316
OxygenOS 3.5.5 (MM) OTA for OnePlus 2
  1. Robson
    KitKat Dec 22, 2016
    Robson , Dec 22, 2016 :
    THEY DYEDED WHEN THEY TESTED IT
  2. Techder
    Ice Cream Sandwich Dec 22, 2016
    Techder , Dec 22, 2016 :
    What and not for the op3...... Rip
    :eek:
  3. Manish roy
    Donut Dec 22, 2016
    Manish roy , Dec 22, 2016 :
    about the app lock ...once its opened you dont need to put password again...really its of no use ....it should ask every time you open it after closing the app totally ...otherwise its a waste...
  4. Deactivated User
    Dec 22, 2016
  5. Anzik
    Anzik , Dec 22, 2016 :
    The volume slider don't want to set for MINIMUM
  6. Hobo2k
    Cupcake Dec 22, 2016
  7. Manish roy
    Donut Dec 22, 2016
  8. rarog
    Assistant Head Moderator Assistant Head Moderator Dec 22, 2016
    otto2 likes this.
  9. 300396
    Froyo Dec 22, 2016
  10. The Imp
    The Imp , Dec 22, 2016 :
    its tested u can't do so it was introduced in oneplus 3 you will have to put the alert slider in silent mode and if you want vibration then also enable the option in silent mode for vibration you can't do by bringing the volume down to lowest
    otto2 and Sahilkum like this.
  11. [email protected]+
    Gingerbread Dec 22, 2016
  12. koolharshit7
    Froyo Dec 22, 2016
    koolharshit7 , Dec 22, 2016 :
    I used LinkVPN and got the update notification...will inform about the bugs after updating..Enjoy
  13. Hobo2k
    Hobo2k , Dec 22, 2016 :
    And I'm missing my battery icon with prozent :-(
    Found, But the App Permissions I wound understand: wether will make phone calls??? -> deinstalled
    and so on...
  14. Dr.kandas
  15. Dr.kandas
  16. Abhimanyu Mane
    Honeycomb Dec 22, 2016
  17. rarog
    rarog , Dec 22, 2016 :
    This seems to be the desired behaviour. It's same on OP3, OP3T. You have to go into silent mode via slider.
    kpmak, otto2, jaivaghela and 3 others like this.
  18. Anzik
    Where is the admins that I can write to? What's is wrong with volume slider?
  19. Anzik
    How I can write you directly? I want to ask something :(
  20. rarog
    If you want to write to me directly, just use PM. You can even write in Russian. :D
    otto2 likes this.
