120
OxygenOS 3.1.0 (Marshmallow) Community Build for OnePlus X
Thread Status:
Not open for further replies.
  1. bundys
    Gingerbread Aug 23, 2016
    bundys , Aug 23, 2016 :
    Hi guys.
    I detected an error, possibly coming from CM13 by Sultan and do wipes with stock recovery, but just in case, and I tell reported it here for people of OnePlus can leaf through.
    App phone settings, "sound and vibration" ERROR AND APPLICATION CLOSES.
    P.D: Just in case...the automatic brightness is by default very high for the ilumination conditions.
  2. FaleshC
    KitKat Aug 23, 2016
    FaleshC , Aug 23, 2016 :
    Come on..don't you read previous comments?? Clearly its mentioned that twrp has issues, still users posting same question.
    You need to be in stock recovery to flash thw update successfully as of now.
  3. Davidullo
    Cupcake Aug 23, 2016
    Davidullo , Aug 23, 2016 :
    Install stock recovery (you can find it on the download page of the update, on the bottom) and then install the update from here. You can install stock recovery right from TWRP!
    I had the same problem and solved doing this.
  4. criss_caz
    Froyo Aug 23, 2016
    criss_caz , Aug 23, 2016 :
    Testing again,
    It seems that mobile data is not working as should be with some apps... I cannot send/receive Watsapp messages, on Hangouts messages appear only if enter/re-enter in app ..e-mail apps are not refreshing/syncing with mobile data ON..
    It's seems that only for web surfing mobile data is working fine.. really don't have a clue why on some apps mobile data usage has above behavior...
  5. venky4real
    venky4real , Aug 23, 2016 :
    Yeah iam also very happy but in community build battery drain is too heavy
  6. sushee61
    Eclair Aug 23, 2016
    sushee61 , Aug 23, 2016 :
    There are too many comments going through all of them is tough.
    I am not able unlock my bootloader as well
  7. fozy.rafique
    fozy.rafique , Aug 23, 2016 :
    I have installed successfully. It's running smoothly.
    And I have found few bugs :
    1. Opened apps list doesn't show in recent apps
    2. Connected apps in Google menu in settings doesn't work when I check the box to delete activities too
    #will update more..
  8. twentyfourinc
  9. Leonard Muke
    Froyo Aug 23, 2016
    Leonard Muke , Aug 23, 2016 :
    Everytime I connect the phone to my pc, it automatically switches to "Charging-Mode", so I can't get access to the data on the phone. I have to switch it manually to "File Transfer", but this setting doesn't save for the next time.
  10. bundys
    The Google Form to report bugs....Can I only fill once?...I See an error, and a probably small tweak to adjust in the finally OTA.
  11. keenanjf
    Froyo Aug 23, 2016
    keenanjf , Aug 23, 2016 :
    You don't need to go very far in this thread to realize that this rom can ONLY BE FLASHED WITH THE STOCK BOOTLOADER. It's written on the instructions on the download link too.
    Did you enable "OEM Unlocking", and "USB Debugging" in the dev options?
  12. bivin123
    bivin123 , Aug 23, 2016 :
    Lol :D Android n to be released soon and you get m now . .. Pathetic.. I feel you guys. .
  13. Gavisharora
    Leonard Muke likes this.
  14. Tiongkia
    Froyo Aug 23, 2016
    Tiongkia , Aug 23, 2016 :
    This is a Marshmallow bug, not OSS. Happens to other and custom ROMs too.
  15. sushee61
    Eclair Aug 23, 2016
    Sorry I didn't notice that.
    Yes I enabled "OEM Unlocking", and "USB Debugging" in the dev options.
    When I try the below command:
    Code:
    fastboot oem unlock
    its rebooting to recovery.
    Code:
    fastboot oem device-info
    I find Device unlocked:false
    Because of this I am not able to flash stock recovery :(
  16. Luca Mennini
  17. OneMarco
    OneMarco , Aug 23, 2016 :
    After 4 hours of MM on my OPX :
    its a bit slow
    heats up a bit
    laggis a bit
    there are some tunning to do but ... thanks a lot for the update !
  18. G_marcus_marcus_gmwv
    G_marcus_marcus_gmwv , Aug 23, 2016 :
    cannot connect to free wifi or hotspots and major video lag since download
  19. makis106
    Donut Aug 23, 2016
  20. lehoon
    lehoon , Aug 23, 2016 :
    Anyone found a way to remove the Google search bar?
    Cannot find the setting anywhere.
