120
OxygenOS 3.1.0 (Marshmallow) Community Build for OnePlus X
Thread Status:
Not open for further replies.
  1. Leonard Muke
    Froyo Aug 22, 2016
    Leonard Muke , Aug 22, 2016 :
    Finally the MM update... i try to install it as fast as possible and will tell you my thoughts here at this thread...thank you!
    #61
  2. ilaria988
    Ice Cream Sandwich Aug 22, 2016
    ilaria988 , Aug 22, 2016 :
    @Allen W how much time do we have to wait for a full OTA without flash our device? and what about the shelf? does this update to marshmallow fix that bug?
    #62
  3. locxFIN
    KitKat Aug 22, 2016
    locxFIN , Aug 22, 2016 :
    Good news for all OPX users! Here they were thinking they're abandoned ;)
    #63
  4. fdroko
    Jelly Bean Aug 22, 2016
    #64
  5. Arpit_Singh_
    Eclair Aug 22, 2016
    Arpit_Singh_ , Aug 22, 2016 :
    When we will get update notification in Mobile...
    Also please someone tell me.. Is volte has been started in mm
    #65
  6. rarog
    Assistant Head Moderator Assistant Head Moderator Aug 22, 2016
    rarog , Aug 22, 2016 :
    Not needed. Just install it.
    #66
    davidjlosi likes this.
  7. Jasis
    Cupcake Aug 22, 2016
    #67
  8. jai patel
    Froyo Aug 22, 2016
    #68
  9. Arpit_Singh_
    Eclair Aug 22, 2016
    I am newbie....so Please can someone tell me that... Whether I can install it directly after downloading it? ... I m on stock rom (non-root)
    #69
    ImWajeed likes this.
  10. Vj88
    Froyo Aug 22, 2016
    Vj88 , Aug 22, 2016 :
    Pheww, Thanks OP finally you made it..
    I would like to wait for the Official OTA (more waiting:() rather than falshing this Link file.
    #Safeside Thank you @Allen W :rolleyes::)
    #70
  11. Amitnv
    Gingerbread Aug 22, 2016
    Amitnv , Aug 22, 2016 :
    Can somebody post full instructions on how to flash this build?
    On the FAQ page it is mentioned that "device must be unlocked" does that refer to boot loader?If yes, then let me know how to do it!
    #71
  12. SWD33
    SWD33 , Aug 22, 2016 :
    Question: will there ever be a non-community build version? As I'm currently uncertain if I want to update jut yet!
    #72
  13. azn39
    azn39 , Aug 22, 2016 :
    If you come from another ROM, you do a factory reset, otherwise if you are using the OxygenOS you can install it easily without any wipe. Just a wipe cache. ;)
    #73
    Mr. BG and fdroko like this.
  14. fdroko
    #74
  15. G_Christophorus_Angga_MP
    #75
  16. sam2t
    sam2t , Aug 22, 2016 :
    If you download then turn off your phone hold power button and volume down to go into recovery. Then select install etc
    #76
  17. Deactivated User
    Aug 22, 2016
    #77
  18. Deactivated User
    Aug 22, 2016
    #78
  19. rarog
    No need to unlock bootloader, as it's signed OTA zip, which will work with Oxygen recovery.
    #79
    otto2 likes this.
  20. Deactivated User
    Aug 22, 2016
    #80
