364
OxygenOS 3.0.2 (MM) OTA update will start soon on OnePlus 2
Thread Status:
Not open for further replies.
  1. Wildvine Gingerbread Aug 14, 2016
    Wildvine, Aug 14, 2016 :
    Hi @Helen @Carl , I am a OP2 (stated 2016 flagship killer) user and also have a OP3. Already got the 4th update after received my OP3. The same (frequent updates) was happened during last year when OP2 was the recent flagship from OnePlus' end. But after that it took 7/8 months to get the marshmallow on OP2 as OnePlus was busy with OP3. Will you guys please let us know when the existing bugs will be solved for OP2 and we will get the OTA for that. Please make my old OP2 better as best is not suitable for.
    katariyaketak, Ach94 and derveni like this.
  2. devashish saroha Eclair Aug 15, 2016
    devashish saroha, Aug 15, 2016 :
    If you guys want support from oneplus then go to carl's twitter account and complain there
    Use hashtag #oneplus #oneplus2 #oneplus3 #neversettle
    Do this so that new oneplus3 buyers will get to know what these guys did with oneplus2
    And this is only way they will provide us update ASAP
    derveni, kpmak and Impulse37 like this.
  3. Virendrathakrar Froyo Aug 22, 2016
    Virendrathakrar, Aug 22, 2016 :
    Hi,
    Recently I am facing very weird issue with my OP2. Mic has stopped working. If I do clear cache or reset phone then MIC will work for couple of calls. In that too it will not respond properly. after that it stops working.
    I have check with customer care but they said its hardware issue so they asked to visit service center. But if its hardware issue then how come its started working with clear cache or resetting OP2?
    anyone have any idea?
  4. prp24 Donut Aug 23, 2016
    prp24, Aug 23, 2016 :
    Hi everybody, I updated my OP2 to 3.0.2 the moment it came out and I have been very happy with its performance. However for the past week I have been facing issues with my battery. The charging speed is very slow. I take 4-5 hours for my phone to fully charge as compared to the 2+ hours it was taking when I first updated my phone to 3.0.2. I'm using the stock cable and adapter and I don't use my phone while charging it. Any help will be appreciated. Thank you very much.
  5. diwakarmj Honeycomb Aug 23, 2016
    diwakarmj, Aug 23, 2016 :
    Since mm update I'm facing following issues
    1.Battery drain by Android system, Android OS and phone idle
    2.audio lag in YouTube videos
    3.volume level problem. It's not working efficiently, it's low when volume bar is below 2-3 steps from top.
    4.brightness level problem
    5.Sum bugs like silent symbol sometimes after using alert slider even in all notification mode.
    6.Sometime launcher lags
    jwarszawa likes this.
  6. jwarszawa Froyo Aug 23, 2016
    jwarszawa, Aug 23, 2016 :
    The only sensible advice: if you can , go back to version 2.2.1.
  7. Document02 Honeycomb Aug 23, 2016
    Document02, Aug 23, 2016 :
    The one that had 30s hang envery half hour?
  8. jwarszawa Froyo Aug 26, 2016
    jwarszawa, Aug 26, 2016 :
    OK , no one is perfect ;) And seriously - which of that the OP2 software is fully usable , without errors , tiring "functionality," etc ? Maybe it was some damn model , even the manufacturer is trying to forget about it ?
  9. Leehm Honeycomb Aug 26, 2016
  10. Joshua_B Ice Cream Sandwich Aug 26, 2016
    Joshua_B, Aug 26, 2016 :
    How come a lower priority device like the OPX get 3.1 before the OP2? 3.1 is dope, I want it
    ashwinguy likes this.
  11. Dillinger Honeycomb Aug 26, 2016
    Dillinger, Aug 26, 2016 :
    So you wont see it this month either as it draws to a close very soon. I guess role on September!!!!!!
  12. luissalvador90 Honeycomb Aug 26, 2016
    luissalvador90, Aug 26, 2016 :
    The 3 most important things to fix in the next update:
    - battery drain (android processes)
    - autofocus video & camera quality
    - sound quality
    The 3 things we will receive:
    - new camera UI
    - new OP bloatware apps
    - new wallpapers
  13. jwarszawa Froyo Aug 28, 2016
    jwarszawa, Aug 28, 2016 :
    Unfortunately , there are not all the problems:(
    It remains :
    - full support for two SIM cards, including such trifle ( in version 2.2.10 as an independent sounds / ringtone, for each of the cards
    - problems with identification of callers ( caller ID )
    - problems with bluetooth
    - phone will not ring after reboot - unless clearing the cache .
    - issues with charging.
    About OS version 3.0.2 "mistakes" is over 190 pages:).
    OK , not all have the same problems. But most reports like this same ..
    I think that the creator (OnePlus programmers) after so many months, could something to do with it!!! The more that the equipment was not given away for free!
    Q: after a half of year OnePlus forget flagship number 3 like forgot about us? And will deal with another toy?
    Shame...........
    obustudei likes this.
  14. Vbhv Honeycomb Aug 28, 2016
  15. patdol28 Froyo Aug 28, 2016
  16. Mohitoneplus02 Cupcake Aug 31, 2016
  17. intutaurus Donut Sep 9, 2016
    intutaurus, Sep 9, 2016 :
    We heard some users are experiencing bootloop post OTA upgrade to 3.0.2. Based on the feedback from helping these users, we are providing general instructions that should help everyone.
  18. vinay1+2 Cupcake Sep 9, 2016
  19. vinay1+2 Cupcake Sep 9, 2016
    vinay1+2, Sep 9, 2016 :
    @@Helen Any update on this query?
  20. vinay1+2 Cupcake Sep 9, 2016
