swich b/w HW keys and on screen navigation buttons based on app i using(My employer forces all android users to use Touchdown). Only disappointing issues for me as of now.
  4. Dr sushil kumar
    Eclair Dec 24, 2015
    robinghai likes this.
  5. mangelasakis
    Eclair Dec 24, 2015
  6. mohammed.shiraz
    Cupcake Dec 24, 2015
  7. SadButTrue
    Ice Cream Sandwich Dec 24, 2015
    SadButTrue , Dec 24, 2015 :
    there is NO touchdown issue you are simply using the wrong app - and this also is mentioned by nitrodesk/symantec in there release notes / goolge play app app description!
    TouchDown for Smartphones
    This version of TouchDown is specially for SmartPhone devices running Android 2.x
    you have to use the TouchDown HD app this is the only app that meet's the google android 4.x and above design rules because as of android 4 and above there is no menu button there has to be a 3 dots or swipe in menu (which the TouchDown HD app has).
    the purchased license also works for the HD version - so simply switch the app and everything works as it should!
    nikhiltanwar likes this.
  8. rgvd1987
    Gingerbread Dec 24, 2015
    rgvd1987 , Dec 24, 2015 :
    Use Thermocouple.. o_O
  9. asifsolkar
    Froyo Dec 24, 2015
    asifsolkar , Dec 24, 2015 :
    Can we have release dates for countries please ? This delay makes me feel they found some bug in this release so not released to other countries
  10. baslia
  11. wmm
    KitKat Dec 24, 2015
    wmm , Dec 24, 2015 :
    Are you using one of the USB C adapters that are known to work (the official OnePlus adapter or the Xiaomi adapter)? If you're using some other adapter, or a USB C OTG cable/adapter, it will not work. I would guess that that is a hardware issue and not something that can be resolved by a software update, but that's only speculation on my part. (OTG continues to work with 2.2.0 on my phone with the official OnePlus USB C adapter.)
  12. wmm
    KitKat Dec 24, 2015
    The flash works fine. The three special modes (Clear Image, HDR, Beauty) are incompatible with using the flash, so now under 2.2.0 the flash icon has a little slashed-circle beside it when you're in one of those modes. If you unselect the mode you're in (hit the three dots, then hit the highlighted mode indicator), you'll be in Auto mode, and the flash icon will be operable.
    Erges and Jac van Esdonk like this.
  13. wmm
    KitKat Dec 24, 2015
    No, there's still no explicit way to unmount a USB drive (although if you uncheck the "OTG storage" box in Settings/Storage, that might have the same effect).
  14. ayushbhatt27
    ayushbhatt27 , Dec 24, 2015 :
    No hydrogen is for users in China.
    For others oxygen OS will live on.
  15. _vinayak_k
    Froyo Dec 24, 2015
    _vinayak_k , Dec 24, 2015 :
    Not me.
    Get the files from here: https://goo.gl/vCwSfz
    Flash using the tutorial here: https://goo.gl/dntpxs
    No. HydrogenOS is for Chinese users, It'll probably be Oxygen OS 3.0 or similar I guess.
  16. dorjanvulaj
    dorjanvulaj , Dec 24, 2015 :
    Amazing update , better battery life, fixed the problem with camera rotation and a lot of other improvements .
  17. khaniq
    khaniq , Dec 24, 2015 :
    still now sign of update in india ...
    been four days now...
    cummon oneplus get ur act together
  18. akbasu777
    akbasu777 , Dec 24, 2015 :
    Good news. Hope this update will not invite fresh bugs/issues (already one has reported that camera crashes after installation of this update). When may we expect Android v6 (Marshmallow)?
  19. gkirko
    gkirko , Dec 24, 2015 :
    Is anybody can answer this - is this update fix issue with carrier name is not displayed correctly?
    du04lal likes this.
  20. otto2
    Photography Expert Dec 24, 2015
    otto2 , Dec 24, 2015 :
    Same with direct call widgets. new Bug. :(
    du04lal likes this.
