161
OxygenOS 3.1.3 (Marshmallow) OTA for OnePlus X
Thread Status:
Not open for further replies.
  1. simoniub
    Gingerbread Sep 28, 2016
    simoniub , Sep 28, 2016 :
    Can you move apps to SD card after update to 3.1.2? I can not, the option has gone but I could on 3.1.1 CB.
    Pls let me know.
    #81
    Taran5 likes this.
  2. Alpha Victor
    Cupcake Sep 28, 2016
    Alpha Victor , Sep 28, 2016 :
    Thanks for update.
    How's battery life? Hope it's not like 3.1.1
    If someone have updated then please give feedback.
    #82
  3. maje68
    #83
    simoniub and rarog like this.
  4. simoniub
    Can you pls confirm that after update to 3.1.2 can you move apps to SD card? I can not. The move to sd card option has gone!!!!!!
    #84
  5. simoniub
    Same here, move to SD card has gone !!!!!!
    #85
  6. Mr. BG
    Marshmallow Sep 28, 2016
    Mr. BG , Sep 28, 2016 :
    :p
    No, it's just not recommended either as it is still very wonky...
    That usually works for most people.
    #86
    tmarcal likes this.
  7. anishnv
    anishnv , Sep 28, 2016 :
    When this update will be reflecting in the automatic mobile updates?
    F**K my OPX is not charging!!!
    Overheating!!!
    Apps not responding!!!
    OPX Restarting!!!
    #87
  8. Sven Engelen
    Donut Sep 28, 2016
    #88
    simoniub likes this.
  9. script
    Nougat Moderator Sep 28, 2016
    script , Sep 28, 2016 :
    I'm sorry,i don't use a sd card, as I'm using 2 Sims. One for calling, one for data. Can't answer your question.
    #89
  10. shele92
    shele92 , Sep 28, 2016 :
    I have 2.2.3 firmware,if i download this 3.1.2 zip and instal it would i lose any of my data?
    #90
  11. simoniub
    Thanks for respond. Lets see what comes from others :)
    #91
    script likes this.
  12. rarog
    Lollipop Assistant Head Moderator Sep 28, 2016
    rarog , Sep 28, 2016 :
    Which is indeed needed, so OEMs can close security holes, before more exploits are circulating. That's the usual way to handle security in the world. :)
    #92
    dsmonteiro likes this.
  13. simoniub
    No you will not. I did the dirty flash from 3.1.1 CB and it works great except for the move apps to SD card.
    #93
  14. Amitnv
    #94
  15. LiverpoolFC
    Donut Sep 28, 2016
    LiverpoolFC , Sep 28, 2016 :
    Hi, same problem for me, i have just updated via OTA and Google Play Services keeps pushing a message saying "Google Play Store has been stopped", as an alert triangle appears on the notification bar, saying: "Google PLay Services won't work until you update Google Play Services".
    How can I fix it?
    This didn't happen before the update.
    P.S: I can't open my apps (inside Play Store) so as to update Google Play Services.
    Thanks!
    #95
    dibit, psk4053, JediJer and 2 others like this.
  16. HeartbreakKid
    Eclair Sep 28, 2016
    #96
  17. ITB
    Donut Sep 28, 2016
    ITB , Sep 28, 2016 :
    Dear,
    Yesterday i had a small update( arround 74MB) and from then my phone heats so hard i can hardly call because of heat. Apps doesn't work anymore...
    Please make fast an update too fix the bugs...
    Best regards Roald
    #97
  18. fabiolanzi
    Ice Cream Sandwich Sep 28, 2016
    fabiolanzi , Sep 28, 2016 :
    I did not have any problems with the Apps that were on the SD-card, when you first reboot they don't show up, but after a couple of minutes they reappear, at least... in my case it happened without any specific action.
    #98
  19. Aqua_X
    Aqua_X , Sep 28, 2016 :
    Set up a VPN to USA and you get the update , Installing it would be fine here in India , but downloading it through a VPN causes an error where the verifying file never loads
    #99
  20. volteon
    Community Veteran Sep 28, 2016
    rarog and script like this.
