161
OxygenOS 3.1.3 (Marshmallow) OTA for OnePlus X
Thread Status:
Not open for further replies.
  1. maje
    Gingerbread Sep 28, 2016
    maje , Sep 28, 2016 :
    Move to SD Card still available for me!
    App Info -> 1st Button (Storage? In german it is called 'Speicher') and then I can choose between the Internal storage and SD Card.
    Mounting SD Card as Internal not tested yet. I will do this in the evening
    Mr. BG and script like this.
  2. fabiolanzi
    Ice Cream Sandwich Sep 28, 2016
  3. script
    Nougat Moderator Sep 28, 2016
    script , Sep 28, 2016 :
    Which os version did you have in beforehand?
  4. HeartbreakKid
    Eclair Sep 28, 2016
    HeartbreakKid , Sep 28, 2016 :
    369 MB also for me, had Oxygen 2.2.3 before
    script likes this.
  5. abhiversion2.1
    Eclair Sep 28, 2016
    abhiversion2.1 , Sep 28, 2016 :
    Unable to open Access permissions in Apps under settings.
    Battery Optimization option not working for App settings.
    Kill all recent apps option missing
  6. shroootea
    Cupcake Sep 28, 2016
    shroootea , Sep 28, 2016 :
    After updating my phone to the 2.2.3 update this afternoon, my phone has been overheated, its battery has rapidly drained, and none of my applications are functioning.
  7. FaleshC
    KitKat Sep 28, 2016
    FaleshC , Sep 28, 2016 :
    as you must know that Google changed the version of Play services for Lollipop and MM. so without updating you cannot use google apps, just allow to update it and all will be fine.
    Mr. BG likes this.
  8. FaleshC
    KitKat Sep 28, 2016
    just now did it no problems, also i used us server for 2.2.3 no problems as of now.
  9. Sarfaraz2015
    Mr. BG likes this.
  10. FaleshC
    KitKat Sep 28, 2016
    they have moved the setting its there.
    open any app from Settings>Apps and tap on Storage, at the top you will get Storage Used. Tap on it and you will get the option to chose your storage.
    rarog, Mr. BG and simoniub like this.
  11. Robyrq
    Donut Sep 28, 2016
    Robyrq , Sep 28, 2016 :
    I had the same issue.
    Wasn't able to update Google Play Services because the Play Store kept crashing (So it was kinda an endless loop).
    The thing I did to fix it:
    1. Backup your data under Settings -> Backup and reset
    2. Reset the phone to factory settings
    3. After the reboot follow the setup and allow it to use the backup you just made
    Now it works just fine ;)
    Pijaam and Mr. BG like this.
  12. ketan_patel19
    ketan_patel19 , Sep 28, 2016 :
    Gujarati font is added or not?
  13. opticoverload
  14. Guidoce
    Guidoce , Sep 28, 2016 :
    I agree with you, it seems that Helen left OP cause was asking more resources..
  15. FabianRene
    FabianRene , Sep 28, 2016 :
    And what about the version of OPO. Surgical team you push the first user? Since there is no new Android 7, according to the statements, we also need a current OxygenOS.
  16. ketan_patel19
    I need my native lang. support otherwise your device is worst.
  17. Guidoce
    Only 13MB????
  18. tomosellis
    tomosellis , Sep 28, 2016 :
    All working fine on 3.1.2 apart from SD Card formatting. For some reason it keeps giving me an error when I try to format it and then unmounts itself. Does anyone else have this bug?
  19. emannxx
    Froyo Sep 28, 2016
  20. Adrycada
    Adrycada , Sep 28, 2016 :
    Same issue here, Radio has a tons of problems since MM updates
