OxygenOS 3.2.2 Battery status after update.
SOT after update to OxygenOS 3.2.2
  1. >4hrs
    39.5%
  2. ~5hrs
    36.4%
  3. <6hrs
    24.1%
  1. kaghedo
    Jelly Bean Jul 30, 2016
    kaghedo , Jul 30, 2016 :
    Never had any issues with my battery life to be honest and i get like 2 days yes i mean two days from normal use :cool:
    #61
  2. Benz1337
    Eclair Jul 30, 2016
    Benz1337 , Jul 30, 2016 :
    After clearing cache and restarting again...see attachment. Same usage as before... Seems to be better than 3.21!
    #62
  3. m4r1k
    Froyo Jul 30, 2016
    m4r1k , Jul 30, 2016 :
    Could you post also the app stats?
    I got a quote worst battery after the 3.2.2 without any new app installed and I've cleaned the cache.
    Also, bright percentage?
    Thanks!
    #63
  4. Benz1337
    Eclair Jul 30, 2016
    This?
    Adaptive brightness.
    #64
    AhmedZunaid likes this.
  5. balaji66
    Cupcake Jul 31, 2016
    balaji66 , Jul 31, 2016 :
    Definitely it drains faster. I don't have the screen shot for 3.2.1 but after the update.. It drains within a day.. Am worried.
    #65
  6. fernandezm707
    Donut Jul 31, 2016
    #66
  7. vikeor
    Gingerbread Jul 31, 2016
    #67
  8. ritchiedrama
    Ice Cream Sandwich Jul 31, 2016
    ritchiedrama , Jul 31, 2016 :
    Mine just drained 0% from 2 am til 9 am :D
    #68
    SergiuszJasper likes this.
  9. Desejmon
    Desejmon , Jul 31, 2016 :
    I mean, how much time you have wifi/lte turned on
    #69
  10. ritchiedrama
    WiFi entire time if I remember correctly
    #70
  11. Desejmon
    Here are my new stats with turned off backup option and cleaned cash. Screen Brightness ~30% I think 5hrs SoT it's normal for this phone. I can get 6hrs SoT now after unchecking backup option :p But I have to use OP3 without stop. Let's say 6hrs SoT counting the % that runned out throw nights. Without "Messenger" will be another next 45min? So really u can get almost 7hrs SoT That's my opinion. WiFi/LTE always on.
    #71
  12. m4r1k
    Froyo Jul 31, 2016
    m4r1k , Jul 31, 2016 :
    Thanks.
    So mine just drain like a crazy when I use it. The display is always the main one.
    I just disabled the backup and now I'm going to clean the cache (again). Let's hope something will change ...
    #72
  13. Doko05
    Froyo Jul 31, 2016
    #73
  14. Benz1337
    Eclair Jul 31, 2016
    Benz1337 , Jul 31, 2016 :
    OK, something is wrong. Yesterday I charged from 33% to 93%. Overnight the battery went down to 77%! I cleaned the cache and restarted, before leaving it alone.
    #74
  15. Pinttas
    Honeycomb Jul 31, 2016
    Pinttas , Jul 31, 2016 :
    For me is the same.
    Of corse it deppends on your use.
    1)
    One day and 13h00 without charging and 5h07 SOT browsing, 2h00 of calls, 1h00 YouTube and 30 min. Of clash of clans...
    2)
    20 hours without charging and 6h01 SOT browsing 1h00, real racing 1h30, clash of clans 20min. 1h00 YouTube..
    Not bad for me
    #75
  16. APP11
    #76
  17. ritchiedrama
    Clear cache, turn off back-up, etc.
    It's clearly just cause of Android doing something.
    #77
  18. bhargav5544
    #78
  19. Xenti3
    Xenti3 , Jul 31, 2016 :
    I swapped to PacRom instead of losing 30% over 8 hours sleep with the partial wakelock in Oxygen. I instead lose 15% max so its much better though not as good as Oxygen was before the wakelock at about 8 - 10% over the same amount of time.
    #79
  20. AhmedZunaid
    AhmedZunaid , Jul 31, 2016 :
    Isn't this normal? I just dont have any games installed. Light usage gets me 2-3 days.
    btw SOT was 1hr 17m at the time of screenshot
    #80
