133
OxygenOS 3.1.4 (Marshmallow) OTA for OnePlus X
  1. G_Pankaj_Khatri_cUZl
    Cupcake Nov 14, 2016
  2. Kéno40
    Jelly Bean Nov 14, 2016
    Kéno40 , Nov 14, 2016 :
    Read the answer above... I'm begging you and your friends !
    Mr. BG likes this.
  3. leowjc
    Eclair Nov 14, 2016
    leowjc , Nov 14, 2016 :
    Upgraded to OOS3.1.4, rooted.
    I cannot notice any difference with 3.1.3.
    so far so good.
    zer0se7en likes this.
  4. script
    Nougat Moderator Nov 14, 2016
    script , Nov 14, 2016 :
    Every time this is asked it's one day later
    maddd and Mr. BG like this.
  5. Eddard
    Eddard , Nov 14, 2016 :
    I have found a workaround: Google+: delete data and disable, restart the phone, done!
  6. zer0se7en
    Ice Cream Sandwich Nov 14, 2016
    zer0se7en , Nov 14, 2016 :
    Yep. been obsercing this update (3.1.4), and I must say... has no difference with 3.1.3. only difference I see is my battery is not being drained as much as before. will test further then will report back.
    So far no issues at all. flashed dirty. But I cleared the cache first, then Flashify Stock kernel, wiped Dalvik and cache before flashing the OTA.zip.
    Now with TWRP rooted and BlackReactor Kernel. Running smooth so far.
    leowjc likes this.
  7. trebontX
    trebontX , Nov 14, 2016 :
    Then flash my phone again and then re install all my apps.
    No thanks.
  8. Kéno40
    Not at all.
    But you would know that if you had done a minimum of research and reading before posting crap.
    Mr. BG and zer0se7en like this.
  9. vickyy17
    Gingerbread Nov 14, 2016
    vickyy17 , Nov 14, 2016 :
    Many were complaining about the gestures not working properly including me in 3.1.3 . Now after the upgrade it seems fixed, so yea I did see a noticeable bug fix. the auto brightness also feels more accurate. Just wish OnePlus will continue to update security patches regularly like they are doing presently....
  10. zer0se7en
    As I have said... I flashed dirty. Updated and retaining all my apps and datas. Also rooted. No issues whatsoever.
  11. SapilautX
    SapilautX , Nov 14, 2016 :
    archiving. . .
    [SUPERSU] UPDATE !!
    • Latest :
    superSU_2.78_SR4_SYSTEMLESS (5.64mb)
    modified by XDA member -ferk-
    http://forum.xda-developers.com/attachment.php?attachmentid=3939651&d=1479393635
    • old one:
    Oxygen_OS3_v2.78_supersu-systemless(4.77mb)
    https://drive.google.com/file/d/0B4K5cvm1zdldcmZpc3RuVnRjUUE/view
    √ both are compatible with OOS 3.1.3/3.1.4. Free to choose!
    [TWRP]
    the most stable (flash+backup+restore) worked flawlessly.
    • Twrp_3.0.2-2_blu_spark_v41 by eng.stk
    http://forum.xda-developers.com/devdb/project/dl/?id=20236
    √ all files are already tested by me & others.
    [STOCK RECOVERIES]
    • MM ROMs (15.12mb) : use this to flash/upgrade Oxygen MM ROMs (MM bootloader) from your current Oxygen MM ROM. OR use
    the blu_spark's twrp v41 above.
    http://oxygenos.oneplus.net.s3.amazonaws.com/OPX_MM_recovery.img
    • LP ROMs (14.62mb) : use this to flash Oxygen MM ROMs from your current LP ROM.
    https://s3.amazonaws.com/oxygenos.oneplus.net/OPX_recovery.img
    nen3i and zer0se7en like this.
  12. AlexEC2
  13. Alfred Albert
    Froyo Nov 14, 2016
    Alfred Albert , Nov 14, 2016 :
    you can turn off screenshot sound using silent slider, but you whatsapp camera sound can't be turn off
  14. Kéno40
    Whatsapp sound can be manually stoopped by erasing the file of the sound with a rooted explorer.
  15. Adrycada
    Adrycada , Nov 14, 2016 :
    OTA is working?
    I mean, for the latest update I flashed the device and I installed manually (O2OS 3.1.2) the update. And for the 3.1.3 i receive the OTA the same day It was released.
    But now, I didn't receive anything...
  16. zahidreza
    zahidreza , Nov 14, 2016 :
    Hi, I hate to say it but after I installed 3.1.4 my "OP X" is no longer able to access Play Store - "Unfortunately, Google Play Store has stopped." Please advise how to roll back to 3.1.3 (was really happy with 3.1.3!)
    Thanks in advance!
  17. yoursbalag
    yoursbalag , Nov 14, 2016 :
    Kindly check if all the permissions are granted.
  18. fabiolanzi
    fabiolanzi , Nov 14, 2016 :
    just put your phone on silent mode
  19. fabiolanzi
    poor baby
    Mr. BG likes this.
  20. Akku143
    Eclair Nov 14, 2016
    Akku143 , Nov 14, 2016 :
    RooteD... On 3.1.4 oxygen Os... Unable to set Selinux to permissive tried se linux mode changer..
