114
OxygenOS 2.2.1 rollout is starting on OnePlus X
  1. mafioso16
    Cupcake Apr 5, 2016
    mafioso16 , Apr 5, 2016 :
    Oh lord, this has nothing to do with anything that should be posted here.
    Nobody asked for the story of your life.
    Whining and self-promoting is even more annoying than asking google-able questions or these "WHERE IS MM" guys.
    OT: Looking forward to the YouTube fix and security update, backing up data with Titanium Backup for a quick restore after going back to stock/unrooted.
    Deactivated User likes this.
  2. sandeepkhanal
    Cupcake Apr 5, 2016
  3. mafioso16
    Cupcake Apr 5, 2016
    Stock ROM? Root?
    Did you use OTA or OP recovery?
    If rooted, did you flash with TWRP (doesn't work)?
    If rooted, go back to Stock ROM/unrooted, use OTA or official recovery to flash the .zip and then you're good to go to re-root and modify stuff like Kernel etc.
  4. Pedrock10
    Froyo Apr 5, 2016
    Pedrock10 , Apr 5, 2016 :
    How did you install the update?
  5. Struppi
    Jelly Bean Apr 5, 2016
    Struppi , Apr 5, 2016 :
    What about the update for the oneplus one? I have the impression that Oxygen is treated preferentially. For weeks we have to wait for the Cyanogen OS 13 update, there are no reports about it. What shoud that?
  6. mafioso16
    Cupcake Apr 5, 2016
    Nobody will ever give you an answer for it. The OPO is quite old compared to the X and 2, therefor it will be updated last (probably). I'd be glad that it DOES get the update officially.
  7. alvarocotan
    Cupcake Apr 5, 2016
    alvarocotan , Apr 5, 2016 :
    Is you battery over 80%?
  8. gabeduke
    Cupcake Apr 5, 2016
    gabeduke , Apr 5, 2016 :
    I'm glad that OnePlus is working on a solution to the Google hangouts speakerphone but it is still unusable for me. When using Google hangouts video call the other user is hearing a strong echo of their own voice. It seems like the opx is not cancelling out noise from the speakers. Is there a solution to this issue? Is anyone else having this issue? Thanks
  9. bplesa
    Gingerbread Apr 5, 2016
    bplesa , Apr 5, 2016 :
    Thanks for nothing.
    I wonder if they are just taking a piss at us.
    Nobody was complaining of any of the 'fixes'.
    Disapointed.
    geffa likes this.
  10. OneMarco
    OneMarco , Apr 5, 2016 :
    Great as always...
    Is the Bluetooth car issue included?
    Is the contact issues included?
    Is marshmallow issue included?
    Thanks to a all staff
    Axevictim likes this.
  11. ImreK0
    Honeycomb Apr 5, 2016
    ImreK0 , Apr 5, 2016 :
    I guess they've fixed some of the gaming performance... at least Asphalt 8 is running pretty smooth now. Not a single lag on the tokyo map before it was lagging like crazy. Still no lowlight camera fix which is a bummer.
    praneil2050 and joeypt09 like this.
  12. JuanpaGG94
    JuanpaGG94 , Apr 5, 2016 :
    Lag on twitter videos continues... I don't know why this update size is near about 300MB and no solves the most important bugs that are still here. (Frame drop on low light conditions in camera, lag on videos...)
    What the hell are u doing OnePlus software team...???
  13. doublear
    doublear , Apr 5, 2016 :
    Simply nothing...
    Oez58 and JuanpaGG94 like this.
  14. joeypt09
    Eclair Apr 6, 2016
    joeypt09 , Apr 6, 2016 :
    Oh man kind of hoped the video issues were at least resolved, or the gaming ones. Waiting for it to be available OTA and then reporting
  15. mafioso16
    Cupcake Apr 6, 2016
    mafioso16 , Apr 6, 2016 :
    Just flash it with stock recovery, doesn't require root or anything else.
    ImreK0 likes this.
  16. Tiongkia
    Froyo Apr 6, 2016
    Tiongkia , Apr 6, 2016 :
    Anyone has this issue? After updating 2.2.1, under about, its still indicated as 2.2.0-X?
  17. mafioso16
    Cupcake Apr 6, 2016
    Did you flash Boeffla Kernel after going back to stock and then updating to 2.2.1?
    Maybe his kernel overwrites the displayed version.
  18. Tiongkia
    Froyo Apr 6, 2016
    I go back to stock (i. e. Flash full 2.2.0-X rom, flash 2.2.1 ota) then flash Kernel
  19. sandeepkhanal
    Cupcake Apr 6, 2016
  20. Ourway
    Cupcake Apr 6, 2016
    christinawright likes this.
