58
OxygenOS 3.0.1 Beta Buglist
  1. locxFIN
    KitKat May 29, 2016
    locxFIN , May 29, 2016 :
    Does it show if only one SIM is activated?
  2. Tuchkata
    Gingerbread May 29, 2016
    Tuchkata , May 29, 2016 :
    I saw the following problem. Most of the times when I unplug the charger the phone stays awake and the only solution is to reboot it. Cleaning all apps or all background apps doesn't help, it is still awake. I made dirty flash from 3.0 to 3.0.1 and wiped the cache after the flash. Does anyone have similar problems?
  3. pgomase
    pgomase , May 29, 2016 :
    No, it does not.
    Edit:
    This is strange, rebooted the device and "R" is appearing now. Let me see if it disappears on its own again.
    Edit:
    Yes, "R" disappeared on its own, Search Bar Border also missing.
    locxFIN likes this.
  4. locxFIN
    KitKat May 29, 2016
    Yes, this guy:
    Did you manage to fix it?
    Ok, I'll keep that in mind.
  5. anilkigal
    Ice Cream Sandwich May 29, 2016
    anilkigal , May 29, 2016 :
    Dirty flashed cleaned cache ,and have minimal amount of apps
  6. kvp@1+
    kvp@1+ , May 29, 2016 :
    Sorry not the service !
    The phone app...
    long press it then go to info you'll see the options there.
    piyushsoni24 likes this.
  7. Fikri
  8. Vivek Ghosh
    Eclair May 29, 2016
    Vivek Ghosh , May 29, 2016 :
    As on 29 May, 2016:
    1. Phone crashed 3 times. Out of that two times was while using Wynk App for listening to music.
    2. Vibrate on Touch Option is put inside setting option Other sounds. Put it under Sound & Notification.
    3. Camera shutter is taking time to focus for clicking pictures. Its difficult to click instantly if you want to capture something immediately.
    4. Sometimes, after unlocking the phone the Quick Unlock page is getting displayed even though i have not activated it.
  9. Vivek Ghosh
    Eclair May 29, 2016
    @locxFIN
    As on 29 May, 2016:
    locxFIN likes this.
  10. locxFIN
    KitKat May 29, 2016
    Try clean flashing then. As a rule of thumb, if you're facing issues after dirty flash, perform a clean flash. Especially if the bugs are not "known bugs" as in universal to all users on that build.
    Didn't try this myself but: The default DPI is 480 so no need to find out that first. Personally I use 400 but find your sweet spot yourself.
    Thanks for feedback, I'll have a look at what I can.
  11. pgomase
    Did u said Wynk? hell yesss. Me to observed a device crash/reboot while using Wynk on device and i was connected to bluetooth speaker.
  12. Miratek
    Honeycomb May 29, 2016
    Miratek , May 29, 2016 :
    I've to say that battery life is aweful now.
    With 3.0: 5-6 hours SOT
    With 3.0.1: 3-4 hours SOT
  13. lukode
    lukode , May 29, 2016 :
    Hello, thx, i can see but direct access doesnt appear in home page. Im root, is there any way to show it? In Lolipop it was automatic.
    Thx and best regards
  14. grk007
    grk007 , May 29, 2016 :
    Am getting random reboots twice a day.. Unrooted.. Complete stock.. OOS 3.0.1
  15. Aureatron
    Aureatron , May 29, 2016 :
    Camera photos are terribly compressed and is very bad. (2 mb - 900 kb???)
    This is not a possible bug, A definite bug.
  16. chzetzl
    chzetzl , May 29, 2016 :
    Had the same problem. Reset the app-permissions in the settings->apps-menu and it works fine.
    R_shashidhar, locxFIN and pgomase like this.
  17. locxFIN
    KitKat May 29, 2016
    It is a definite, but not necessarily a bug. It might be that they've intentionally changed the compression rate, though I don't know why.
  18. pgomase
    Alright....
    This resolved the problem :)
    Thank you for the suggestion!
  19. awesomeX1
  20. ildejc
    Froyo May 29, 2016
    ildejc , May 29, 2016 :
    When choosing a ringtone or alarm tone (in phone, clock, calendar app, etc) copied from PC to the phone, appears "unknown" when picked up from the list. In the list you can see its name correctly, but not once selected. Legacy ringtones and alarms names seem to be correctly displayed when selected.
    Gestures don't work properly. Double tap wake up and camera circle don't work. Only torch V gesture seems to work. 3.0.1 clean flash.
