170
OxygenOS 3.2.6 (MM) OTA for OnePlus 3
  1. Alpha Mike Foxtrot
    KitKat Oct 2, 2016
    sankeerth24 likes this.
  2. Mike7pap
    Gingerbread Oct 2, 2016
  3. adpro
    KitKat Oct 2, 2016
    adpro , Oct 2, 2016 :
    Third party manual camera apps don't work properly with OP3, especially the slower shutter speeds (2 second to 30 seconds). They support manual shutter speed upto 1 second only. Why ?
    Is Camera2 API not implemented in OP3?
  4. adarsh majhi
    Eclair Oct 2, 2016
    adarsh majhi , Oct 2, 2016 :
    Hey guys how's the battery life on 3.2.7?
    Is it better than 3.2.6?
    Please comment your experience.
    N how much of SOT has increased or decreased from the previous update.
  5. F3AR
    Donut Oct 2, 2016
    F3AR , Oct 2, 2016 :
    No problems
  6. Alpha Mike Foxtrot
    KitKat Oct 2, 2016
    Alpha Mike Foxtrot , Oct 2, 2016 :
    I was getting about 5 1/2 hours SoT. I am yet to fully use up the battery.
  7. ChinChinati
    Jelly Bean Oct 2, 2016
    ChinChinati , Oct 2, 2016 :
    i am getting better battery than 3.2.6
  8. Mike7pap
    Mike7pap , Oct 2, 2016 :
    Have to report that the strange bug I had which made the notification panel a little bit laggy (without a reason)...is gone now after factory reset on 3.2.7...
    Sahilkum likes this.
  9. Alpha Mike Foxtrot
    KitKat Oct 2, 2016
    Finally. That's good to hear.
  10. adarsh majhi
    Eclair Oct 2, 2016
  11. adarsh majhi
    Eclair Oct 2, 2016
    Hey buddy, what are your comments on the battery life?
    Has it improved?
  12. adarsh majhi
    Eclair Oct 2, 2016
    Ya I am also getting around 5.30 SoT on 3.2.6
    So what are your thoughts on battery life with the new update.
  13. Alpha Mike Foxtrot
    KitKat Oct 2, 2016
    I'll check it out and post screenshots.
    adarsh majhi likes this.
  14. aakash0606
    Honeycomb Oct 2, 2016
    aakash0606 , Oct 2, 2016 :
    Got fixed in 3.2.7
  15. Mike7pap
    as of now the battery life is very good i think...i tested it with the lagginesh that i had for no reason....now after factory reset i'll have to test it again for 1-2 circles, but generally it seems good as i said before.
  16. Mike7pap
    Well I have to make another report....After restoring all my apps and setup....the laggy notification panel returned...it got on my nerves and I started investigating...the reason behind this stupid lag is if I check nova launcher under accessibility services...nova launcher BETA actually (which I always checked until 3.2.6 and was fine, maybe an update of nova caused it) then the notification panel starts to feel laggy and even nova launcher...so now I left everything off under accessibility as it was by default and I fixed my issue ...SO it is a bug that nova launcher BETA caused with accessibility settings... IF YOU HAVE LAGGY NOTIFICATION PANEL DO WHAT I SAID ABOVE. SORRY FOR THE SPAM JUST TRYING TO HELP :)
    Sahilkum and srlawren like this.
  17. zenmaster
    Cupcake Oct 2, 2016
    zenmaster , Oct 2, 2016 :
    This update (3.2.6) caused a game I play everyday (sky force reloaded) to lag big time. Making it unplayable. It's a scrolling game and maybe the battery optimisations for scrolling in this update is causing this. Really want to enjoy my game again.
    Please fix this one plus
  18. Mike7pap
    Install 3.2.7 via VPN and you are good to go mate .
    srlawren likes this.
  19. zenmaster
    Cupcake Oct 3, 2016
    zenmaster , Oct 3, 2016 :
    Thanks ! Works great now :)
    srlawren and Mike7pap like this.
  20. anandbs155
    Eclair Oct 3, 2016
    anandbs155 , Oct 3, 2016 :
    Hi All,
    Even after updated to 3.2.6 , still the signal fluctuates for airtel 4G in Bangalore ,India
    Tried changing the SIM Slots , but no luck. Can anyone tell me how to resolve this.
