125
OxygenOS 3.2.1 rollout is starting on OnePlus 3
  1. JasonMR
    Lollipop Jul 10, 2016
    JasonMR , Jul 10, 2016 :
    Try connecting to Germany and loading any webpage, then check for updates. It wouldn't show for me until I did something else first
  2. joebass96
    Ice Cream Sandwich Jul 10, 2016
    joebass96 , Jul 10, 2016 :
    When you have downloaded the Snap vpn,change location to a Germany,then go to your browser type in Google anything click on that site,do it with another site.
    Then go to settings and do the check for updates then you should see the update to install,that's what I did last night anyway.
  3. matt1500
    Eclair Jul 10, 2016
  4. andrewrcatton
    Cupcake Jul 10, 2016
  5. matt1500
    Eclair Jul 10, 2016
    matt1500 , Jul 10, 2016 :
    Hold your horses....... Did it again and it works. Not sure what was different.
    Thanks guys
    es.salby and JasonMR like this.
  6. Sindri Steinn
    Sindri Steinn , Jul 10, 2016 :
  7. Sindri Steinn
  8. es.salby
    Gingerbread Jul 10, 2016
    es.salby , Jul 10, 2016 :
    Good things come to those who wait ;)
  9. joebass96
    Nice one.
  10. lkosova
    lkosova , Jul 10, 2016 :
    So there is this Germany update and there seems to be one on the Oneplus site. Stupid question but is there a difference between the two? Also if in the United States would there be a different one? Before I get lynched....:eek:....I know there are different version of the OS from US and China but not sure about different countries per se. thx.
  11. JasonMR
    Lollipop Jul 11, 2016
    JasonMR , Jul 11, 2016 :
    They're all the same update, fine to grab it from either source.
  12. Akiva
    Gingerbread Jul 11, 2016
    Akiva , Jul 11, 2016 :
    The gps is still not working properly. I'm on 3.2.1 and while using navigation apps it thinks I am a bit to the side of where I actually am.
  13. Jebusfreek666
    Jebusfreek666 , Jul 11, 2016 :
    Have you tried calibrating it?
    Akiva likes this.
  14. lkosova
    Ice Cream Sandwich Jul 11, 2016
    lkosova , Jul 11, 2016 :
    Thx so much.
  15. 0xFireball
    Cupcake Jul 11, 2016
  16. sbooth
    US Brand Ambassador Jul 11, 2016
    sbooth , Jul 11, 2016 :
    No, nothing yet. I went ahead and manually updated via the TWRP zip.
  17. Ashish rajoria
    Eclair Jul 11, 2016
  18. saikiran4ever
    Jelly Bean Jul 11, 2016
    saikiran4ever , Jul 11, 2016 :
    Use merge+ from play store.
  19. Anz19
    Anz19 , Jul 11, 2016 :
    I have still not got the oxygen os 3.2.1 update
    I am from India.
  20. Ashish rajoria
    Eclair Jul 11, 2016
    Ashish rajoria , Jul 11, 2016 :
    i am also facing same problem
