196
OxygenOS 2.2.1 rollout is starting on OnePlus 2
Thread Status:
Not open for further replies.
  1. Deepanshu Nabi
    Cupcake Mar 4, 2016
  2. anicoll01
    Donut Mar 4, 2016
    anicoll01 , Mar 4, 2016 :
    When is 6.0 going to be released.. I can only guess before this month is out since you have already said that it will be 1st Q of 2016 but a specific date would be great!
  3. loche
    Donut Mar 4, 2016
    loche , Mar 4, 2016 :
    Ok so I have installed the latest update but I have never worked with raw files... I understand that the files are saved with a. Dng extention, but I cannot seem to locate them even with a raw file viewer. Where are they being saved?
  4. Bradok
    Froyo Mar 4, 2016
    Bradok , Mar 4, 2016 :
    Desde cuando no funciona el flash?, hace unos días funcionaba. Quien toco la versión actual, metió la pata hasta el fondo. Y esta actualización va en camino de no solución ar nada. Hay que ponerse las pilas "oneplus".
    Un saludo.
  5. Bradok
    Froyo Mar 4, 2016
    Tuve el Oneplus One y ahora el Oneplus 2, pero como no mejores el sistema, me parece que tendré que abandonar y no ir al Oneplus 3.
    "Poneros las pilas".
    Un saludo.
  6. uppu9999
    Froyo Mar 4, 2016
  7. Ro.passarett
    Eclair Mar 4, 2016
  8. CoolViet93
    Cupcake Mar 4, 2016
    CoolViet93 , Mar 4, 2016 :
    Will there be an improvement on the battery life?
    Has the issue of battery drain and longer charge time been corrected?
  9. vamshichaithanya
    Eclair Mar 4, 2016
  10. pratyush1993
    Gingerbread Mar 4, 2016
  11. dendirk
    Honeycomb Mar 4, 2016
    Bradok, goncalorijo, dfjkl and 4 others like this.
  12. surya.tokas
    Donut Mar 4, 2016
    Sahilkum likes this.
  13. sajavid
    Froyo Mar 4, 2016
  14. RistoEe
    RistoEe , Mar 4, 2016 :
    Kind of confused. Is this previous version or did I miss one? This new one is patch from 11 to 12 but I think my last update was from 9 to 10. So kind of confused about those update numbers.
  15. surya.tokas
    Donut Mar 4, 2016
    surya.tokas , Mar 4, 2016 :
    Bro u r on 2.2.0 just flash this zip and your have done
    RistoEe likes this.
  16. gagne.pierreluc
    gagne.pierreluc , Mar 4, 2016 :
    Clean flashed OOS, updated to 2.2.1. Noticed that the fingerprint scanner seems to be faster, no WiFi or Bluetooth issues. Kernel still poorly optimized, the launcher is garbage, noticeable video and audio lag while running antutu benchmark. All I have to say is good job for Bluetooth and FPS. I think its time to make it open source now, let the big boys handle it.
  17. Ambardongre
    Cupcake Mar 4, 2016
    Ambardongre , Mar 4, 2016 :
    Rooted 2.2.0 and modified kernel still got update notification then at what stage OTA upgrade fails for rooted phones ?
  18. RistoEe
    Got mine rooted so have to flash full zip (09 latest I have) and few otas to update.. so that's why asking. But Thanks :)
  19. Jopa
  20. Prasannakumarbr
    Froyo Mar 4, 2016
