230
OxygenOS 3.2.8 (MM) OTA for OnePlus 3
  1. F_Pao_Placides_XWHG
    Donut Dec 20, 2016
  2. laurencew
    Cupcake Dec 20, 2016
    laurencew , Dec 20, 2016 :
    Having spoken to them on the online chat I'm going to send it back for repair and hope! Slightly lucky that I hadn't got around to selling my 5X so I can use that while I wait...
  3. yawarkhalid
    Honeycomb Dec 20, 2016
    yawarkhalid , Dec 20, 2016 :
    heating issues and thus faster battery drain is getting out of hand. need any sort of update asap!
    Andrei R. likes this.
  4. yuriz_ridwan
    Deactivated User and patrickSVK like this.
  5. GeesRiK
    Ice Cream Sandwich Dec 20, 2016
    GeesRiK , Dec 20, 2016 :
    What did they say on chat? Did you just explain and they agreed quick? Is it covered under Warranty and free of charge?
  6. elfuno
    Donut Dec 20, 2016
    elfuno , Dec 20, 2016 :
    This is a ridiculous comment... It's like you don't even understand the meaning of beta software nor how it has improved over the past three months thanks to great listening by oneplus. The only big issue about OOS community builds right now is battery draining due to Android System heavy RAM usage. I'd wish it was solved before OTA push if I was you. Blind complaints are useless.
  7. Francisco88
    Froyo Dec 20, 2016
    matuka and patrickSVK like this.
  8. santhanvgqa
    Froyo Dec 20, 2016
  9. JorgeManuelSilva91
  10. pradha91
    pradha91 , Dec 20, 2016 :
    I don't face any of the issue you mentioned. The charging adapter gets heated up and battery gets slightly heated up when it's below 10%. And for battery life, it's s improving by every update I get. Give it a few days, try if any rogue app is running in background and do some checks you should be fine :)
  11. ddhbanger
    ddhbanger , Dec 20, 2016 :
    You're so funny or well informed Which is it? I know, I'll start a thread/poll to decide.
    santhanvgqa and Asumos like this.
  12. Mohityadav7
    Froyo Dec 20, 2016
  13. fc_themaster
    Eclair Dec 21, 2016
    fc_themaster , Dec 21, 2016 :
    Blacklist works very bad... the caller hear one ring, then the phone auto-answer and close the call immediatly.
    Some third party apps does not allows any ring!
    The data planner does not support weekly and 28days plans (the only ones in italy)
    Still no call recorder.
  14. adpro
    KitKat Dec 21, 2016
    adpro , Dec 21, 2016 :
    Just noticed.. phone has been heating a lot lately. Today it heated to a point that i could not hold it anymore. Had to switch off the phone.
    This has been happening since 3.2.8 update.
    OnePlus devs pls fix it !
  15. Alpha Mike Foxtrot
    KitKat Dec 21, 2016
    Alpha Mike Foxtrot , Dec 21, 2016 :
    That'd mean bringing another MM update for the phone, currently the devs are working on the Nougate update.
    So most probably, it'll get integrated once official Nougat comes out.
  16. laurencew
    Cupcake Dec 21, 2016
    laurencew , Dec 21, 2016 :
    The person on chat was pretty clueless to be honest. I then had to submit an RMA and someone from support then e-mailed and said I needed to do a factory reset to begin with. So I'll do that tonight, check the camera again and then go back to them. I doubt it will fix anything as the issue has been there since I bought the phone. It is covered under warranty and should be free of charge, assuming the issue is still there after wiping it...
  17. GeesRiK
    Ice Cream Sandwich Dec 21, 2016
    GeesRiK , Dec 21, 2016 :
    Let me know how it goes when you wipe it. How long have you had the phone?
  18. laurencew
    It arrived 1st December, so only a couple of weeks but outside of the 15 day replacement/return window.
  19. lunchboxLarry
    Gingerbread Dec 21, 2016
  20. Asumos
    Asumos , Dec 21, 2016 :
    where is it?
    patrickSVK and laurenzo87 like this.
