196
OxygenOS 2.2.1 rollout is starting on OnePlus 2
Thread Status:
Not open for further replies.
  1. manojgengini
    Cupcake Mar 22, 2016
  2. crap80
    Eclair Mar 22, 2016
  3. AUSmatty3961
    Donut Mar 22, 2016
    AUSmatty3961 , Mar 22, 2016 :
    No I bought it from BecexTech Australia
  4. Benyew
    Froyo Mar 22, 2016
    Benyew , Mar 22, 2016 :
    Please advice what we need to do before updating our phones. The last time that I updated it through OTA, once the phone rebooted - it has an error message that say some file is missing.
  5. sajavid
    Froyo Mar 22, 2016
  6. farouqtaj
    farouqtaj , Mar 22, 2016 :
    Can you please add the following to the feature list?
    1) Enable the dual SIM software to recognise which seem was used for the called number and re-use and give the user an option to change this during call setup. This gives me flexibility to use both SIMs in an easy way.
    2) Enable the user to choose which SIM to use for each SMS text message.
    Both of the above were available on the Motorola Moto G and dual SIM support is an essential feature for many users.
  7. jyubil
    Gingerbread Mar 22, 2016
    jyubil , Mar 22, 2016 :
    You can't see raw file.. Go through file Explorer..you can see there next to your jpg file..
    kaihp likes this.
  8. buddydave
    Honeycomb Mar 22, 2016
    buddydave , Mar 22, 2016 :
    Oh right, can you install ota updates or does it fail?
  9. AUSmatty3961
    Donut Mar 22, 2016
    yea mate it fails... i even tried installing the package manually... no luck
  10. sajavid
    Froyo Mar 22, 2016
    fenixchamp likes this.
  11. Vasilachi Eugeniu
    anz563 likes this.
  12. SaltLife
    Ice Cream Sandwich Mar 22, 2016
    SaltLife , Mar 22, 2016 :
    The DEVICE may get support for it, but the CARRIER decides when they release the OS to their customers' phones. Which could be a while.
  13. sajavid
    Froyo Mar 22, 2016
    Vasilachi Eugeniu likes this.
  14. manojgengini
    manojgengini , Mar 22, 2016 :
    I can not see using file explorer and also when connected to computer. Is this is an issue with my phone? Could you please help?
  15. farouqtaj
    Ignore point 2) as I realised this afternoon that you can select which SIM to use when sending a text message.
  16. kaihp
    Jelly Bean Mar 22, 2016
  17. buddydave
  18. micdarau85
    micdarau85 , Mar 22, 2016 :
    After last update my phone does not see my usbc C memory stick
    Heelp !!
    The stick is working ... i tried it on another phone ...
    Thank you
  19. SaltLife
  20. buddykartz
    Eclair Mar 22, 2016
