316
OxygenOS 3.5.5 (MM) OTA for OnePlus 2
  1. Blachloq
    Gingerbread Dec 22, 2016
  2. Mohamm3d_adam
    Froyo Dec 22, 2016
    Mohamm3d_adam , Dec 22, 2016 :
    Use the alert slider. Put it in top most position and magic.
    Nvds, Sahilkum and habeeb_dashti like this.
  3. Mohamm3d_adam
    Froyo Dec 22, 2016
    To fix the network drops download network guru app and give it root access, then go to band locking- lte - select b3 or b5 and select stop test and exit. No network drops whatsoever.
  4. Ashu0612
    Cupcake Dec 22, 2016
  5. Deactivated User
    Dec 22, 2016
  6. shivagonal
    shivagonal , Dec 22, 2016 :
    After updating some options moved somewhere. where is screen shot option.? and How to clear all apps which are running in background..?
  7. hanhaenger
  8. shivagonal
  9. Mickyadi
    Gunjan Ft Shady likes this.
  10. jayypanchal
    Froyo Dec 22, 2016
    jayypanchal , Dec 22, 2016 :
    Hello...
    There is a fix for network drops but for rooted users...
    Install the new oxygen os 3.5.5
    Root it
    Install Network Signal Guru app from Play Store.
    Lock the baseband to LTE B3 and B5
    Click on Stop Testing and than exit the app.
    Thats it... No more network drops... Enjoy... This is personally tested by myself.
  11. Adityaf
    Ice Cream Sandwich Dec 22, 2016
    Adityaf , Dec 22, 2016 :
    Disable one SIM
  12. Gunjan Ft Shady
    Gunjan Ft Shady , Dec 22, 2016 :
    Hi Guys,
    there's a lot of Network Drop... honestly it's kinda irritating.... its creating a lot of issues.. if someone has some solutions.. kindly help...
    such a great update and I am not Enjoying
    Raajeshsahoo likes this.
  13. shujat17
    shujat17 , Dec 22, 2016 :
    After upgrade screen freezing momentarily, battery percent disappeared.
    Thanks for upgrading wish you great holidays and have wonderful Christmas.
  14. Raajeshsahoo
    Eclair Dec 22, 2016
    Raajeshsahoo , Dec 22, 2016 :
    Sir,
    All time phone get disconnected for carrier network please fix it.
  15. 72084
    Froyo Dec 22, 2016
  16. Raajeshsahoo
    Eclair Dec 22, 2016
    After update I also face the same..
  17. SoniaB
    Head Moderator; Community Hero 2020 Head Moderator Dec 22, 2016
    Tobikage and Robson like this.
  18. The Imp
    The Imp , Dec 22, 2016 :
    You have 2 options to take screenshot
    1. Vol Down+power
    2. go to gesture in setting and you can tick the option of three fingered screenshot
    Clear all apps which are running in background can be done by:-
    go to settings->advanced->recent app management->Deep Clear
    so when you will clear all your apps then it will do deep clear i.e clearing all apps in the background
    Hope i solved your problem.
    tnewman66, Sahilkum and shivagonal like this.
  19. Deactivated User
    Dec 22, 2016
  20. Spannaa
    KitKat Dec 22, 2016
    Spannaa , Dec 22, 2016 :
    Looks like you're the guinea pig!
    Try the latest official SuperSU zip and, if you can't boot, use the latest modified version from the OOS mirrors thread instead.
    rarog likes this.
