202
OxygenOS 2.2.0 will start roll-out on OnePlus X today
Thread Status:
Not open for further replies.
  1. rsimonek
    Cupcake Jan 31, 2016
    rsimonek , Jan 31, 2016 :
    Tried, but the problem persists.
  2. joeblues
    Gingerbread Jan 31, 2016
    joeblues , Jan 31, 2016 :
    I make a restart an then re enable the search bar. For the momento for me works. I do not know if this will work foreaver
  3. Ron1122
    Froyo Jan 31, 2016
    Ron1122 , Jan 31, 2016 :
    24 hours after installing Oxygen 2.2.0. i can't open the APP drawer or rename the App's. So now i use the NOVA LAUNCHER and it works. Does anybody have the same Problem? Wipe cache done, same problem!
  4. Ron1122
    Froyo Jan 31, 2016
    I have the same problem! So i use now the NOVA LAUNCHER and it works fine.
  5. joeblues
    Do you have the google search bar enabled?
    Ron1122 likes this.
  6. Ron1122
    Froyo Jan 31, 2016
    Ahh i See, thanks it works.
  7. Ron1122
    Froyo Jan 31, 2016
    Ok, problem solved. Searchbar enabled. It works. Thanks dude.
  8. joeblues
    May be another bug. So you can not disable the google search if you want a "normal" work...
  9. Ron1122
    Froyo Jan 31, 2016
    Yeah
  10. joeblues
  11. rsimonek
    After a reboot or turn on / off and again to be all set up, and that's the problem.
  12. ShahriarShovon
    ShahriarShovon , Jan 31, 2016 :
    phew ! it works after turning off the HDR mode ''twice'' :D
  13. ShahriarShovon
    phew ! thanks ! now it's working after turning off the HDR mode ''twice'' ! :D
  14. ShahriarShovon
  15. canada
    Donut Jan 31, 2016
    canada , Jan 31, 2016 :
    Installed the update last night and everything is smooth. Youtube playback issue is fixed. I use nova launcher and love having the google search bar at the top so no issues with that. Gaming seems to be fine... I only play Implosion and it was fine before.
  16. damianduffy
  17. damianduffy
  18. damianduffy
  19. joeblues
  20. ZBluUser
    ZBluUser , Jan 31, 2016 :
    I tried to install the new update on my device, after I downloaded it and clicked on 'Install' there was a message letting me know that the update might not install on a rooted device. And it didn't
    After some struggle to fully unroot my phone with SuperSU I managed not to get the warning message and proceeded to install the update. Again, it wouldn't let me install it.
    So maybe the root wasn't the problem, or maybe fully unrooting didn't help (wich is strange considering I did not do much with the root apart from 'boosting' once the performance using purify.)
    Maybe another cause is the fact that I changed SD cards recently, but again, I have no idea how this could affect the update
