123
OxygenOS 3.5.4 (MM) Community Beta for OnePlus 3
Thread Status:
Not open for further replies.
  1. G_Marco_Pereira_PDfk Donut Oct 18, 2016
    G_Marco_Pereira_PDfk, Oct 18, 2016 :
    I am also having crazy android system and android OS usage on battery.
    Have cleared cache and done all of the usual. Suppose a full add sideload would be next but it's not helping oneplus if they don't learn what causes these otas to leave these problems
    inkaine likes this.
  2. aashay2035 Cupcake Oct 18, 2016
  3. F_Kseng_Roy_vtzR Cupcake Oct 18, 2016
  4. LiiightSkiin Honeycomb Oct 18, 2016
    LiiightSkiin, Oct 18, 2016 :
    K I think. I've tried everything to add sideload this build but I'm still getting cannot read I leave the original title of the file or change it doesn't matter whatever I put or do won't read the file I'm on 3.2.7 BTW trying to get to 3.5.4 such a pain -_-
  5. himanshudhoopia Honeycomb Oct 18, 2016
    himanshudhoopia, Oct 18, 2016 :
    Tha
    there is an for this! app lock (shield like app)
  6. himanshudhoopia Honeycomb Oct 18, 2016
  7. sedhupathi Donut Oct 18, 2016
    sedhupathi, Oct 18, 2016 :
    Any one having issues on puting mobile in a silent mode??... Cant able to put in silent mode by sliding the volume....
    Desejmon and MEJDEN like this.
  8. G_Onur_Öztürk_PFoR Cupcake Oct 18, 2016
    G_Onur_Öztürk_PFoR, Oct 18, 2016 :
    Since I have 3.5.4 it no longer can my wifi or mobile internet !! Must every time the phone rebooting to see if anyone has written to me Whats app that goes even for 1 second. In the beginning everything worked.
  9. York_21 Gingerbread Oct 18, 2016
    York_21, Oct 18, 2016 :
    Can't put the battery percentage inside the icon . . . .
    Come on guys! Fix that
    willy_907 and Desejmon like this.
  10. bkbkjbb Honeycomb Oct 18, 2016
    bkbkjbb, Oct 18, 2016 :
    No that looks stupid, small and crammed.
    pradeepv78 and clayginn like this.
  11. Aasresh Donut Oct 18, 2016
    Aasresh, Oct 18, 2016 :
    They are the same haven't changed.
  12. damiandd Honeycomb Oct 18, 2016
    damiandd, Oct 18, 2016 :
    You have to turn on the cellular data ..it won't use the cellular data ...but it will turn on wifi
  13. G_Maciej_Wilkosz_IRzz Cupcake Oct 18, 2016
    G_Maciej_Wilkosz_IRzz, Oct 18, 2016 :
    Hi,
    I have a problem with battery drain on bluteooth (I had the same after unpacking - stock rom). After update to 3.5.4 community everything was great but after yesterday's update my problems returned.
    Bluetooth is turned off but is still drain battery (screenshot). I noticed that when I wake up my phone I can see BT icon by a fraction of a second... so it works all the time, why?
    I have a smartwatch and I am worried about using it, while BT-OFF drain my phone, what will happen when I turn it ON.
  14. jiekuang Cupcake Oct 18, 2016
    jiekuang, Oct 18, 2016 :
    i have the same problem as yours. it may be a bug~
  15. viveknaudiyal Gingerbread Oct 18, 2016
    viveknaudiyal, Oct 18, 2016 :
    Try to check if the file downloaded is OK or corrupted. I was also on 3.2.7 non rooted, bootloader locked and was able to upgrade to 3.5.4 without any data loss through sideload
  16. stephenboyo KitKat Oct 18, 2016
    stephenboyo, Oct 18, 2016 :
    Most apps behave that way. Try using a nexus phone or Samsung and see whether your battery will last that long. Apps go wild unless you stop them with things like greenify or doze or just root your phone. Personally I feel battery management on the OP3 is very good, if you're a heavy user then keep your Dash charger nearby. Many people have totally unrealistic expectations of their Android phones and expect their batteries to last all day long without making an active effort to conserve usage by turning off WiFi or LTE when not in use or using app managers like greenify or doze. The more powerful your phone becomes the quicker the battery will drain unless you root or install battery managing apps. That's the long and short of it, ranting at OP won't solve anything.
    Please delete any apps youre not using, especially those powerful battery consuming apps that run in the background, you will immediately see an improvement in your battery life!
    inkaine and otto2 like this.
  17. Vector Jelly Bean Oct 18, 2016
    Vector, Oct 18, 2016 :
    I'm skeptical of this build...3.2.7 is where I'm staying for now. Can't beat 5 hour plus of on screen time with heavy usage.
  18. akkireddyashok987 Gingerbread Oct 18, 2016
    akkireddyashok987, Oct 18, 2016 :
    Are you guys adding unread badges at least in the next release???
  19. G_Tallai_Gergő_BchU Gingerbread Oct 18, 2016
    G_Tallai_Gergő_BchU, Oct 18, 2016 :
    Why don't the data wipe?
    So just clean the cache. Dont wipe data and factory reset?
  20. reyscott1968 Jelly Bean Oct 18, 2016
    Serco likes this.
