123
OxygenOS 3.5.4 (MM) Community Beta for OnePlus 3
Thread Status:
Not open for further replies.
  1. toureelhadj
    Froyo Oct 17, 2016
  2. JasonMR
    Lollipop Oct 17, 2016
    JasonMR , Oct 17, 2016 :
    It's only the SIM card pin that is causing the issue, if you have normal pin set up to use fingerprint then it is fine.
    otto2 and dermot33 like this.
  3. Wahoux
    Wahoux , Oct 17, 2016 :
    yes but here it's a big issue ... more OP fault
  4. mapulu
    Cupcake Oct 17, 2016
    mapulu , Oct 17, 2016 :
    My phone was set to german (germany). phone blinking seems to be a language issue. It only blinking when I should enter the SIM PIN. Removed the SIM-Card, go to settings and changed the language to English (US), now it works.
    Hope it would get fixed soon
    inkaine, louispires and nostfake like this.
  5. vamshichaithanya
    Eclair Oct 17, 2016
    vamshichaithanya , Oct 17, 2016 :
    Insert the sim card in other phone and disable simlock and reinsert again,the problem of blinking is gone..anfdif you want to use it right now remove the sim card phone is usable..
    otto2 likes this.
  6. dermot33
    Ice Cream Sandwich Oct 17, 2016
    dermot33 , Oct 17, 2016 :
    Thanks. Ill go ahead then
  7. fxguru77
    Jelly Bean Oct 17, 2016
    fxguru77 , Oct 17, 2016 :
    How did you do that i also Have the Same issue
  8. Micha121265
    toureelhadj likes this.
  9. mapulu
    What language do you use? Try to remove the SIM and set it to english. Worked for me.
    dubazar likes this.
  10. tobias14
    tobias14 , Oct 17, 2016 :
    this pin issue happens only when updating via OTA or also with clean flash ?
    I know I can disable PIN lock before flashing or updating, just curious
  11. robbiegast
    Honeycomb Oct 17, 2016
    savina likes this.
  12. JasonMR
    He removed it BEFORE updating.
  13. otto2
    otto2 , Oct 17, 2016 :
    OK, Phone is set up to german language. After de activating sim pin in another phone, i tried to re enable sim pin in my OP3. After reboot- flickering again. So right now phone is not usable with activated sim pin. OP3, Stock, german language setting.
  14. Magnetic Nerd
    Magnetic Nerd , Oct 17, 2016 :
    I got excited when I read the accent colours had be changed but they actually haven't :/ I don't see any change in any accent colours actually.... come on OP! These colours suck!!
    Don't have this bug other people have either (atm)
    Also was the, feature Carl wanted app locker?
    Wahoux likes this.
  15. KyaNani
  16. G_Florian_Piat_(Floxx)_S
    Froyo Oct 17, 2016
    G_Florian_Piat_(Floxx)_S , Oct 17, 2016 :
    Go back to 3.5.3 via adb sideload and wait for a fix. This is what i've done and it works fine. This is not normal that we must disable the PIN lock to do the update and be able to use the phone after.
    So, OP3 team, we are waiting for a fix. Thank you.
    Gearoid O Cathain likes this.
  17. dermot33
    I cant remember exactly where, but found option to turn off pin for sim somewhere while on .5.3. restarted it and didnt ask for pin, so Im assuming that it wont ask when I finish updating to .4. fingers crossed
  18. Umar Haroon
    Gingerbread Oct 17, 2016
    Umar Haroon , Oct 17, 2016 :
    Snapchat is working faster than normal for me
  19. arendal
    Froyo Oct 17, 2016
    arendal , Oct 17, 2016 :
    Solution worked for me
    Remove sim
    Change language to English (US),
    insert sim,
    remove sim lock,
    Change back to language you like
  20. G_Florian_Piat_(Floxx)_S
    Froyo Oct 17, 2016
    Do you think that snapchat is the more important on a phone? Wow...
