196
OxygenOS 2.2.1 rollout is starting on OnePlus 2
Thread Status:
Not open for further replies.
  1. G0NZa
    Cupcake Mar 29, 2016
    G0NZa , Mar 29, 2016 :
    I'm having a problem with 2.2.1, is that the wake/power button, sometimes freeze and doesn't work, and screen stays black and can't make it work, the only solutions is restarting the phone, anyone knows why? what should i do?? the phone works great... but that is weird...
    thanks.
  2. Fuzzylumpkin
    Fuzzylumpkin , Mar 29, 2016 :
    No idea, but you can work around it if it's just the power button with double tap to wake or using the fingerprint scanner. I very rarely touch the power button.
    Hopefully the next update will sort you out.
  3. G0NZa
    no fingerprint working when that happens... is strange...
  4. pampurio97
    Gingerbread Mar 29, 2016
    pampurio97 , Mar 29, 2016 :
    I still haven't received this update (Italy)
  5. Sauravkumar12
    Gingerbread Mar 30, 2016
    Sauravkumar12 , Mar 30, 2016 :
    is it solved now? Please let me know if you need any more guidance. Its a good phone amongst the others out there.
  6. ankurvvvv
    Cupcake Mar 30, 2016
  7. hampfred
    hampfred , Mar 30, 2016 :
    Yes it will. Im guessing it will start roll out nightlies in a few weeks from official cyanogenmod with grarak as maintainer.
  8. Prakash Bulusu
    Prakash Bulusu , Mar 30, 2016 :
    Thanks @hampfred
  9. buddydave
    Honeycomb Mar 30, 2016
    buddydave , Mar 30, 2016 :
    Why don't you manually update using ota file?
  10. du04lal
  11. Shazel
    Cupcake Mar 31, 2016
  12. freddeno
    Gingerbread Mar 31, 2016
    freddeno , Mar 31, 2016 :
    After update to OOS 3 beta fingerprint is now superfast and everything running smoothly so far. Hoping for improved battery life now.
    du04lal likes this.
  13. M3LV!N
    Cupcake Apr 1, 2016
    M3LV!N , Apr 1, 2016 :
    Hi,
    My phone has started lagging and freezing after this update. Please release a fix soon. It is ruining the brilliant experience I've had so far with my OP2.
  14. ibrahimmuhsin
    Eclair Apr 1, 2016
    ibrahimmuhsin , Apr 1, 2016 :
    Hi, big fan of OPT here, but unfortunately I've had a bad experience so far.
    I bought the phone brand new and upon starting discovered it was one of those phones that had a ton of malware on it.
    So using the oxygen recovery, I reinstalled Oxygen OS 2.2.1, after wiping cache and data.
    Everything seemed fine until my phone randomly started restarting itself, also sometimes when I take a picture, the file doesn't save, no matter how many times I take the picture.
    Kindly advice, I do have a lot of hope for OnePlus.
    Thanks
  15. mp081280
    Eclair Apr 2, 2016
    mp081280 , Apr 2, 2016 :
    You were partially right. When you turn on roaming option you receive mms. But as I said this setting was on - yet mms messages did not appeared (only info that multimedia message is available).
    The root cause of my problem is sms/mms app: Textra. As it does not support dual sim, despite proper setting with roaming, I will not receive mms from second sim (on which data transfer is not on).
    Anyway I can see two options only: to wait for Textra's update when dual sim will be supported or switch to another sms/mms app.. :)
  16. CeferinoLamb
    Cupcake Apr 3, 2016
    CeferinoLamb , Apr 3, 2016 :
    Lost all faith in oxygen OS 2.n. Too unreliable. Will try 3.0 if out soon, or rom to Cyanogen.
  17. S1erra
    Eclair Apr 3, 2016
    S1erra , Apr 3, 2016 :
    Hello everyone! I was really sceptical about updating to 2.2.1 from my factory 2.1.2 since I had no isues with my phone but decided to update today anyway.
    Everything seems to be fine atm, only question I have is why dont I have options icon in camera menu? I looked up the reviews and everyone have that gear icon when swiping right in the camera app and options to enable Raw image, but I dont. Whats going on with that?
    Edit: Nevermind, after about 15 mins after update the gear appeared in the menu.
  18. gobmb
    Cupcake Apr 3, 2016
    gobmb , Apr 3, 2016 :
    My oneplus2 has the same issue and after i us all the battery and plug it to charge, it will reinstall the 2.2.1 update all over again. Why?
  19. athaes
    Cupcake Apr 3, 2016
    athaes , Apr 3, 2016 :
    Hello there,
    I have installed this update still did not fix the problem i am having.
    I bought a new unit in February and it came with a factory fault that when it disconects from wifi it never connects to 3G.
    I have to put it on aeroplane mode then turn it off again to make 3G works.
    Anybody else having the same problem?
    + Finger print scanner works better after this update.
    - Every now and then my phone goes so slow even i have nothing running in the background.
    Its so annoying that basic tasks like open phone dialer takes few seconds.
    I get so angry that i want to throw and phone out the window and go back to my good old Nokia.
    Thanks,
  20. vaishakmadhu
    Cupcake Apr 4, 2016
