170
OxygenOS 3.2.6 (MM) OTA for OnePlus 3
  1. ipalot
    Cupcake Oct 12, 2016
    ipalot , Oct 12, 2016 :
    I always use privacy guard to restrict APPs in order to stop battery drain
  2. Alpha Mike Foxtrot
    KitKat Oct 12, 2016
    Alpha Mike Foxtrot , Oct 12, 2016 :
    That's only for desktop version I think.
  3. Alpha Mike Foxtrot
    KitKat Oct 12, 2016
    Doesn't doze do the exact same thing?
  4. kalander Shihab
    Ice Cream Sandwich Oct 12, 2016
    kalander Shihab , Oct 12, 2016 :
    Good news guys, a staff DM'ed me asking about the Snapchat lag issue.
    I think they're looking into this.
    Finally!
    ungeeked, srlawren, Archies and 2 others like this.
  5. Revi1997
    Donut Oct 14, 2016
    Revi1997 , Oct 14, 2016 :
    wouldnt it be nicer if u add double tap to sleep in the next update??
    just a suggestion though.
    sachitsingh and Desejmon like this.
  6. adpro
    KitKat Oct 14, 2016
    adpro , Oct 14, 2016 :
    You can set double tap to sleep in gestures in settings.
  7. Alpha Mike Foxtrot
    KitKat Oct 14, 2016
    Alpha Mike Foxtrot , Oct 14, 2016 :
    I think he means double tap the screen. Like how LG phones have?
  8. adpro
    KitKat Oct 14, 2016
    Tapping buttons instead of screen is not that difficult. Anyways, having easier options are always appreciated.
  9. ritchiedrama
    Ice Cream Sandwich Oct 14, 2016
    ritchiedrama , Oct 14, 2016 :
    I suggest you go and seek psychological help.
    express75 likes this.
  10. express75
    Froyo Oct 14, 2016
    express75 , Oct 14, 2016 :
    hi guys, i just write this, to thanks to all OP team. My OP3 run really good. The update 3.2.7 works. its can get better, obviously. But you doing good job.
    I can't wait to see my OP3 with Nougat. Keep working like now.
    Archies likes this.
  11. Archies
    Archies , Oct 14, 2016 :
    Ok bro
  12. trickfinancials1120
    Froyo Oct 15, 2016
    trickfinancials1120 , Oct 15, 2016 :
    again, this was before the modified twrp and 3.2.6/7 update.
  13. ChinChinati
    Jelly Bean Oct 15, 2016
  14. HerrDeacon
    Cupcake Oct 16, 2016
    HerrDeacon , Oct 16, 2016 :
    New guy here and recently upgraded to 3.2.7 OTA and have found the battery drain to be exceptionally bad since the update. Found it good on 3.2.6 but 3.2.7 has killed it. Last night before going to bed it was at 25% and when I got up 7 hours later it was at 3%. No idea why.
    Also, not sure if its related to update since its only happened once but yesterday when I turned bluetooth on, the top section of the phone in back got very hot. Can't say for sure if it was bluetooth related or not but it only started after I turned it on. Used it before in the past with no problems. Anyone know what parts are located in the upper part of the device?
    Love this phone so hope they can address the battery drain or I can figure out the cause.
    Archies likes this.
  15. adpro
    KitKat Oct 16, 2016
    adpro , Oct 16, 2016 :
    Why don't you try doing battery re-caliberation. May be that will help. I am loosing 4-5% during night. Also getting 6 hrs of SOT on an average.
    Archies likes this.
  16. adarsh majhi
    Eclair Oct 16, 2016
    adarsh majhi , Oct 16, 2016 :
    Totally off topic!
    Which back cover should I get for my OP3,
    The Spigen neo hybrid or the Orzly grip pro.
    Please suggest.
  17. noquarter
    Lollipop Oct 16, 2016
    simonone likes this.
  18. Deactivated User
    Oct 17, 2016
  19. sachitsingh
    Cupcake Oct 17, 2016
    sachitsingh , Oct 17, 2016 :
    how to recalibrate ?
  20. Scherpenseel
    KitKat Oct 17, 2016
    Scherpenseel , Oct 17, 2016 :
    Empty the battery untill the phone shuts down and then charge it to 100%.
    sachitsingh likes this.
