196
OxygenOS 2.2.1 rollout is starting on OnePlus 2
Thread Status:
Not open for further replies.
  1. prabhathg
    Cupcake Mar 7, 2016
    prabhathg , Mar 7, 2016 :
    Like many others here I, too, am relieved that I can use One Plus Two as a phone again with OOS2.2.1.
    So far haven't seen any freezing issues or any lags. Apps, esp. Google Play Music, have become quick and responsive post the update.
    Marshmallow can wait if they can release it with thorough testing.
    Thank you, One Plus Two team.
  2. Pramod Magadi
    Cupcake Mar 7, 2016
    Pramod Magadi , Mar 7, 2016 :
    Nope didnt work
  3. IvanMuse
    Ice Cream Sandwich Mar 7, 2016
  4. wibul10
    Cupcake Mar 7, 2016
    wibul10 , Mar 7, 2016 :
    after update by VPN, everything seem to be better , wifi better, sound better , camera better, for me....overall is better than before update....
    tucci0 and IvanMuse like this.
  5. abkumar
    Cupcake Mar 7, 2016
  6. mearvind
    Froyo Mar 7, 2016
    mearvind , Mar 7, 2016 :
    You can trigger 'Check for update' then you might be able to upgrade/update.
    IvanMuse likes this.
  7. abkumar
    Cupcake Mar 7, 2016
    abkumar , Mar 7, 2016 :
    thanks ! but I already did that multiple times. no help :)
  8. AE1975
    Donut Mar 7, 2016
  9. marcus0089
    Froyo Mar 7, 2016
  10. IvanMuse
    IvanMuse , Mar 7, 2016 :
    Just use ExpressVPN app and set your server to India
    Wait until it connects
    Go to settings
    Check for updates
    When you get the update disconnect from Indian server
    Download the update and install
    mearvind likes this.
  11. Erajk
    Froyo Mar 7, 2016
    Erajk , Mar 7, 2016 :
    The phone is so much better with 2.2.1! Like it alot :) Well done Oxygen!
  12. Sandy_Sankalp
    Cupcake Mar 7, 2016
    Sandy_Sankalp , Mar 7, 2016 :
    I got an update for my One Plus Two on March 5th, and after the update I am not able to open my phone's 'Settings'. It opens up for a split second and crashes. Please let me know how it can be fixed.
  13. mearvind
    Froyo Mar 7, 2016
  14. rickvdsommen
    rickvdsommen , Mar 7, 2016 :
    I got the update right when i put the vpn an India
  15. Sandran
    Cupcake Mar 7, 2016
    Sandran , Mar 7, 2016 :
    Since when I updated to 2.2.0, I've started to feel my Oneplus 2 lagging very much till to the extent which I need to restart it. I'm just not satisfied with this issue. Please assist me on this. What makes my device having such problem? My device storage still showing available memory of 47.37GB which is a lot. And also, finger sensor function which makes the device wakes up with few seconds delay.
    Will the 2.2.1 will help me on my concerns which I believe none of your descriptions above would be relating to my issues.
    Please be specific on the month when we'll get the update for Marshmallow.
    A big thank you if you (Allen) could help me resolving the issues which I'm facing right now since you're an OxygenOS project manager. I need your better after-sale- service.
  16. targy82
    Donut Mar 7, 2016
    targy82 , Mar 7, 2016 :
    Hi, this means that we can download the Express VPN application and make the update ?
  17. IvanMuse
    Yes
    You just download it select free 1 day trial
    Select India as a server
    Wait for it to connect
    When it's connected go to settings, system updates and check for updates
    When you recieve the update
    Go to ExpressVPN and disconnect from Indian server
    Go to System Updates
    Download the update and install it
    Kaven and gerter89 like this.
  18. targy82
    Donut Mar 7, 2016
    thanks a lot... i am downloading...
  19. Chris Piacentini
    Froyo Mar 7, 2016
    shahvikram123 likes this.
  20. dmiller
    Froyo Mar 7, 2016
