364
OxygenOS 3.0.2 (MM) OTA update will start soon on OnePlus 2
Thread Status:
Not open for further replies.
  1. LHammond99
    Cupcake Jun 8, 2016
    LHammond99 , Jun 8, 2016 :
    Yes I have network signal, just no internet. I will check the APN and preferred network type again and see if they make a difference, but looks like I might have to reset!
    SoniaB likes this.
  2. dabendra
    Gingerbread Jun 8, 2016
    dabendra , Jun 8, 2016 :
    Go through the forums properly before making irresponsible statements. There are problems when u are doing major updates like from kitkat to lollipop or from lollipop to marshmallow, nexus phones experience it too. Done blame oneplus for that.
    Well you can say that they could have given a warning about the disabled google apps since the start but other than that you cant blame them.
  3. venu500
    Donut Jun 8, 2016
    venu500 , Jun 8, 2016 :
    Guys, no ringtone after upgrade. It neither vibrates too....... Tried all (Rebooted. Rebooted with silent and then changed the slider to "all notifications". Booted to Rom, but found Chinese)........... Any others?
    Seriously oneplus, this is definitely not the way to roll out an upgrade.......... Totally disappointed.
  4. realfruitloop
    Donut Jun 8, 2016
    realfruitloop , Jun 8, 2016 :
    Yeah I'm having lots of issues with the notification settings and switch. Doesn't seem to be working full and differs from app to app. Disappointing.
    stevenchow90 likes this.
  5. Yashasvi Shah
    Naveen 326 likes this.
  6. hsaxena11
    Cupcake Jun 8, 2016
    hsaxena11 , Jun 8, 2016 :
    Received OTA update in India not sure I'll go ahead for it as there are mix reviews. CN anyone please suggest?
  7. Timo gustafsson
    Froyo Jun 8, 2016
    Timo gustafsson , Jun 8, 2016 :
    Were can i adjust the vibrating or disable when you press home and the other 2 buttons, after the update they vibrate 2 times quikly and i find it quite annoying , thanks
    jiancong likes this.
  8. marinobiagio
    KitKat Jun 8, 2016
    marinobiagio , Jun 8, 2016 :
    Totally agree!
    Anyway after some days and some battery cicle 3.0.2 works great!
    Smooth like butter no lags and freeze (2.2.1 was very frustrating), no issue (bt, lte, gps works great!) No bugs for me.. great job @Helen and Oxygen OS team.. I hope this is only the START of your journey!
  9. sncalaska
    sncalaska , Jun 8, 2016 :
    Got MM update in alaska, usa this a.m.. working fine so far. my 1+2 is not rooted. glad to finally have update!
  10. Thiyagarajan Ranganathan
    Cupcake Jun 8, 2016
    Thiyagarajan Ranganathan , Jun 8, 2016 :
    any answers?
  11. venu500
    Donut Jun 8, 2016
    Got one workaround.Not sure if I have to stick on to it, this way, but for the interest of others, who have the same issue,
    1. Slide the notification slider to "Priority notifications" (Left side slider to the middle).
    2. Increase your volume by one using the volume rocker on the right.
    3. Click on the options icon (wheel).
    4. Go to "Calls" and change to "From anyone".
    its persistent across reboots...
    Mere purpose of the slider stages is defied but, I cannot leave my phone dumb.......
    Nash007 likes this.
  12. Sharad Ranjan
    Froyo Jun 8, 2016
    Sharad Ranjan , Jun 8, 2016 :
    Downloaded, installed and now it's updated without any issue.
    No cache memory nor any other issue while updating.
    Only thing is that ensure that all the Google apps are enabled.
  13. realfruitloop
    Donut Jun 8, 2016
    I'm more concerned that my phone no longer vibrates whenever I receive an email. I used to have a shorter vibrate for that so that I could differentiate it from my other notifications.
  14. lee_82
    Eclair Jun 8, 2016
    lee_82 , Jun 8, 2016 :
    Hi guys. Is there variation in OTA's file size from different regions?
    Noticed some people mention 1.01GB but mine was about 356MB
    FYI. I live in Denmark.
  15. venu500
    Donut Jun 8, 2016
    Check your ringtone.
  16. toonvranken
    Cupcake Jun 8, 2016
  17. Sahilk0369
    Honeycomb Jun 8, 2016
    Sahilk0369 , Jun 8, 2016 :
    Ota from 2.2.1 is 1.1GB
    Ota from 3.0 is around 356MB
    Ota from 3.0.1 is around 100MB+
    kaihp likes this.
  18. klutch
    Donut Jun 8, 2016
    klutch , Jun 8, 2016 :
    Hi there, can i check if wiping data and cache will lose everything on the phone? I got stuck at boot loop and tried wiping cache and its not helping.
  19. Harsh Rathore
    Donut Jun 8, 2016
  20. lee_82
    Eclair Jun 8, 2016
    Thanks man.
