130
OxygenOS 3.5.3 (MM) Community Beta for OnePlus 3
  1. Archies
    Ice Cream Sandwich Oct 13, 2016
    Archies , Oct 13, 2016 :
    They are still trying to fix snapchat lag so we have to wait for new update
  2. inkaine
    Honeycomb Oct 13, 2016
    inkaine , Oct 13, 2016 :
    Source?
  3. Archies
  4. Wahoux
    Lollipop Oct 13, 2016
    Wahoux , Oct 13, 2016 :
    report it in the dedicated app, Carl is tagged 10000 times per day and it's even not his job to take notes of the bugs
    inkaine and alexferdean like this.
  5. Mideon
    Froyo Oct 13, 2016
    Mideon , Oct 13, 2016 :
    Sorry for the question but can you remove the nfc and other icons from the status bar?
  6. EdgA
    Cupcake Oct 13, 2016
    EdgA , Oct 13, 2016 :
    enable systemUI tuner, there u can edit ur statusbar icons
  7. simonone
    simonone , Oct 13, 2016 :
    Yes, and unfortunately no. If you activate System UI Tuner (long press on cog in notification blind) then you can remove many icons. But not NFC or VoLTE.
  8. dermot33
    dermot33 , Oct 13, 2016 :
    Could you provide a link to this thread please ?
  9. Wrath1972
    Wrath1972 , Oct 13, 2016 :
    Hi all, is anyone still having NFC problems on this build. Haven't once managed to get it to work.
  10. betamax_bandit
    Froyo Oct 13, 2016
    betamax_bandit , Oct 13, 2016 :
    Thanks for the advice on this one, unfortunately the experience was the same with this version of Xposed as with the Rovio version and I'm guessing that there's an "incompatiblity" with this build of OOS and Xposed in some way (which I don't understand!)
    - Greenify can't verify that it has a Pro licence and suspect that it'd not working
    - App Ops crashes out
    Not essential I know - but once I have the power to control these things, I don't want to give it up :)
  11. humanzqzr
    humanzqzr , Oct 13, 2016 :
    Have you tried uninstalling the previous xposed and then installing xposed by wanam or did you directly flashed xposed by wanam ? I can confirm that xposed by wanam works .
  12. 0101ics
    Donut Oct 13, 2016
    0101ics , Oct 13, 2016 :
    Does any of you know if it is possible and how to activate VoLte on 3.5.3.
    Regards,
    Me
  13. Galahad95
    Froyo Oct 13, 2016
    Galahad95 , Oct 13, 2016 :
    Go to settings, then SIM. If you can't see the option, this means that you're operator does not support VoLTE yet
    otto2 and Archies like this.
  14. Archies
  15. sarwadravi
    sarwadravi , Oct 13, 2016 :
    is there any chance of adding Video calling feature in new OTA or Open Beta versions?
  16. runboy93
    Jelly Bean Oct 13, 2016
    runboy93 , Oct 13, 2016 :
    So they aren't fixing Snapchat lag currently, they asked more things from you. Did you provide more information to them?
    inkaine likes this.
  17. gurneyben
    gurneyben , Oct 13, 2016 :
    Ok, so we are taking a road trip today and I've noticed that my phone is almost never on 4g or 4g+, even when a moto x (2013) on the same carrier has 4g or 4g LTE. I'm indicating 3g right now. Any ideas?
  18. notcyf
    notcyf , Oct 13, 2016 :
    Ah, i missed the part saying that, i only read:
    I've used it myself on my Galaxy S6 once, but it was too laggy on this device.
  19. Archies
    Yes already provied. They asked me for some logs, screenshot and video recording
  20. F_Andrea_Ippolito_ZsRS
    F_Andrea_Ippolito_ZsRS , Oct 13, 2016 :
    I finally went for CB, after staying with stable since the start.
    Now I wonder: where is my battery icon in the notification dropdown? I used to tap on it to go straight to battery stats, but now as soon as I pull down the notification area, the battery disappears.
    Is there another way to go directly to battery settings, that I'm not seeing?
    Thanks
