364
OxygenOS 3.0.2 (MM) OTA update will start soon on OnePlus 2
Thread Status:
Not open for further replies.
  1. ryan.mendonca27
    Donut Jun 9, 2016
    ryan.mendonca27 , Jun 9, 2016 :
    Finally, I got the OTA update my Oneplus 2 now runs on OS 3.0.3 and it is just so awesome. Having an hands on to check the improvements and by the feel I can say... The fingerprint sensor has just improved and is at its best
  2. ashwinjain
    Cupcake Jun 9, 2016
    ashwinjain , Jun 9, 2016 :
    OTA update is getting stuck at 87%. Tried restarting, changing the internet connections but nothing helps.. anyone else facing a similar issue..
  3. BluMox
    Eclair Jun 9, 2016
    BluMox , Jun 9, 2016 :
    Finally the OTA! Cant wait for the download to end *.* <3 LOVE YA ONEPLUS
  4. RenevSeeters
    Eclair Jun 9, 2016
    RenevSeeters , Jun 9, 2016 :
    For those of you who are still experiencing problems with booting up the Phone.
    Here is what i did:
    Power off the phone.
    Hold the volume button down and press the power button,
    hold down both together until you see the screen power on
    and the "powered by android logo", Then release both buttons.
    Select English as your language.
    Select Wipe Data and Cache
    Select Wipe Data , confirm with Yes
    Select Done, confirm with Yes
    Select Wipe Cache, confirm with Yes
    Select Reboot.
    Phone will now boot normally, you WILL lose your saved apps and settings,
    but you will NOT lose your files, photo's or music.
    Unless you have a backup of your phone software
    prior to the update Install, this is the only way that you can
    reinstate the phone to a normal functioning condition.
    In my case this worked and i did NOT lose my pictures, they were loaded back in after completing the introduction setup like PIN password and Google account settings.
    Also be aware that this does delete every app you have downloaded and every setting that was set on the device by you.
    And finally.. this worked for me, but unfortunattely there is no guarantee this will work for everyone else.
    kaihp and Sahilkum like this.
  5. amarnroy
    Cupcake Jun 9, 2016
    amarnroy , Jun 9, 2016 :
    Request your suggestion or help on this issue. Yesterday I had updated my OP2 to Marshmallow OxygenOS-3.0.2 version, but ever since that LED Notification for apps is not working except while charging. Tried rebooting the device, and wipe cache:confused:, but that didn't help. As of now everything else is working fine. Please let me know what can be done to rectify LED Notification issue or if anyone else is having the same issue . Thanks
  6. jaitradixit
    Cupcake Jun 9, 2016
    jaitradixit , Jun 9, 2016 :
    I got the 3.0.2 update and I downloaded it. But when I try to install it says 'there was a problem installing the update. please try again later' it gives this message every time. I am currently on 3.0 beta. Anyone else having the same problem?
    digadefy likes this.
  7. Arnis C.
    Cupcake Jun 9, 2016
    Arnis C. , Jun 9, 2016 :
    Hi All,
    I'm trying to understand if it is worth doing the upgrade to OS3.0.2 now. Reading this thread so far I see complains about after upgrade problems like:
    - battery life
    - wifi switch to 4g and back problems (or smth like that)
    - ringtone issue for incoming calls (workaround to slide notification slider all the way up and down after each reboot)
    - audio quality without Maxx Audio Tuner
    The most important problems for me is battery life and wifi/4g.
    I hope that battery life issue can be related to some specific application. So OP2 owners that successfully upgraded your OP2s to OS3.0.2 and who have no issue with battery life and wifi/4g, could you write here about it? :)
    I would very appreciate it, just need to make a decision wait or go for OS3.0.2.
  8. uday344
    Gingerbread Jun 9, 2016
    uday344 , Jun 9, 2016 :
    Finally satisfied with update, major changes are done and phone is now superfast
    Blazing Fast 100% accurate fingerprint sensor.
    Camera app is fast and bug free as for now.
    Autofocus is good from previous.
    Battery yet to test.
    else look awesome
    Thank you OnePlus for update much appreciated :)
    danduf1981 likes this.
  9. kbnagi
    Cupcake Jun 9, 2016
    kbnagi , Jun 9, 2016 :
    When you press the volume up/down key, next to the volume adjust button, there is a down arrow which shows more options for Ringtone and Alarms. Just increase the volume settings there.
  10. vir.pitaliya
    Cupcake Jun 9, 2016
  11. aironeous
    Cupcake Jun 9, 2016
    ihopetwo likes this.
  12. Sayan Roy
    dsorensen likes this.
  13. Sandeep Poddar
    Honeycomb Jun 9, 2016
    Sandeep Poddar , Jun 9, 2016 :
    no..its for oneplus 2 only.. if u want u have to flash it.. go through the forums for d procedures
    kaihp likes this.
  14. prashanthsun9
    Cupcake Jun 9, 2016
    prashanthsun9 , Jun 9, 2016 :
    After Upgrade my phone charging is worst, it shows, it will take 18 hours to fully charge my mobile from 18%, i am using oneplus2 without any extra plugins
  15. alexpandy
    Cupcake Jun 9, 2016
    alexpandy , Jun 9, 2016 :
    Hi i too had the same issue but i used Alert slider(in left sideof device) once by making it to None and again to All option.
  16. mylinuxz
    Cupcake Jun 9, 2016
    mylinuxz , Jun 9, 2016 :
    I am now able to see the updates. Thank you for your reply :)
  17. despiriado89
    Donut Jun 9, 2016
    despiriado89 , Jun 9, 2016 :
    I've updated OS 3.0.2 thru VPN and the phone is working fine till now with no issues.
    Kudos to those who posted about VPN. :) :)
  18. devil_boy
    Donut Jun 9, 2016
    devil_boy , Jun 9, 2016 :
    Got the update OOS 3.
    Wooosshhhhh...not at all disappointed.
    Superfast and smooth as hell.
    Battery after 12 hours of usage after update is good enough for me.
    Loving it.
    Thanks #OnePlus
    Thanks @Helen
    kaihp likes this.
  19. raj9779
    raj9779 , Jun 9, 2016 :
    Yes 3.0.2 has ringtone volume problem. Once volume slider is taken to priority notification and change back to normal all notification... its volume remain zero. so it only vibrates even in all notication.
  20. Jabamiah
    Froyo Jun 9, 2016
    Jabamiah , Jun 9, 2016 :
    OTA update finally received (from 2.2.1 stock, in Belgium), waw.
    Everything went fine, and the phone seems way faster..
    Battery test not done yet.
    Thank you OP !
