170
OxygenOS 3.2.6 (MM) OTA for OnePlus 3
  1. adarsh majhi
    Eclair Sep 22, 2016
    adarsh majhi , Sep 22, 2016 :
    Mine is 5 hrs screen on time at 80% drained!
    Having said that I m not a heavy gamer, and have switched off gestures and I turn off mobile data when not in use. But I do watch a lot of videos online. N capture a lot of photos.
    Brightness at 20% and due to all these I m getting better screen on time.
    I used to get more SOT while I was on 3.2.2 though. This update slightly downgraded my phone battery life.
  2. azeemsiddiqi
    Eclair Sep 22, 2016
    azeemsiddiqi , Sep 22, 2016 :
    I'm getting 6 hours plus SOT. I think that is pretty great considering my device is stock and unrooted.
    adarsh majhi likes this.
  3. avinashvp
    Cupcake Sep 22, 2016
    avinashvp , Sep 22, 2016 :
    The Bluetooth issues with connection to car still persists. Can't hear voice on the call. Other Bluetooth features like media work perfectly well.
  4. sankeerth24
    Eclair Sep 22, 2016
    sankeerth24 , Sep 22, 2016 :
    For un rooted phones.. how to clear cache alone? I know it can be selected individually in twrp but in stock recovery .. I am wondering whether it ll wipe anything else..
  5. baratus
    baratus , Sep 22, 2016 :
    Makes sense. Anyway, I'm just wondering how complicated is add another language. Anyway, I have no problems using English or Portuguese from Portugal. :)
    Regards.
    G_Marco_Abrantes_cexi likes this.
  6. jakkipoika
    Gingerbread Sep 22, 2016
    jakkipoika , Sep 22, 2016 :
    You'd need to install adb and enable USB debugging in Developer options. No root needed.
    Sure it's throttling, but my device uses 624 MHz if needed.
  7. Flitcher
    Froyo Sep 22, 2016
    Flitcher , Sep 22, 2016 :
    I mean, you would't like it if a phone exploded in your hand instead. Hardware Controll pfftt..look at Samsung and Apple with exploding devices.
  8. manurd350
    manurd350 , Sep 22, 2016 :
    May be because you have clean installed. I have got it as OTA on my unrooted phone.
    Though after deleting cache games performance is better, but earlier it was flawless.
  9. Wi!dcat
    Eclair Sep 22, 2016
    Wi!dcat , Sep 22, 2016 :
    In stock recovery click on the wipe and factory reset option, it then gives u 3 other options one of which is just cache
  10. sotaque
    Donut Sep 22, 2016
    sotaque , Sep 22, 2016 :
    Less than 3 h SOT after the update when I was getting up to 5.30 h with 3.2.4. Wiped cache but it doesn't help... It's frustrating.
  11. Archies
    Ice Cream Sandwich Sep 22, 2016
  12. Fayizt
    Eclair Sep 22, 2016
    Fayizt , Sep 22, 2016 :
    Few observations after update to 3.2.6 on my OP3:
    - No improvement in adaptive brightness
    - Still no solid LED notifications for third party apps like Whatsapp. There are colour flashes as with 3.2.4
    - No improvement in battery consumption. Just on stand by mode with wifi, battery dropped by 3%.
  13. balivyta
    Honeycomb Sep 22, 2016
    balivyta , Sep 22, 2016 :
    i noticed, that camera uses a lot of resources, and phone becomes hot while taking pictures, its similar like when paying games, so i think it drains battery a lot...
  14. SheryVM
    SheryVM , Sep 22, 2016 :
    Bugs noticed.
    1.got a soft reboot once after quitting a game.had this issue in 3.2.4 also..
    2.games at the start have stutters initially then smoothen out... (not expected from a flagship)
    3.batery consumption and slight heating during heavy use like gaming and camera have increased compared to 3.2.4..
    On the positive side cam has improved, adaptive brightness has improved so getting a better battery life comparatively, drastic improvement in scrolling esp...
    I think the issue seems to be like a cpu throttling issue...
  15. G_Arnas_Klimavičius_PzI
  16. grk007
    grk007 , Sep 22, 2016 :
    I guess then its issue from your device may be.. try to clear data from the playstore and try to access it. Better connect it in wifi and check.. cause playstore loads some good amount of data in its homepage..
  17. kkmillennium
    Froyo Sep 22, 2016
    kkmillennium , Sep 22, 2016 :
    Second Day Use:
    - lag in settings (one time homebutton, back button, recent button stopped working until i turn on and off the screen again)
    - battery seems to be fine during idle but drains almost double the battery life comparing 3.2.4 when screen is on. Note: not gaming, just chattings through whatsapp or reading news through google news app
    - phone gets really warm still comparing to the original version out of the box which is super cold even while charging. This totally defeats the feature oneplus posted on official site that the phone runs cool even while charging!
    - phone performance and scrolling seems to be slower comparing to older versions especially gaming, scrolling through apps such as appstore and chrome browser
  18. grk007
    Its a MM Rom bro..!! u need wait for N ..
  19. akkiemehta
    Froyo Sep 22, 2016
    akkiemehta , Sep 22, 2016 :
    @Berg P. Battery drains drastically after the 3.2.6 update. Used to get 6 hrs of SOT on 3.2.4. Now struggling to even get 4!! Tried clearing the cache and other options too but nothing helps out. Please help out for this as battery is one of the most important concern for all!
    Archies likes this.
  20. tuenbabz
    tuenbabz , Sep 22, 2016 :
    This update works like a charm on my OP3, battery is better, and overall performance. Good job Oneplus :)
