316
OxygenOS 3.5.5 (MM) OTA for OnePlus 2
  1. Dillinger
    Gingerbread Jan 10, 2017
    Dillinger , Jan 10, 2017 :
    I have done all that on 3.5.5 and 3.5.6. It will not connect onto AT&T in Sim 2. I did read that AT&T do not support Volte on their network at the moment, but I will not be using Volte at this present moment in time. Thanks for listening bro. I will look at it later this month as I do not wish to spend my holiday time messing around with the phone.
    nikhilanroid7 likes this.
  2. tiffanyhsu322
    Cupcake Jan 10, 2017
    tiffanyhsu322 , Jan 10, 2017 :
    mine is totally doing the same thing. I had my phone charging while updating from 3.5.5 to 3.5.6. Once the update completed it was at 59% when the initial update was at 74%. Within an hour of unplugging the charging cord, the battery percentage drops at least 20% when it's just sitting at my desk.
  3. katariyaketak
    Donut Jan 11, 2017
    katariyaketak , Jan 11, 2017 :
    Facing issue with charging, charging time taken much time than the earlier. Some issue after update to 3.5.6.
  4. Yash97
    Donut Jan 11, 2017
    Yash97 , Jan 11, 2017 :
    Brief Review: This update of OOS 3.5.5 sucks big time.
    Detailed Review:
    PROS:
    1) VoLTE is a pleasant welcome.
    2) Schedule power on off is a very useful feature IMO.
    CONS:
    1) The device lags, All Google apps like youtube open after a second or two. Top games like Jetpack Joyride, Clash Royale stutter and lag during gameplay.
    2) The redesigned Contacts and Dialler apps look pathetic. The earlier stock-ish UI to these apps was way better.
    3) BATTERY DRAINAGE. This is the most annoying thing of this update. Battery drains at crazy fast speeds but takes a lot of time to charge. My phone has been connected to the charger pretty much all the time since I updated my device.
    I would go to sleep with my device at around 25% battery and wake up 7 hours later to a Switched OFF device.
  5. aditya0205
    Froyo Jan 11, 2017
  6. Lalit_12345
    Cupcake Jan 11, 2017
    Lalit_12345 , Jan 11, 2017 :
    I Tried with Hard Reset Also. nothing is working. no VoLTE . not able to make phone call directly.
  7. Tim Vestergaard
  8. Arul karthik
    Eclair Jan 11, 2017
  9. Prasun_Pramanik_FNpU
    Prasun_Pramanik_FNpU , Jan 11, 2017 :
    After the latest update, from few days i am facing a problem. While using some apps suddenly it gets closed and device is asking my password just like after restarting the device but it actually not restarting the device.
    What should I do???
  10. robypil
    robypil , Jan 11, 2017 :
    thanks
  11. Bibin Alexander
    Froyo Jan 12, 2017
    Bibin Alexander , Jan 12, 2017 :
    So there's no point in performing a hard reset as well. This is so frustrating.
  12. Lalit_12345
    Cupcake Jan 16, 2017
    Lalit_12345 , Jan 16, 2017 :
    Thanks A Lot Man !!! You Saved Me. !!
    Enjoying VoLTE Proudly.
    No Battery Issue
    No Network Drop
    No issue. i am using from last 4-5 days. Working like Charm .
    Thanks Man !!
  13. LoveCupid02
    Cupcake Jan 17, 2017
    LoveCupid02 , Jan 17, 2017 :
    I'm experiencing a problem with eap-sim not being able to authenticate. Anyone else experiencing the same issue?
  14. Hassan junior
  15. Lalit_12345
    Cupcake Jan 30, 2017
    Lalit_12345 , Jan 30, 2017 :
    After 15 days its stopped working again.
    if you shift data network from 1st sim to 2nd sim. this problem is coming up.
    please resolve this
  16. dmolloy
    Cupcake Mar 23, 2017
    dmolloy , Mar 23, 2017 :
    I have a2005 , and can not use lte network since 3.5.5 upgrade. I have wiped cache etc, used instructions to downgrade to 3.1 and upgraded to 3.5.6 from there and still can not use LTE.
  17. Danish anjum
    Eclair Mar 23, 2017
  18. F_Balaji_Subramanian_mjS
    Donut Mar 23, 2017
  19. Shivangbansal
    Froyo Mar 23, 2017
    Deactivated User likes this.
  20. G_Durgarao_Polisetty_jDK
    Donut Mar 25, 2017
