364
OxygenOS 3.0.2 (MM) OTA update will start soon on OnePlus 2
Thread Status:
Not open for further replies.
  1. pranay.jain.90
    Eclair Jun 8, 2016
    pranay.jain.90 , Jun 8, 2016 :
    Finally!! Few quick issues. Someone pls help!
    1. Phone ringtone is not working even after setting to some ringtone. I am not able to hear anything when I get calls. :(
    2. It is asking for pin unlock even after I use my fingerprint to unlock. :confused:
    Crazy things happening to basic usage. :rolleyes:
  2. prematonline
    Cupcake Jun 8, 2016
    prematonline , Jun 8, 2016 :
    Hi..
    I got the update now in USA and looks fine.
    But my Menu view has been changed as list type in Vertical view.
    Any way to change it back to old view mode.
    Thanks
    dmg9 and realfruitloop like this.
  3. hrushis
    Froyo Jun 8, 2016
  4. realfruitloop
    Donut Jun 8, 2016
    realfruitloop , Jun 8, 2016 :
    On the plus side, the new fingerprint scanner is amazingly fast. I used to have real problems with it before. Excellent job with that One Plus.
  5. tiboss5
    Cupcake Jun 8, 2016
    tiboss5 , Jun 8, 2016 :
    I have downloaded the newest update but my phone keeps restarting?
  6. realfruitloop
    Donut Jun 8, 2016
    Been trying to find a solution to this all day.
  7. Dominik316
    Donut Jun 8, 2016
    Dominik316 , Jun 8, 2016 :
    Just got the Update per OTA (not VPN) in Austria. I had no Problems with the Installation and it seems faster than before...:)
  8. Sahilk0369
    Honeycomb Jun 8, 2016
    Sahilk0369 , Jun 8, 2016 :
    For all those who are having issue with ringtone and vibration follow the steps below :
    1.Clear cache for dialer app
    2.wipe phone cache and restart
    3.Also check that in settings a ringtone is selected or not
    4.Also see that the slider is in the bottom most position
    5.Check that ringer volume is increased/ phone not on silent/vibrate
    For issue with the fingerprint it is asking for your pin beacuse :
    firstly after every reboot on the first unlock you have to give your password/pin/pattern
    secondly did does not recognize your fingerprints as the API for the sensor has changed and it require you to register your fingerprints again.
  9. Mika Nikulainen
    Cupcake Jun 8, 2016
    Mika Nikulainen , Jun 8, 2016 :
  10. Sahilk0369
    is this happening every time you pull down the notification tray ?
  11. kaihp
    Jelly Bean Jun 8, 2016
    kaihp , Jun 8, 2016 :
    Credit due where credit is due: Your appreciations should go to Google, they made the clusterf*** you're in. OnePlus cannot avoid but inherit it.
  12. prematonline
    Cupcake Jun 8, 2016
    Ok.. Me too.. Lets see if we get any info
  13. yuganathan
    Gingerbread Jun 8, 2016
  14. dhruvgupta21
    dhruvgupta21 , Jun 8, 2016 :
    Thanks for the suggestion man. I like haptic feedback, I need it. But I used to like it more on the previous version. I would prefer the current haptic feedback rather than none at all.
    Sahilkum likes this.
  15. ekikoo
    Cupcake Jun 8, 2016
    ihopetwo likes this.
  16. metalmore
    Cupcake Jun 8, 2016
    metalmore , Jun 8, 2016 :
    i downloaded via OTA..
    installed,
    reboot
    stuck boot on logo
    reboot into recovery, wipe full, reboot, same problem...
    reboot into recovery, install from sd, install OTA, re-installing, same stuck, re-wipe of full, same stuck
    reboot into recovery, install from usb, sideload, not recognized
    some one can help me??
    thanks!
  17. MasterMadman
    Cupcake Jun 8, 2016
    MasterMadman , Jun 8, 2016 :
    I have recently updated my phone with OxygenOS 3.0.2 (MM) OTA update and I am not getting ringtone on receiving calls
  18. pranay.jain.90
    Eclair Jun 8, 2016
    Thanks !! But where can I find dialer app? I can't see anything like that in apps section. Even clearing phone cache and restarting , i am facing same issue. For fingerprint everytime it is asking pin unlock even after first instance.
  19. dert882
    Cupcake Jun 8, 2016
  20. Sahilk0369
    For all those who are having issue without ringtone and vibration follow the steps below :
