8
OxygenOS 3.2.6 OTA bugs
  1. Flitcher
    Froyo Sep 18, 2016
    Flitcher , Sep 18, 2016 :
    for those that are still on 3.2.2, I recommend you to be patient and wait for other people to bring the bugs into light.
    also this is an incremental OTA update, so don't expect to get it right away.
    JyotiradityaG5 and runboy93 like this.
  2. harlekinwashere
    Honeycomb Sep 18, 2016
    harlekinwashere , Sep 18, 2016 :
    We are now getting into serious "potential deniability" management deliberations here.
    To turn off Doze (just to be able to receive notifications in time) is not a fix. Its something they can point at to say - "we have done something", but the issue is still there.
    Doze is a core Android system - why do we have to disable it on the Oneplus 3 to receive notifications in time?
    Why is none of the dev team talking to us about this issue? Its a major one - it makes the phone not work as a phone.
    It would help and reduce much of the confusion and negative sentiments out there if you could explain - why you cant get this working as it should.
    If its an impossible issue for you to fix - at least tell us why. You are preventing the phone from working as expected, and give us workarounds without going into why you won't fix the issue.
    arym, vjnow, dr.anel and 6 others like this.
  3. Colliwobbles
    Cupcake Sep 18, 2016
    Colliwobbles , Sep 18, 2016 :
    What is the Doze bug? Not sure I've noticed it but I'd like to be aware of it so I can monitor and leave feedback.
    Cheers.
  4. harlekinwashere
    https://forums.oneplus.net/threads/push-notification-issues.451149/unread
    TLDR: Notifications sometimes will arrive hours late, reminders will go into negative time instead of having the alarm (you set) go off.
    Only happens if the phone enters a special sleep state (Doze). Notifications that should go right through Doze - aren't doing that - things like that.
    JyotiradityaG5 and Colliwobbles like this.
  5. Deactivated User
    Sep 18, 2016
  6. Wilko2010
    Wilko2010 , Sep 18, 2016 :
    I think its not related to the Oneplus 3. I was noticing this behaviour before on the Samsung Galaxy S5. Notifications went through only when was unlocked.
    clayginn likes this.
  7. tytanmcbride
    Ice Cream Sandwich Sep 18, 2016
    tytanmcbride , Sep 18, 2016 :
    Can confirm, shows up the same for me too.
    Deactivated User likes this.
  8. Wilko2010
    Google Maps shortcut will be renamed after reboot
    When placing a shortcut for destinations within Google Maps onto the desktop, its given name will usually contain the destination. In my case it is named "Gabrielweg". This happens on oneplus3 as well. But after a reboot the shortcut will be renamed to "maps". I am on 3.2.6. This behavior was in 3.2.4 before. No root and nothing. Bootloader is locked. It sheems it has to do with the Standardlauncher, because this is not happening with nova launcher.
  9. samish.arora
    Froyo Sep 18, 2016
  10. adpro
    KitKat Sep 18, 2016
    adpro , Sep 18, 2016 :
    Mine shows as Pocket Mode and not like those numbers.
  11. nashi316
    Jelly Bean Sep 18, 2016
    nashi316 , Sep 18, 2016 :
    Yes doze,battery, heating issues are still unsolved. I was hoping for this bt ...
  12. AhmedZunaid
    AhmedZunaid , Sep 18, 2016 :
    No I did a typo there. "Common issues Doze, beattery, heating, sensor seem to be fixed." I have no problem with receiving notifications with the phone on sleep, and actually it's quite annoying sometimes. There was never a battery or heating issue for me tbh. My main problem was the ambient light sensor and that is fixed in the 3.2.6
    crumyee99, abhi77kumar and runboy93 like this.
  13. Schrotty40
  14. harlekinwashere
    Yet other phones dont have this issue.
    So what do we do? Oneplus doesnt give any statements as to why this is happening or provide a fix, instead they introduced a hidden workarround for people to deactivate a marshmallow feature.
    Now tell me, what parts of this sound right to you? And why should the majority if people out there life with a phone that cant do notifications correctly?
    None of this is new, btw - we had a dedicated topic on the issue thats 120 pages long and ongoing.
  15. nashi316
    But I m facing these problems did reset phone 2 times bt issue still persists
  16. Wilko2010
    As i mentioned before and to clarify: I had this issue an the Samsung Galaxy S5 and still having it. I'm on MM with the S5.
    I don't have this issue with the Oneplus3. Neither on 3.2.4 nor on 3.2.6. Which means i'm fine with my OP3
  17. Wilko2010
    I do think this is actually a bug within android MM showing on some devices.
  18. harlekinwashere
    As far as we know, everyone is having this issue on the Oneplus 3 - people just tend to overlook it most of the time.
    Dont ask me why. I dont see any reason to cut Oneplus any slack over releasing a phone that has problems doing notifications correctly.
    Four (?) months after its release.
    #38
  19. AcmE85
    AcmE85 , Sep 18, 2016 :
    @Wilko2010
    All apps? WhatsApp is the only app which provides instant push notifications on my device. All other apps only show notifications when I power-on the screen.
    Regarding your S5, does it happen on wifi AND mobile data?
    #39
  20. Nayaz99
    Donut Sep 18, 2016
    #40
    Archies, Limitbreak and f2008 like this.
