161
OxygenOS 3.1.3 (Marshmallow) OTA for OnePlus X
Thread Status:
Not open for further replies.
  1. shirsho.dbz
    Froyo Oct 2, 2016
    shirsho.dbz , Oct 2, 2016 :
    I'm facing a serious problem. After the marshmallow update I can't seem to find my memory in my computer. It's the same in Ubuntu. The window is showing a blank page. Please help.
    404error likes this.
  2. NIK3SH
    Froyo Oct 2, 2016
    NIK3SH , Oct 2, 2016 :
    #Update...
    I resolved it by resetting app preferences...
    It did resolved my issue immediately. Just need to reconfigure permission for all apps while needed...
    ROM is working fine and flawlessly...
  3. NIK3SH
    Froyo Oct 2, 2016
    Drag notification and select FILE TRANSFER...
    By default USB connection treated as CHARGE ONLY...
  4. sixthspeed
    Cupcake Oct 2, 2016
  5. NIK3SH
    Froyo Oct 2, 2016
    Revert to lollipop would be difficult...
    Give a try by resetting network settings under BACKUP & RESET...
  6. NIK3SH
    Froyo Oct 2, 2016
    You're flashing stock ROM package over TWRP?
    I think it's not recommended as well you must have loose TWRP as well...
    Try booting Recovery and Clear Cache should help, Afaik...
  7. sixthspeed
    Cupcake Oct 2, 2016
    sixthspeed , Oct 2, 2016 :
    I used TWRP recovery to flash stock 3.1.3 over stock 2.2.3. Now the phone wont boot into recovery
  8. sreenivasulu reddy.k
    Donut Oct 2, 2016
    sreenivasulu reddy.k , Oct 2, 2016 :
    How to toggle between icon packs?? Where to change icons?? Any body to help me??
  9. sohilrockz
    Cupcake Oct 2, 2016
    sohilrockz , Oct 2, 2016 :
    The official update of marshmallow is not upto the mark. The oneplus x launcher keeps crashing frequently and the app drawer has no option of scrolling horizontally ..... So plz take it into consideration as mostly with the older OS all users were used to the horizontally scrolling app drawer
    postie likes this.
  10. amirul_lisan
    Ice Cream Sandwich Oct 2, 2016
    amirul_lisan , Oct 2, 2016 :
    is it good? any issues so far?
    simoniub likes this.
  11. Mahesh6264
    Cupcake Oct 2, 2016
    Mahesh6264 , Oct 2, 2016 :
    My op x mobile is heating continuously after new update even though i tried to cool down with clean master it didn't work
    My opx mobile is keep getting heating after new update even though i tried to cool down it with clean master but it didn't work
  12. sunny33438
    Froyo Oct 2, 2016
    sunny33438 , Oct 2, 2016 :
    i did the same, not an issue at all...
  13. amirul_lisan
    long Tap on your homescreen, swipe left and you'll find the Icon Pack options. select and tap SAVE top right corner :)
    sreenivasulu reddy.k likes this.
  14. fabiolanzi
  15. amirul_lisan
    Thanks, updated to OxygenOS 3.1.3 and it's rebooting now. let's see how it serves ;)
  16. mfirdaus428
    Cupcake Oct 2, 2016
    mfirdaus428 , Oct 2, 2016 :
    Long press screen and you will find customize..do scroll to the right side to see more option.
  17. SURE3018
    Eclair Oct 2, 2016
  18. Avinash Sanapala
    Cupcake Oct 2, 2016
    Avinash Sanapala , Oct 2, 2016 :
    Anybody have issues with songs being skipped after the update?? Mine seems to skip after the gets locked.... Is it some kinda glitch...
  19. Aj264
    Cupcake Oct 2, 2016
    Aj264 , Oct 2, 2016 :
    I got the OTA update to 2.2.3 and then 3.1.2 MM. The thread title suggests 3.1.3. Am I missing an OTA update?
    I had issues with google play services after update and had to factory reset the phone to fix them. Otherwise I am unrooted, on stock OOS.
  20. stephane_A
    Eclair Oct 2, 2016
    stephane_A , Oct 2, 2016 :
    It is good, changing location to Canada made the update appear on the screen.
    No issues so far, the phone is acting as usual.
