62
OxygenOS 3.5.3 (MM) OTA for OnePlus 3T
  1. Deactivated User
    Dec 2, 2016
    runboy93 and recon0xe like this.
  2. vicusbass
    Honeycomb Dec 2, 2016
    vicusbass , Dec 2, 2016 :
    • "Added motion detection in camera and enhanced image capturing quality" - I would love to get this in OP3, so I finally can take some acceptable shots when subjects are moving
  3. tonykung
    Froyo Dec 2, 2016
    tonykung , Dec 2, 2016 :
    can i roll back this update? The battery drain from cell standby is getting worse?
  4. G_Lai_homwam_QHTI
    Cupcake Dec 2, 2016
  5. G_Lai_homwam_QHTI
    Cupcake Dec 2, 2016
  6. recon0xe
    Donut Dec 2, 2016
    recon0xe , Dec 2, 2016 :
    Basic features I'm missing from my Galaxy S7 are as follows..
    1. Auto max display brightness when launching camera to see display more clearly.
    2. Ability to turn on or off an "Always on Display" feature.
    3. Auto display brightness always too low even in day light (build 3003_28_161122).
    4. More display contrast options, OP3T dull compared to S7 though I think ambient sensor for higher auto brightness would fix this on the large side.
    5. RGB colour wheel/chart for more accent colours.
    Thanks for looking :)
    p.s. LOVING my new OP3T!!! Amazing battery and performance!
  7. negated
    Eclair Dec 3, 2016
    negated , Dec 3, 2016 :
    Actually, the main reason I decided to buy the OnePlus 3T now instead of waiting for a future OnePlus device is BECAUSE of the 1080p screen.
    Why? I'm afraid whatever's next will have a higher resolution. More pixels to power all the time == less battery life. 1080p screen is fine for a 5.5 inch device. I'd take battery life over pixels the human eye can't discern any day of the week. [e]1f609[/e]
    andrediaslopes and mcfeti like this.
  8. ningbo182
    Donut Dec 3, 2016
    ningbo182 , Dec 3, 2016 :
    Hope the new version could have chromecast build in at system grade and priority mode like CM does
  9. DamnedGuy
    Donut Dec 3, 2016
    DamnedGuy , Dec 3, 2016 :
    I like the way they changed dialer UI and etc.
    Would like to see this enchancments on op3
  10. runboy93
    Jelly Bean Dec 3, 2016
    runboy93 , Dec 3, 2016 :
    How to gather logs for bug reports
    https://forums.oneplus.net/threads/wifi-had-problem-in-turning-off.474905/#post-15407030
    1. Input "*#800#" from dialing interface, enter "oneplus logkit", delete history log
    2. Click "advanced", choose "save log type", select all these options (Kernel, Main, System, Radio, Event, Tcpdump), then click OK
    3. Click "save log"
    3. Click "get QXDM Log", choose "category"
    4. Click "open device log"
    5. Make the issue reproduce and take a screenshot to record the time, then stay for a few minutes (better above 10 minutes)
    6. Click “save log” again to stop it, enter QXDM Log and choose “close device log”
    7. Finally, enter filemanager > storage > oem_log, find the file, zip it and send it to us along with the screenshot.
    https://forums.oneplus.net/feedback/
    RonaldM and papolytic like this.
  11. BiOnicTecHie
    Gingerbread Dec 3, 2016
    BiOnicTecHie , Dec 3, 2016 :
    Didn't get it till now....
  12. Tomas_Nagaj
    Eclair Dec 4, 2016
    Tomas_Nagaj , Dec 4, 2016 :
    3T v3.5.3 Battery status indicator in quick settings status bar missing
    The redesigned GUI of quick settings is fine (what you get when you drag the status bar down with 2 fingers). I'm having only one issue with it. I'm missing the battery status indicator showing % of battery charge remaining and serving as a shortcut to the battery settings menu.
    The indicator is displayed on OP3 v3.2.7 and it's missing on OP3T v3.5.3 (screenshots included)
    Not a good design decision in my opinion.
    G_Paul_de_Vries_yrxV likes this.
  13. luckyken
    Cupcake Dec 4, 2016
  14. freeze0011
    Cupcake Dec 5, 2016
  15. 1357913579
    Cupcake Dec 5, 2016
    1357913579 , Dec 5, 2016 :
    purchased OnePlus 3T device in pop-up event and using it in dual sim the speed wont even cross 1mbps in 4g of I remove the second sim or disable it the speed drastically changes to 5-6mbps! don't know of its hardware or software problem..what to do?
  16. huebju
    Cupcake Dec 5, 2016
    huebju , Dec 5, 2016 :
    Hi,
    i have found a little visual bug in the Clock-UI related to the alarm clock (see https://imgur.com/TsTfCB0) the monday is behind the description. I use the German language of Oxygen. It's maybe for all languages so?
  17. koriwi
    Donut Dec 5, 2016
    koriwi , Dec 5, 2016 :
    i can confirm this error. i almost forgot to activate monday in my alarm clock.
  18. lutti
    KitKat Dec 5, 2016
    lutti , Dec 5, 2016 :
    Don't see a nougat update for 3t yet so looks like you are coming short on this promise. Then of course you are talking about the OTA release and not a beta version i'm sure but still looks like OP3 users can go for nougat right now and 3T users can not.
  19. alberto_87
    Cupcake Dec 5, 2016
    alberto_87 , Dec 5, 2016 :
    Same here, and i can't even use my mail (Gmail app). That's pretty annoying, i can go to Play Store but not to Gmail or Hangouts.
  20. huebju
    Cupcake Dec 5, 2016
    I had the same problem, nothing except factory reset has worked. After this everything was fine.
