202
OxygenOS 2.2.0 will start roll-out on OnePlus X today
Thread Status:
Not open for further replies.
  1. BenArtzz
    Cupcake Feb 2, 2016
    BenArtzz , Feb 2, 2016 :
    Where is the Google energy widget? It's necessary for me to switch between energy save and high accuracy when using location service
  2. Ron1122
    Froyo Feb 2, 2016
    Ron1122 , Feb 2, 2016 :
    This is Strange, i enable the searchbar and everything works fine. Turning on and off is no problem at all.
  3. dimei
    Donut Feb 2, 2016
    dimei , Feb 2, 2016 :
    Widgets in Shelf stop to work after some time. Please fix that :/
  4. SadButTrue
    Ice Cream Sandwich Feb 2, 2016
    SadButTrue , Feb 2, 2016 :
    i guess you have to activated the Roaming Auto-retrieve options in messenger app?
  5. SadButTrue
    slide down the status/infobar -> long press on location -> change mode into what you want
  6. rohitporoli
    Donut Feb 2, 2016
  7. youjustgotserved
    Cupcake Feb 2, 2016
    youjustgotserved , Feb 2, 2016 :
    Mm that's weird.
    And what happens when you turn off the search bar and then turn the phone off and on again? When I do this the problem occurs again.
    Greetings
  8. youjustgotserved
    Cupcake Feb 2, 2016
    To OnePlus: When I go to the files folder and for example choose my pictures, if I then press the back button because I want to go to another folder, for example my videos it closes the entire app/folder and goes back to the home screen in stead of 1 step back. Can you please fix this, it's not very usable right now? :)
  9. joeblues
    Gingerbread Feb 2, 2016
    joeblues , Feb 2, 2016 :
    I think that Oxygen, Android and inactive phone both 15% it's very high. I use the phone with display on less than 3h. On my opinion , after 3 cycles of battery and some days of use, I think 2.3.1x was much better.
  10. teous
    Cupcake Feb 2, 2016
    teous , Feb 2, 2016 :
    Hi,
    I just updated to 2.2.0 and lost all my contacts but that's not a problem... Thing is I still cant select my sd card to be used by the camera ? How do u get to that option ? In camera app or storage settings ? Please explain.
  11. m.lohse
    Froyo Feb 2, 2016
    m.lohse , Feb 2, 2016 :
    Another "pro" I found: App permissions are fixed for all Apps (like WhatsApp) :) :)
    konscht1611 likes this.
  12. naamlozenaam
    Froyo Feb 2, 2016
    naamlozenaam , Feb 2, 2016 :
    Is it only me when you bring to volume up but the circle stays at the same place, even though the volume DOES go up/down.. When i wait a few seconds and the volume bar disappears and i open it again, the circle is at the supposed place. When i want to change the volume again the circle just stays there, so it doesn't move but the sound does go up/down. I can not move this circle with my fingers.
  13. SadButTrue
    #51: open camera app -> swipe from the left display border to the right -> tap the gear -> there you are...
    JonFr, script and teous like this.
  14. harishharish
    Cupcake Feb 2, 2016
  15. ZZ_OnePlus
    Donut Feb 3, 2016
    ZZ_OnePlus , Feb 3, 2016 :
    Based on suggestions for other bugs I was able to address this issue by clearing the cache.
    Z
  16. ath.peppas
    Gingerbread Feb 3, 2016
    ath.peppas , Feb 3, 2016 :
    My battery is maximum 2.5 hours if on screen. However last days I came across this fantastic standby. However it's not consistent at all.
    m.lohse likes this.
  17. alex042795
    Eclair Feb 3, 2016
    alex042795 , Feb 3, 2016 :
    I get an average of 3 hrs and 30 mins SOT when using cellular network as my primary means of connecting to the Internet, and an average of 4 hrs and 15 mins when using wifi from 100% to 15%.
  18. PeteAU
    Cupcake Feb 3, 2016
    PeteAU , Feb 3, 2016 :
    After the update, I'm connected to both WiFi & HSPA ("H" in the titlebar). Is it expected?
  19. joeblues
    joeblues , Feb 3, 2016 :
    Are you using the "dark theme"? With dark theam I can not see android icon...
  20. dfjkl
    Froyo Feb 3, 2016
    dfjkl , Feb 3, 2016 :
    Calling b.s. on that. There is nothing to give any indication that this is a different piece of software. If it was, giving it that label is an awful, cruel joke, and I'm still discouraging anyone I know from putting that pile of crap on their phones.
