58
OxygenOS 3.0.1 Beta Buglist
  1. pankajtidke
    Donut May 24, 2016
    pankajtidke , May 24, 2016 :
    Hi All,
    I am using the 3.0.1 however there are no major bugs..if u are facing please do the clean flash
    locxFIN likes this.
  2. josefn24
    Jelly Bean May 24, 2016
    josefn24 , May 24, 2016 :
    No oxygen here so far either have phone running in this build for 10 hours or more now.
    sahil_starrh and locxFIN like this.
  3. chzetzl
    Honeycomb May 24, 2016
    chzetzl , May 24, 2016 :
    Luc
    Lucky one :)
  4. itsmesdn
    itsmesdn , May 24, 2016 :
    I tapped on the watsapp notification and the app opened for me.
    locxFIN likes this.
  5. taruncool01
    Froyo May 24, 2016
    taruncool01 , May 24, 2016 :
    Well this is for anyone and everyone, please take it very seriously and pass this message to everyone you could in the community.
    There is one major bug in oos 3.0.0/MM beta build, I don't know if it continues in OOS 3.0.1 beta build as well.
    The FPS is damn sensitive, any contact with it makes it start reading the touched part. Even when put in pocket a little touch of fabric or thai movement make it starts reading what it had touched. This is making phone always Warm and a high battery drainage.
    And the most dangerous thing is that it is making fps sensor /home button dead permanently. I already had My home button dead once and got it replaced with oneplus service centre.
    Using it again with same rom will make it dead again. I am scared what happens when warranty runs out and this isnt fixed even in official MM build!!
    Please some senior Oneplus Company member comment on this.
  6. @ds
    @ds , May 24, 2016 :
    Did that :)
  7. abhinav49
    abhinav49 , May 24, 2016 :
    I agree +1
  8. JoshBaldassarre
    Ice Cream Sandwich May 24, 2016
    JoshBaldassarre , May 24, 2016 :
    Yep, that's a bug
    marinobiagio likes this.
  9. locxFIN
    KitKat May 24, 2016
    locxFIN , May 24, 2016 :
    A bug is a bug, always worth pointing out. Also the quick PIN accept is not a bug but new AOSP security standard.
    So it was working correctly at one point, then it can't be a bug in the build.
    Worked fine in the previous beta for me, still need to try it in this one.
    @ds likes this.
  10. locxFIN
    KitKat May 24, 2016
    Indeed, setting it up goes as planned but can't unlock it with it.
    Yeah it seems to be a conscious design choice rather than a bug.
    Which volume?
    Don't have that, can you elaborate?
    That's expected when it's so shortly after flashing.
  11. piyushsoni24
    Gingerbread May 24, 2016
    piyushsoni24 , May 24, 2016 :
    So, what should i do now to make it work as before?
  12. locxFIN
    KitKat May 24, 2016
    We are counting the minor bugs here too ;)
    Not a problem I have. It sometimes tries to read my palm when I rest my hand on the phone, which is understandable, but never my clothes.
    Hard to say since I don't know what you've done. Reset the settings, try with V4A installed but not yet activated, reinstall everything, reinstall OS. There's some things you can try.
  13. piyushsoni24
    I clean flashed oxygen os 3.0.1 yesterday. Then it should work fine but it is no working. Please help me making my Viper4android work fine
  14. hmuny99
  15. Santi_SAZ
    Santi_SAZ , May 24, 2016 :
    Bug?
    Not appears name of SIM card when you are introducing the PIN number.
    I can't rename the carrier in SIM cards option
  16. marinobiagio
    KitKat May 24, 2016
    marinobiagio , May 24, 2016 :
    On 3.0 hotspot worked fine for me.. I'll try later on 3.0.1 and I'll post results :)
    AKA bug XD
    I like GEL but stock launcher is really improved since 3.0 and shelf is very use full for me! I prefer use OnePlus launcher for now the blinking search bar is not a big problem for me :)
  17. Dunnow
    The Lab - OnePlus 6 Reviewer May 24, 2016
    Dunnow , May 24, 2016 :
    In my case not even so. I dont even see my face on the recognition screen... and suddently also said "improve facial match" instead of setting it up... was it still in memory even tho it was gone for the past 2 or 3 updates? Wtf...
  18. Rushabh Gohel
  19. locxFIN
    KitKat May 24, 2016
    Well that's weird. I never tried it until now but setup is easy and works just fine. Unlocking on the other hand...
    Maybe read the first post? I updated it like 12 hours ago.
  20. Royalslash
    Donut May 24, 2016
