196
OxygenOS 2.2.1 rollout is starting on OnePlus 2
Thread Status:
Not open for further replies.
  1. prasadpatrikar
    Eclair Mar 4, 2016
    prasadpatrikar , Mar 4, 2016 :
    So,about 2.2.1..It lags 'as much as' the previous 2.2.0 :) ..No performance improvements..Please do not install this update.I would have sold my op2 if there was no cm13 from grarak.Believe me guys,you cannot return to oxygen after using cyanogenmod.First and last onplus device.Now just waiting for the official cm13 nightly with fp support..
  2. swapnilpkumar
    Gingerbread Mar 4, 2016
  3. jpswer
    Jelly Bean Mar 4, 2016
    jpswer , Mar 4, 2016 :
    It's a mighty large update in terms of MB. Interesting considering the changelog. Maybe there's more than meets the eye to this update?
  4. kaghedo
    kaghedo , Mar 4, 2016 :
    Google ID:com.gmsinstaller there you go ;)
    swapnilpkumar likes this.
  5. MafiaTechTeam
    MafiaTechTeam , Mar 4, 2016 :
    I've explained what I think causes it
  6. kaghedo
    Google ID:com.gmsinstaller there you go or do a google search simple ;)
    uppu9999 likes this.
  7. RistoEe
    Honeycomb Mar 4, 2016
    RistoEe , Mar 4, 2016 :
    Anyone managed to change DPI after this update? Tried several times with Le DPI changer with no luck :(
  8. demongokul
    Ice Cream Sandwich Mar 4, 2016
    demongokul , Mar 4, 2016 :
    Oh shit not another lollipop update. What the hell guys, haven't you seen people shouting for Marshmallow? I guess you people are not even in schedule to release MM that's why you have released this other useless update.
    ChiefIndica and gagne.pierreluc like this.
  9. vincent.manjuran
    vincent.manjuran , Mar 4, 2016 :
    Did a cache wipe in recovery right after the update!
    Didn't encounter any issues.
    Device is running pretty cool.
    Very responsive. Animation frame rate is pretty stable.
    People encountering problems with the latest update... I'd recommend them to do a cache wipe and right after that instead selecting reboot. Go back in recovery and go and shutdown. Keep the phone for charging. Charge upto 100% when it shows full.
    Detach and boot the phone. I hope no one should have any issues...
    Final option do a clean install of OOS 2.2.1 and cache wipe after clean install with 100% battery.
    Sahilkum likes this.
  10. Deactivated User
    Mar 4, 2016
  11. DarrellNR2
    Cupcake Mar 4, 2016
    DarrellNR2 , Mar 4, 2016 :
    How late is it going to roll out?
  12. pryggi
    pryggi , Mar 4, 2016 :
    Yes, did it manually in build.prop file. Worked fine. Instructions found on this forum.
  13. harshrthakkar
  14. jlasensiofi
    The Lab Reviewer - OnePlus 9 Series Mar 4, 2016
  15. RistoEe
    Any tips how to get Swiftkey working after DPI change? Got it changed via terminal (also instructions found on this forum) and now swiftkey is messed up.
  16. pryggi
    I changed dpi to 400 and have noticed no issues in SwiftKey. Maybe it does not like your dpi value?
  17. Mohamm3d_adam
    Froyo Mar 4, 2016
    Mohamm3d_adam , Mar 4, 2016 :
    Try clearing cache and data of SwiftKey.
  18. RistoEe
    I've tried 400, 390, 380 and 360. Nothing helps :(
    Tried this one too and also deleted all the updates and reinstalled. No change.
  19. Lucaniukas
    Lucaniukas , Mar 4, 2016 :
    Rolling so rolling but then it will be accessible in europe?
  20. FalconeDigital
    Eclair Mar 4, 2016
