196
OxygenOS 2.2.1 rollout is starting on OnePlus 2
Thread Status:
Not open for further replies.
  1. vegantime
    Cupcake Mar 9, 2016
    vegantime , Mar 9, 2016 :
    I still have some wifi issues with older router. exclamation point on the wifi symbol -> no internet connection.
  2. abkumar
    Cupcake Mar 9, 2016
    abkumar , Mar 9, 2016 :
    Thank you all, I got the update via OTA today. The update looks good to me, will share any issues and experience after few days usage.
  3. YasinS
    Gingerbread Mar 9, 2016
  4. JustAPhone
    Ice Cream Sandwich Mar 9, 2016
  5. Mythblaze
    Honeycomb Mar 9, 2016
  6. JustAPhone
    JustAPhone , Mar 9, 2016 :
    Be careful of this change:
    1. Improvement for roaming issues
    i think it introduced some other roaming bug.. i was charged for data roam.. which i already turn off and even off the 2nd SIM...
  7. Jojo7
    Cupcake Mar 9, 2016
    Jojo7 , Mar 9, 2016 :
    For camera, App ProCapture is beste!!!
  8. JustAPhone
    i flashed to 2.2.0 then OTA update to 2.2.1.... this will wipe away my TWRP ?
    thanks...
  9. ezekionokia
    ezekionokia , Mar 9, 2016 :
    Well I managed to install the update via the VPN trick(install express vpn, set to INDIA, check for update).
    So YES, there is a way.
    The update is great, the phone seems snappier, no more lags.
    I'm happy.
    The camera works well(immediately after updating, I FCed it, clear cache).
  10. Mythblaze
  11. Antonio.Loera96
    Antonio.Loera96 , Mar 9, 2016 :
    Thank You!!!! I needed this update so bad because everytime I opened a few applications, such as Google Play Music or dropbox, my home, back, recent, and volume buttons would be disabled. Now after the update its all good. :):):)
  12. nieldw
    Cupcake Mar 9, 2016
    nieldw , Mar 9, 2016 :
    Do you also find the Chrome is freezing quite often? All my other apps are fine.
  13. JustAPhone
    Not really.. running fine over here....
  14. giammin
    Cupcake Mar 9, 2016
    giammin , Mar 9, 2016 :
    ota updated (italy)
    restart
    wipe cache
    restart
    after a few hours opt rebooted
    another annoying fact: lost every saved wifi...
  15. IlMiSeR
    IlMiSeR , Mar 9, 2016 :
    Yes! If you flash full 2.2.0 zip you'll loose root and custom recovery
  16. SadButTrue
    SadButTrue , Mar 9, 2016 :
    root yes recovery no...
    JustAPhone likes this.
  17. 13dillion
    13dillion , Mar 9, 2016 :
    If there is a way, can you share?
    Is your phone encrypted? ... and did you update via the stock recovery? ... if yes, then how can the stock recovery read from the phones (encrypted) storage to apply the update?
  18. Thinkpad
    Eclair Mar 9, 2016
    Thinkpad , Mar 9, 2016 :
    I just received the OOS2.2.1-update OTA (Belgium), downloaded it and followed the on-screen instructions. (Didn't have to wipe the cache? it didn't ask)
    Either way, rebooted it and it all seems to work just fine :)
  19. RichRobby
    Cupcake Mar 9, 2016
    RichRobby , Mar 9, 2016 :
    I updated yesterday. Not sure if it's because of the update but my battery went from 100% to 0% and phone off overnight when it was not being used at all!
    Checking the battery app and it is currently showing 96% - 17 mins / Battery Usage isn't available.
    Fairly new to the OP2 so don't know what's going on.
  20. nhittalamani
    nhittalamani , Mar 9, 2016 :
    Not able to enable flash in camera..Is any one facing the issue.any work around..?
