364
OxygenOS 3.0.2 (MM) OTA update will start soon on OnePlus 2
Thread Status:
Not open for further replies.
  1. bhavinjbhatt
    Cupcake Jun 9, 2016
    bhavinjbhatt , Jun 9, 2016 :
    Hi SoniaB,
    I downloaded the zip from the link you provided and booted into recovery, wiped data and cache, then using adb sideload, installed the software...from USB...but still getting the same issue, the phone boots to marshmallow, where you have to choose your language, English UK or USA ...but at that point the phone looses touch screen ability or something, as much as I try, the screen respond to my fingers touch...tried using a stylus, just in case my fingers were playing up....
    Any other suggestions ?
    Thanks
    Bhav
  2. Karthick V
    Froyo Jun 9, 2016
    Karthick V , Jun 9, 2016 :
    No worries, this doesn't modifies your photos or any of the personal files.
  3. SoniaB
    Nougat Head Moderator Jun 9, 2016
    SoniaB , Jun 9, 2016 :
    You are a smart cookie - you can work it out.
    What goes on in PM, stays in PM ;):p
  4. idlefun
    Cupcake Jun 9, 2016
    idlefun , Jun 9, 2016 :
    Hi Sonia, I have the bootloop issue and wiping data and cache did not resolve. Do you have another solution?
    Thanks.
  5. CrazyNevada
    Cupcake Jun 9, 2016
    CrazyNevada , Jun 9, 2016 :
    I got the update notification and when the download reaches 100%, it starts verifying the file. After some time this message comes up:
    I also tried updating my phone with the .zip, but I get the "installation failed" message.
  6. harsh127
    Cupcake Jun 9, 2016
    harsh127 , Jun 9, 2016 :
    Thanks a ton! This worked like a charm.
    Karthick V likes this.
  7. SoniaB
    Your original post said that you wanted to do a clean install. I gave you the link to the zip.
    Why are you trying to sideload it? Clean install would mean flashing via TWRP.
    @Naman Bhalla ... your thoughts
  8. SoniaB
    That would be adb sideload. check your PM
  9. mjpsammon
    Honeycomb Jun 9, 2016
    mjpsammon , Jun 9, 2016 :
    @SoniaB What are the EXACT steps for clearing cache when installing the OTA? Do you have to clear cache before AND after OTA? Thanks!
  10. Naman Bhalla
    Recognized developer Recognized Developer Jun 9, 2016
    Naman Bhalla , Jun 9, 2016 :
    Is he able to use touch in recovery or anywhere else ?
  11. Jitesh Saitawadekar
    KitKat Jun 9, 2016
    Jitesh Saitawadekar , Jun 9, 2016 :
    "Dumb guy innocently thinking" :anguished: what goes on PM ??? :cry:
    SoniaB likes this.
  12. MortenSThomsen
    Froyo Jun 9, 2016
    MortenSThomsen , Jun 9, 2016 :
    My OPT won't start, after i updated it?
    It updated as usual, but stood still at "Opening your apps" for 1 1/2 hours, so i decided to restart the device. Not it's standing still at the first screen with the OnePlus Logo, and "Powered by android"? How can i make it work again?!
    EDIT: It's fixed, and my phone works again! :D
    DeHeerKelderhuis likes this.
  13. ballbin
    Cupcake Jun 9, 2016
    ballbin , Jun 9, 2016 :
    I started updating around 1,5 hours ago, but for some reason the updating won't get finished? My Op2 just flips between rebooting and the black screen with the red dot and the white dots spinning around it. What can I do?
  14. SoniaB
    I always have done out of habit with OTA on the OPO. With the OP2, I have manually flashed
    Power off phone.
    Boot into recovery
    English
    Wipe cache and data
    wipe cache
    reboot
    Install OTA
  15. pgalatage
    Cupcake Jun 9, 2016
    pgalatage , Jun 9, 2016 :
    I did upgrade and suddenly after reboot my finger print scanner is not working. Home button is also not working. I did reset hard reboot, by pressing down power button. It works but again after lock unlock it says fingerprint hardware is not available. Please help.
  16. SoniaB
    no idea
  17. rchaudry
    Eclair Jun 9, 2016
    rchaudry , Jun 9, 2016 :
    Is it me or did they remove the Wifi calling option? It was present before but didnt work. So now they removed it completely?
    THis product... :rolleyes:
  18. Bibin Alexander
    Froyo Jun 9, 2016
  19. Naman Bhalla
    Naughtyyyy
    If he isn't able to use though in recovery even, it is the time for SVC
    kaihp and SoniaB like this.
  20. Karthick V
    Froyo Jun 9, 2016
    So someone say what happens, if I completely remove the google apps using Titanium backup or some other root uninstall apps? Will that too result in bootloop.
    ihopetwo likes this.
