453
OxygenOS 3.0 Community Build Now Available for OnePlus 2
Thread Status:
Not open for further replies.
  1. sajran
    Cupcake Mar 30, 2016
    sajran , Mar 30, 2016 :
    I noticed that all sounds are very loud, just like when MaxxxAudio was enabled on older versions. It was too loud for me even on lowest setting and I have same problem now but can't just disable MaxxxAudio since it's no longer there. Do you have any idea how to lower the sound volume to reasonable level?
    prasadpatrikar likes this.
  2. pkair
    Honeycomb Mar 30, 2016
    pkair , Mar 30, 2016 :
    How possibly people will have solutions for issues if ROM was basically just announced?If you dirty flashed do factory reset maybe it helps.
  3. SoniaB
    Community Hero 2020 Mar 30, 2016
    SoniaB , Mar 30, 2016 :
    I have already reported it to admins. Not sure why it happened. Its the first time I ever encountered it too.
    Normally clear cache takes seconds. It may happen again as it has with me, but its intermittent. If it does, leave it a minute and then tap screen and it will be fine [​IMG]
    Akshat2793 likes this.
  4. varunsur
    Gingerbread Mar 30, 2016
    varunsur , Mar 30, 2016 :
    Still don't see it...any setting which you enabled?
  5. Rodytjuh
    Eclair Mar 30, 2016
    Rodytjuh , Mar 30, 2016 :
    Can Someone help me out?
    i Have an A2003 running on Oxygen 2.2.1 not rooted
    not unlocked when i go into recovery i dont get install from local
    only from SD and USB if i tap SD nothing happend, what i am doing wrong?
  6. darkdiabl3
    Donut Mar 30, 2016
    darkdiabl3 , Mar 30, 2016 :
    Installing from SD will be fine!
  7. greenazio
    Donut Mar 30, 2016
    greenazio , Mar 30, 2016 :
    Scroll down to the very bottom and theres a button to clear all apps on the right, works fine.
  8. Sothis6881
    Eclair Mar 30, 2016
    Sothis6881 , Mar 30, 2016 :
    My recent apps and contact shelves seem to have shrunk. In the op, it says to remove and re-add, but I can't seem to remove them. Any help would be appreciated.
  9. dakshmay21
    Eclair Mar 30, 2016
    dakshmay21 , Mar 30, 2016 :
    *#*#4636#*#* not working and going crazy. Animations and UI seems to be flying though.
  10. saahill
    saahill , Mar 30, 2016 :
    Hello everybody! Been a reader since 6 months. Just starting the discussions..
    My OP2 is stock OOS 2.2.1 not rooted. So, is dirty flashing worth it or should I wait for the OTA? I just want to avoid any major bugs (if any).. @namanbhalla or @SoniaB can you guys help.
  11. Krishna442
    Eclair Mar 30, 2016
    Krishna442 , Mar 30, 2016 :
    You'll not get update. You should manually download this build. This is not for public release.
  12. bgraham
    Eclair Mar 30, 2016
    bgraham , Mar 30, 2016 :
    A few bugs I've noticed, great update though :):
    Battery is being drained by 'oxygen' and hasn't been great for the few hours I've used it (this might be down to my phone not being fully charged since updating though):
    http://imgur.com/thG5VRC
    Accessing or trying to change permissions doesn't work at all for most apps and crashes Settings when you try but not all apps (Google apps seem fine). I did alter the permissions of apps before on OOS 2.2.1 if that makes any difference.
    http://imgur.com/VkZGQGn
    Default calculator app not recognised by Play Store (neither are dialer or contacts):
    http://imgur.com/uGh1mIe
    Pointless FAB, should go straight to widget menu:
    http://imgur.com/YxLRLWV
    Play Music notification goes weird light blue colour all the time:
    http://imgur.com/JVz7qcZ
    There are two file explorers, one digged in Settings being the default and the other as a separate app:
    OnePlus':
    http://imgur.com/6kfmeAM
    Google's:
    http://imgur.com/WD9d42q
    http://imgur.com/rTz2VqA
    pppttl and anoopp like this.
  13. shrineels10
    rmprakash likes this.
  14. JackPorter18
  15. Deactivated User
    Mar 30, 2016
  16. mohammed1107
    Froyo Mar 30, 2016
    monotonie0815 likes this.
  17. cedalone
    Jelly Bean Mar 30, 2016
    cedalone , Mar 30, 2016 :
    OOS3: install OK
    TWRP:install OK
    SuperSU:install OK
    Xposed: install OK
    so far, so good, thanks to @Naman Bhalla and his post on this thread and to others who helped me.
    hope for Lord Boeffla kernel soon, as they are my favorites
    dinjesk likes this.
  18. Sayonara
    Donut Mar 30, 2016
    Rodytjuh and bdlandis like this.
  19. pranayysharma
    Ice Cream Sandwich Mar 30, 2016
    pranayysharma , Mar 30, 2016 :
    You'll find it at the bottom of recent apps page. Three horizontal lines
    joenbrinch likes this.
  20. Saif.baig1234
    Eclair Mar 30, 2016
    Saif.baig1234 , Mar 30, 2016 :
    The three horizontal lines man
