58
OxygenOS 3.0.1 Beta Buglist
  1. locxFIN
    KitKat Jun 6, 2016
    locxFIN , Jun 6, 2016 :
    I've always had PIN, it worked just fine. Glad you could isolate it, makes fixing it all that much easier. At this point I think you should ask support about it.
  2. u_proprio
    Ice Cream Sandwich Jun 6, 2016
    u_proprio , Jun 6, 2016 :
    Well, I wasn't 100% convinced so i did some extra tests... It seems that the Outlook app may have some influence here (exchange email sync security policies), as right now i have PIN + fingerprint + Exchange mail via Gmail (which i don't like) and everithing seems to be working now... :oops::confused::mad:
    locxFIN likes this.
  3. Akshat2793
  4. pryggi
    pryggi , Jun 6, 2016 :
    Hi, if you still have this Google Maps link in your SMSs, could you check how it looks like now, under the official CM13 (Hangouts or Messenger), that you migrated to. Last time I was on CM13 (in March) it was also split up into multiple chunks, like on OOS3... TIA.
  5. locxFIN
    KitKat Jun 6, 2016
    Report in the 3.0.2 buglist thread.
    split up too. I guess it's an Android 6.0 thing then?
  6. pryggi
    Thanks for checking! Then there is no incentive for me to move to the official CM13 yet.
    Maybe it is an AOSP MM issue, as Sony Xperia Z had it too, but I have Chroma ROM with Android 6.0.1 on my old Nexus 4 and there the links work fine and are not split up.
  7. locxFIN
    KitKat Jun 6, 2016
    Can you ask the dev if he did something special in this regard?
  8. somil_13
    Cupcake Jun 10, 2016
    somil_13 , Jun 10, 2016 :
    OS 3.0.2 is awesome... its make my OP2 even more awesome! snappy...
  9. JoshBaldassarre
    Ice Cream Sandwich Jun 10, 2016
    JoshBaldassarre , Jun 10, 2016 :
    I know it is, but battery life for me was not good, 3-3.5 hours sot... As I said, "For me". I am trying out Paranoid Android 6.0, seems great on paper and video
  10. DeepeshVerma
    Cupcake Jun 19, 2016
    DeepeshVerma , Jun 19, 2016 :
    I amgetting a weird problem similar as Purnima mentioned, When I m using Headphones with OPT and watching a Video(Mx Player) and tried to increase volume after 11point of volume the phone get locked and asked to draw my pattern to unlock the device asking- "Pattern Required for additional Security".
    I tried following :
    1. Remove the screen lock to NONE.
    2. Downloaded a screen lock app and tried disabling the device administrator.
    But no luck with that, help me in this, as I am not able to watch movies with increased volume.
    Any help?
  11. mortamir
    Cupcake Sep 22, 2016
    mortamir , Sep 22, 2016 :
  12. mortamir
    I'm having the same issue with one plus three and h7, can't pair it to the phone.
    Can anybody help?
