114
OxygenOS 2.2.1 rollout is starting on OnePlus X
  1. jkb114
    Lollipop Apr 6, 2016
  2. eye842
  3. xarlag
    Cupcake Apr 6, 2016
  4. mradul5
    Gingerbread Apr 6, 2016
    mradul5 , Apr 6, 2016 :
    For your information.. Mr amateur.. They promised a gaming performance update nearly two months ago..
  5. OnePlusVarma
    OnePlusVarma , Apr 6, 2016 :
    Glad to see hide search bar is working fine. Shelf still has issues though! The frequent contacts don't appear immediately on shelf.
    I am noticing faster battery drain and random screenlock.
  6. nen3i
    Honeycomb Apr 6, 2016
  7. OnePlusVarma
    I was hoping for the OP Gallery too. I know there are apps to download from play store.. but I personally don't like using too many third party apps. I would think that these kind of things should be provided with the custom UI for any device.
  8. gjdass
    gjdass , Apr 6, 2016 :
    For the 10th time on this thread, and the 1000th time on these forums, it's an INCREMENTAL update for god sake.
  9. naa27
    Ice Cream Sandwich Apr 6, 2016
    naa27 , Apr 6, 2016 :
    Then get the OP gallery from the play store. It's not hard to do!
  10. DietmarDejaegher
    Cupcake Apr 6, 2016
    DietmarDejaegher , Apr 6, 2016 :
    Will the problem about the phone not accepting SD cards with large storage capacities (formatting settings: ExFat) be solved, because my oneplus X keeps telling me my SD card has 0,00 B free storage room when it actually has 128GB free
  11. Konrad_M
    Froyo Apr 6, 2016
    Konrad_M , Apr 6, 2016 :
    Paralell ;) For me works OK too. Regards :)
  12. dizzyrulez
    dizzyrulez , Apr 6, 2016 :
    Thx 4 the update but why still no better performance in low light photos and movies :(
  13. HridayK
    Cupcake Apr 6, 2016
  14. HridayK
    Cupcake Apr 6, 2016
    HridayK , Apr 6, 2016 :
    I hope it fixes the issue of getting stuck in fastboot mode for future users.
  15. IlCieco
    IlCieco , Apr 6, 2016 :
    Thanks for the update. Constant updates make us feel important to you. Hope MM wil be released relatively soon for the OPX.... :cool:
  16. Ionutz02
    Donut Apr 6, 2016
    Ionutz02 , Apr 6, 2016 :
    Does this update fix the issue with dual sim settings? On 2.2.0-x after some time my OPX changes the setting for Preferred SIM for Calls to my number 1 sim, even if I have set it to ask every time. I have tried with a fresh install and sett this option on the initial configuration menu and it does the same.
  17. dizzyrulez
    I have strange problem with program WiFi analyzer. WiFi is on but program said that I have airplane Mode on.
  18. vash_85
    Eclair Apr 6, 2016
    vash_85 , Apr 6, 2016 :
    Same issue here!
  19. Nick Adams
    Froyo Apr 6, 2016
    Nick Adams , Apr 6, 2016 :
    OK, enough is enough. I am really surprised what a bunch of computer illiterates are posting in this forum.
    One usually decides between incremental and cumulative updates/patches. This attribute only describes if the update levels up from one version to the next (incremental) or if the update includes all previous updates (cumulative).
    IT HAS NOTHING TO DO WITH THE TIMING OF WHEN WHICH PHONE (THROUGH THE IMEI) OR REGION GETS THE UPDATE.
    I am sure that this is controlled by Oneplus by configuring the OTA servers.
    DMCFRS and mauricemo like this.
  20. dizzyrulez
