133
OxygenOS 3.1.4 (Marshmallow) OTA for OnePlus X
  1. lukaszsikora
    Cupcake Apr 17, 2018
    lukaszsikora , Apr 17, 2018 :
    I had the same on my Oneplus X with Android 5.1.1 just few minutes ago. There is some glitch in system libraries related to contact's database and latest versions of applications using those libraries. Every message app using system's contacts like whatsapp, messages, hangouts will shutdown 1s after you open it. To resolve it I had to uninstall app which was causing that problem ... once it was Google Presentations, other time it was Google Keep. It might be any other application. Just create a list of your apps and start removing them and testing messages, if you can open them without problems (remember to remove them from background apps after each test).
    I know it's not a solution, just a workaround, but that's still something.
  2. Deactivated User
    May 11, 2018
  3. Ankur705
    Cupcake Aug 16, 2018
  4. Tobikage
    Nougat Aug 16, 2018
    Tobikage , Aug 16, 2018 :
    Contact support.
    Ankur705 and Hydra Bob like this.
  5. Hydra Bob
    Marshmallow Aug 16, 2018
    Hydra Bob , Aug 16, 2018 :
    And please stop yelling
    yourdesiredusername and Ankur705 like this.
  6. Nikhil Seenivas
    Honeycomb Aug 16, 2018
  7. DeluxeNoone
    Ice Cream Sandwich Sep 18, 2018
  8. Kéno40
    Jelly Bean Sep 18, 2018
  9. jasto11
    Cupcake Sep 24, 2018
    jasto11 , Sep 24, 2018 :
    Is this OS version still available for download OTA ?
  10. Kéno40
    Jelly Bean Sep 25, 2018
  11. Sushila dudi
    Cupcake Sep 27, 2018
    Sushila dudi , Sep 27, 2018 :
    I using one plus x but I don't received new updates like android nougat and android oreo in one plus x
    E1539825996648 likes this.
  12. Kéno40
    Jelly Bean Sep 28, 2018
    Kéno40 , Sep 28, 2018 :
    OPX is discontinued for a loooooong time.... There won't be update.
    If you want some, just unlock it and use custom roms.
  13. Harshad_Pednekars
    Cupcake Oct 1, 2018
  14. Kéno40
    Jelly Bean Oct 1, 2018
    Kéno40 , Oct 1, 2018 :
    OP3, OPT3 : Yes
    OPO, OPX & OP2 : No
    E1539825996648 and BeingIncog like this.
  15. E1539825996648
    Cupcake Oct 18, 2018
  16. Kéno40
    Jelly Bean Oct 18, 2018
    Kéno40 , Oct 18, 2018 :
    Because he doesn't get update at all for year.
    Then to activate VOLTE, it needs work between manufacturer and ecah carriers so it's just for some flagships or mainstream models.
  17. Tony oneplus x
    Cupcake May 4, 2019
  18. Kéno40
    Jelly Bean May 6, 2019
  19. G1558440112397
    Cupcake May 21, 2019
  20. Kéno40
    Jelly Bean May 21, 2019
    Kéno40 , May 21, 2019 :
    Nope !
    for years !
