OxygenOS 3.2.2 Battery status after update.
SOT after update to OxygenOS 3.2.2
  1. >4hrs
    39.5%
  2. ~5hrs
    36.4%
  3. <6hrs
    24.1%
  1. Desejmon
    Ice Cream Sandwich Jul 29, 2016
    Desejmon , Jul 29, 2016 :
    Can you tell me what % of brightness you had, how much time U have been Online?
    #41
  2. JRCondat
    Froyo Jul 29, 2016
    #42
  3. Agil krish
    Eclair Jul 29, 2016
    Agil krish , Jul 29, 2016 :
    Guys turn of the auto backup in setting and wipe cache in recovery. This works it has improved by battery.
    #43
    Desejmon likes this.
  4. Benz1337
    Eclair Jul 30, 2016
    Benz1337 , Jul 30, 2016 :
    My phone drains battery in idle as fast as when browsing.
    Browsing here for 6 minutes = 1% battery.
    Phone on bag not using for same time = 1% battery.
    Doesn't seem right.
    Yes, cache cleared and no backup service since day 1
    #44
  5. ritchiedrama
    Ice Cream Sandwich Jul 30, 2016
    ritchiedrama , Jul 30, 2016 :
    Mostly 25-50% brightness, like, around there. Time online? Not sure what you mean.
    #45
  6. Xenti3
    Honeycomb Jul 30, 2016
    Xenti3 , Jul 30, 2016 :
    I hadnt't considered wiping the cache after disabling it, thanks for the idea mate it seems to have solved my issue.
    Well maybe not fixed but certainly less than 1/2 the drain it was. Instead of 1% every 5 minutes its more the 15. I think ill swap to a custom rom later today.
    #46
    Agil krish likes this.
  7. iyerkrtk
    Cupcake Jul 30, 2016
    iyerkrtk , Jul 30, 2016 :
    Yes. Yesterday I got my update. After that charged 100% . Within 10hr my battery got drained 60% with minimal usage. Overnight it went down by 15%
    #47
  8. kenchinito
    Froyo Jul 30, 2016
    #48
    Azlan irshad, deepakjb and Mr Mystery like this.
  9. Mr Mystery
    Gingerbread Jul 30, 2016
    Mr Mystery , Jul 30, 2016 :
    My guess is HSPA only and Wifi
    #49
  10. avg1987
    Donut Jul 30, 2016
    #50
  11. SergiuszJasper
    SergiuszJasper , Jul 30, 2016 :
    Just over six hrs and 14% left and a full day from 630am till 1215pm but I am trying out a custom kernel ElementalX now that it has dash charging and I would say there is an improvement but still only day one on this kernel so will see....i like it cos I can play around with and at the moment running on default settings.
    #51
    Kareem Hussaini and aman_11 like this.
  12. Agil krish
    Eclair Jul 30, 2016
    Agil krish , Jul 30, 2016 :
    6 minutes - 1% is same here with my phone, bt when not using it doesn't drain at all wifi is always connected
    #52
  13. aman_11
    aman_11 , Jul 30, 2016 :
    hello everyone!
    i was having good battery performance till i updated to 3.2.1 after which battery performance got very worse.it gets discharged 10% in every 10 mins by only streaming music with headphones ON with screen OFF. the phone also used to heat up a lot during this time.i was so disappointed that i did a factory reset and has since updated to 3.2.2.
    Though i am not yet facing such severe battery performance and heating issues,i am still not completely satisfied the overall battery performance when using the phone.idle performance is also not OK(10% discharge in 2 hours).
    I have read online that this issue is due to google partial wakelocks. i hope oneplus brings an update to rectify this issue soon.
    Since, this issue is not with every oneplus 3, I am more worried about whether the issue will be resolved by oneplus or not.
    that's why i would like to know, Is anyone else also facing similar battery issues?
    #53
  14. Bouncer0
    Donut Jul 30, 2016
    #54
  15. Xenti3
    Yes i am too, Oneplus cant do much to solve this really. It will probably be a few days to a week before another patch, thought about custom roms? since they have Dash now it might be worth looking at.
    #55
  16. cssoz
    cssoz , Jul 30, 2016 :
    Android OS draining ? = Google. we need 6.0.2
    and use ForceDoze root or not.
    #56
  17. Mr Mystery
    ForceDoze doesn't solve the issue. Lose 5% per hour still with it enabled. I think it makes it worse somehow
    #57
  18. cssoz
    did you enable DUMP permission & read_logs?
    #58
    Mr Mystery likes this.
  19. Mr Mystery
    #59
  20. cssoz
    o_O ?
    if u enabled those permissions via ADB platform tool. forcedoze will then only work. unless you have root.
    #60
