58
OxygenOS 3.0.1 Beta Buglist
  1. piyushsoni24
    Gingerbread May 23, 2016
    piyushsoni24 , May 23, 2016 :
    What should i do now to work that as before.
    What's convolver?
  2. marinobiagio
    KitKat May 23, 2016
    marinobiagio , May 23, 2016 :
    So it isn't a bug?
    So I can't report a "minor" bug?
    For me you are totally wrong sorry bro!
    locxFIN likes this.
  3. buddydave
    Honeycomb May 24, 2016
    buddydave , May 24, 2016 :
    Yeah it turns the status bar orange. It reduces cpu frequency to 700mhz so you don't have heat from the cpu to worry about.
    chahid5 likes this.
  4. joesweeney413
    Jelly Bean May 24, 2016
    joesweeney413 , May 24, 2016 :
    It's more of a theme issue than bug. I'm just saying here is 100x more important stuff to worry about than a border
    otto2 likes this.
  5. luissalvador90
    luissalvador90 , May 24, 2016 :
    You should install Google Now Launcher. Don't have dark theme option, but speed is better and don't have lag. ;)
  6. Dunnow
    The Lab - OnePlus 6 Reviewer May 24, 2016
    Dunnow , May 24, 2016 :
    hey look! Trusted face has FINALLY come back. Oh wait, it does not work.
  7. ThePortalZero
    Froyo May 24, 2016
    ThePortalZero , May 24, 2016 :
    Bug: in the notification drawer, tapping on the clock redirects to Time and date settings instead of opening the alarms.
  8. luissalvador90
    "Isn't a bug, it's a feature" :D
    Actually, makes more sense that clock redirect to time/date settings and alarm clock to alarms... but, if you don't have any alarm set on, you will don't have any shortcut to click in... :(
    ThePortalZero likes this.
  9. raman1196
    Cupcake May 24, 2016
  10. jeepers007
    Donut May 24, 2016
    jeepers007 , May 24, 2016 :
    I can confirm this as well. Other camera apps seem to be fine though.
    locxFIN likes this.
  11. AndyChanHK
    AndyChanHK , May 24, 2016 :
    My USB Dac is not workong in oos3.0.1, whick worked perfectly in oos 3.0.0
    the usb dac even cannot detected by onkyo hf player which could be found in oos2.2.0
    anyone tried the USB otg function yet? i think it may be missing something
    locxFIN likes this.
  12. aakaym
    Donut May 24, 2016
    aakaym , May 24, 2016 :
    Setting different ringtone for each sim is missing after the update to OxygenOs 3.
    In the previous version it was under contacts click on 3 dots and go to account details you can set different ringtone for each sim.
    locxFIN likes this.
  13. varunsood
    Froyo May 24, 2016
    varunsood , May 24, 2016 :
    New gesture feature added in new built like samsung phones u just need to open contact and place it over ur ear to place a call automatically
    kpmak, lalit.kultham and locxFIN like this.
  14. varunsood
    Froyo May 24, 2016
    Mine is now fast as hell i wont ask u that did u clear the cache after the update coz u have done it i assume
  15. OliverP
    OliverP , May 24, 2016 :
    When I receive a SIP call using the feature of the builtin Dialer, neither the mic nor the speaker actually work.
    Additionally, there's no practical way to actually /make/ a SIP call from the dialler.
    m1tch3m likes this.
  16. victuringan
  17. Anzik
    Ice Cream Sandwich May 24, 2016
    Anzik , May 24, 2016 :
    Volume slider after some time moves with freezes/lags, same problem as was on 3.0..
  18. Anzik
    Android System still on first place in the battery statistics..
  19. aj7400
    aj7400 , May 24, 2016 :
    I can confirm the wifi speed bug ...
    Sometimes the wifi just doesnt send or receive data and is stuck for few seconds and then works back fine.
    locxFIN likes this.
  20. SaltLife
    SaltLife , May 24, 2016 :
    Mine too
