62
OxygenOS 3.5.4 (MM) OTA for OnePlus 3T
  1. ghettopops Honeycomb Dec 15, 2016
    #81
  2. tjy724 Honeycomb Dec 15, 2016
    #82
  3. Funk Wizard Lollipop Moderator Dec 15, 2016
    #83
  4. tjy724 Honeycomb Dec 15, 2016
    tjy724, Dec 15, 2016 :
    Yep My CX5 has connection issue that It didn't have with my OPT when it connects it works fine but dosent always connect like it should have to sometimes toggle bluetooth on and off a couple times to get it to connect
    #84
  5. Jyoti Prakash padhi Cupcake Dec 15, 2016
    #85
  6. Pankaj oneplus Cupcake Dec 15, 2016
    Pankaj oneplus, Dec 15, 2016 :
    Tony when will update for one plus 2 with volte and naugat update will come
    #86
  7. inffy Nordics POC Assistant Head Moderator Dec 15, 2016
    inffy, Dec 15, 2016 :
    Oneplus 3 won't get the OxygenOS 3.5 update, it will jump straight to Android Nougat, which is OxygenOS 4.0
    #87
    G_JV_jafa_CNtv likes this.
  8. jnasir93 Cupcake Dec 15, 2016
    #88
  9. sleeveroller Cupcake Dec 15, 2016
    sleeveroller, Dec 15, 2016 :
    I went to Settings->System Updates and it found a 24MB update which it downloaded. But it got stuck. So it just says "Downloading 100%".
    I've tried pausing the download and then continuing
    Rebooting the phone, it then finds the update again but it downloads very quickly as though cached somewhere.
    But regardless it always just stops at 100% and doesn't move on.
    Is there anything I can do for this?
    #89
  10. ariya Donut Dec 15, 2016
    #90
  11. otto2 KitKat Dec 15, 2016
    otto2, Dec 15, 2016 :
    Yes, look in this thread for a Link to a google drive, there you ll find the full ROM ,1,3 GB , download and install via ADB.
    #91
  12. dalton Ice Cream Sandwich Dec 15, 2016
    dalton, Dec 15, 2016 :
    Vpn and Usa will get you the update :)
    #92
  13. SimonRam Lollipop Dec 15, 2016
    SimonRam, Dec 15, 2016 :
    Never, 4.0 is next, when is anyone's guess
    #93
  14. G_Danny_Kriegbaum_Laurse Eclair Dec 15, 2016
    #94
    dalton likes this.
  15. worldpeace1977 Eclair Dec 15, 2016
    worldpeace1977, Dec 15, 2016 :
    Yeah I was looking for that too after reading a post elsewhere that it is now enabled in America [e]1f612[/e]
    #95
  16. gubro Jelly Bean Dec 15, 2016
    #96
    phitesh2016 likes this.
  17. phitesh2016 Gingerbread Dec 15, 2016
    #97
  18. littlejonny17 Donut Dec 15, 2016
    littlejonny17, Dec 15, 2016 :
    Can the clear all notification button on lockscreen be removed?? This is annoying because every time i try to hit "0" I hit that button instead!!
    #98
  19. G_范東曉_lOVy Cupcake Dec 15, 2016
    #99
  20. otto2 KitKat Dec 15, 2016
    Dear Cupcake: How about reading OP first (and understanding ) before asking?
    Just a little spoonfeeding for you, since i m in a good mood today: An incremental update will be released for a small group first, then they ll check if it works without issues, then they ll release it for all users. At same time they ll probably release the full zip . Until then it will only get via OTA to the users who have rooted their systems and cannot use the Small update file.
