123
OxygenOS 3.5.4 (MM) Community Beta for OnePlus 3
Thread Status:
Not open for further replies.
  1. viveknaudiyal
    Gingerbread Oct 17, 2016
    viveknaudiyal , Oct 17, 2016 :
    Just flash directly using adb side load and don't wipe the data. Clean cache and update through side load.
    I updated my phone under the same conditions as yours
  2. Ankitkamal
    Eclair Oct 17, 2016
    Ankitkamal , Oct 17, 2016 :
    Ok bye
    otto2, Jeffrey98 and Jamesst20 like this.
  3. Desejmon
    Ice Cream Sandwich Oct 17, 2016
    Desejmon , Oct 17, 2016 :
    Do you also have "squized" app icons? in All applications in settings and the battery usage history?
  4. mmddmm1702
    Honeycomb Oct 17, 2016
    mmddmm1702 , Oct 17, 2016 :
    Yes :/
  5. stephenboyo
    KitKat Oct 17, 2016
    stephenboyo , Oct 17, 2016 :
    Same here. Worked perfectly!
    josefn24 likes this.
  6. JasonMR
    Lollipop Oct 17, 2016
    JasonMR , Oct 17, 2016 :
    Yes it does
    crispy514 and Desejmon like this.
  7. drhide2020
    Eclair Oct 17, 2016
    drhide2020 , Oct 17, 2016 :
    wishing if you solve the bluetooth issue of media browsing in the official edition
  8. Desejmon
    Okay... Thank you 4 anwser couse I wanted to reflash the 3.5.4 :oops:
  9. danimartinez95
    danimartinez95 , Oct 17, 2016 :
    I'm having problems with the synchroniation with Google Photos. They said are waiting for wifi network and I'm connected to my WiFi network. I turn off the cellular data and still the same problem. Someone can help me with this??
    jiekuang likes this.
  10. Desejmon
    4 me would be great if this won't lag reading all for example +10 bluetooth devices
  11. Funk Wizard
    Moderator Moderator Oct 17, 2016
    Funk Wizard , Oct 17, 2016 :
    If your system partition is untouched you can flash ota via modified twrp
  12. raja.d
    raja.d , Oct 17, 2016 :
    just sideload the rom
  13. Funk Wizard
    I mean the feedback link the Google sheets
  14. daxklusifman
    Eclair Oct 17, 2016
    daxklusifman , Oct 17, 2016 :
    I had the same problem as you, but I found a workaround. And no, clicking on "I forgot my password" is not the solution, because after doing it and losing all my data, the problem was still there :(
    Okay, so here's my solution: You just have to disable an option that forces OP3 to ask for pattern during phone bootup. You can do it by going to Settings --> Security --> Screen lock --> Pattern (it will probably indicate that it's your current lockscreen method, but just select it again). It will ask you if you want your OP3 to ask for the pattern while booting or something like that. Simply say "No, thanks" and that's it! Now try booting into recovery and it should load normally. At least it worked for me :)
    That's a new 3.5.4 bug that @Carl or whoever is in charge of that kind of stuff should take into consideration.
    JJepse likes this.
  15. danimartinez95
    I have a great score with this version. Better than the Mi5s, it has the new Snapdragon 821. The OxygenOS is very great could be better but it's interesting OS
  16. lemonhater
  17. ritchiedrama
  18. kniVesss
    Jelly Bean Oct 17, 2016
    kniVesss , Oct 17, 2016 :
    I must apologise to starving children everywhere I hope you never get to hear about silly tantrums regarding OnePlus accent colours.
    SimonRam and stephenboyo like this.
  19. Malenkiy
    Cupcake Oct 17, 2016
    Malenkiy , Oct 17, 2016 :
    Здравствуйте было бы очень хорошо если вы сделали чтобы возможно было бы поднимать трубку когда я подношу телефон к уху и еще что бы в шторки ярлыков активных было больше спасибо
  20. DigitalAnarchy
    DigitalAnarchy , Oct 17, 2016 :
    doesn't work it asks you to set up a pin that's used also on lockscreen
